12-24-2012, 02:39 PM
#4411 |
Trail less traveled
Oddometer: 91
I filled up my new Safari tank and put 4.29 ga. to the bottom of the neck. Put on 80 mi in the dez yesterday and got 35 mpg over varrying terrain. I had to add just one click on the fork comp with the extra weight of fuel from the 3.2 that was on there before. The only time I noticed the little more width was when putting a leg up forward for a berm where it contacted my boot. All in all this is going to work well for my Baja trips.
I'm not day dreaming, I'm prerunning |
12-24-2012, 04:02 PM
#4412 |
Sir Ray!
Oddometer: 978
just fitted the 12.2ltr, now the 6ltr rear to come
Well after chatting to a few peeps I am starting to kit the Kato up alittle,
got the 12.2ltr tank fitted this morning Old tank coming off ![]() ![]() ![]() old tank, new black 12.2ltr clarke tank from the states ![]() ![]() new one on ![]() perfect fit, and i like the black on orange ![]() ![]() fitting the rear tank later on today, also lookin into a Oil Cooler, anyone running one that can offer up some advice, wanna take the Oil capacity up to about 1.8ltrs i think it does, after Xmas, the supermoto rims come :) nice merry xmas to you all Ray ![]()
1998 XR250R Honda 2004 KTM 525 exc |
12-24-2012, 11:19 PM
#4413 |
yup ima hairstylist
Oddometer: 7,562
i have an 04 525 EXC and fitted the oil cooler. it leaked. had my mechanic (at the time) look into it multiple times. still leaked.
took it off after about a year with it on. oil changes are annoying. my 2 cents.
"when there is no more room in hell, the dead will walk the earth" YOUTUBE LINK www.RAZR.whereamiriding.com |
12-24-2012, 11:23 PM
#4414 |
Oddometer: 8,066
HT? If so, what version? The old 2-piece was (in)famous for leaking. My (welded) 1-piece has never leaked at the gasket. It does weep *very* slightly at the lower banjo but I don't really tighten them more than 2-finger tight and I expect this would be solved by new copper washers. It's barely noticeable until after a few hundred miles of dirt get stuck onto the cooler and then you can see the tiny amount of oil weeping out of the banjo.
12-24-2012, 11:28 PM
#4415 | |
yup ima hairstylist
Oddometer: 7,562
1 piece. i'm not totally against it. i'd be into hearing what ppl have done to prevent the leakage. and like i said, that was back when Javier was my mechanic. so by that being said, nothing was very accurate. but i will say that changing oil was a pain.
12-24-2012, 11:33 PM
#4416 | |
Oddometer: 8,066
Mine has been fine. I'd recommend it 100% and that's pretty rare for an asshole like me.
Call Bill Sr. He's a super helpful guy. Just go to the website and get the # for the tech line. Quote:
SEASONS GREETINGS TO MY FELLOW RFS OWNERS!!!! |
12-25-2012, 01:05 AM
#4417 |
Oddometer: 326
What are the additional steps involved when doing an oil change with the HT Cooler installed?
12-25-2012, 09:10 AM
#4418 | |
Oddometer: 8,066
add 10oz extra oil into the standard fill hole, prime the existing 1.2l before doing this (run starter for 20 secs, ignition off) |
12-25-2012, 05:39 PM
#4419 | ||
yup ima hairstylist
Oddometer: 7,562
don't forget to mention the drain plug on the oil cooler is on the side of the engine and oil runs down the side of the oil cooler.
12-25-2012, 05:44 PM
#4420 |
Oddometer: 8,066
Can't say its a major issue for me, I find the recessed location of the two OEM filters to be far more messy
crazybrit screwed with this post 12-25-2012 at 06:00 PM |
01-05-2013, 12:42 AM
#4421 | |
Oddometer: 95
Suffering is caused by desire, A. Sh. |
01-05-2013, 03:16 AM
#4422 |
What sort of riding are you planning on? I installed one on my 450 for some desert riding I did in Tunisia last year. For woods/enduro riding I would say its over kill. It is a good conversation starter though. Lots of people ask me what it is. PM me if you would like links to my install.
01-10-2013, 07:54 AM
#4423 |
Avoiding pavement
Oddometer: 1,933
I hate to ask here, but I'm not having luck elsewhere. Does anyone have a headlight lens they want to sell? (i.e., left over after an upgrade). It would be for a 2007 525 EXC, so, rectangular and glass. Let me know by PM. Thanks.
01-12-2013, 08:58 AM
#4424 | |
Oddometer: 95
01-12-2013, 04:25 PM
#4425 |
Oddometer: 8,066
Trailtech stator output
I posted this over at ktmtalk. I was sent it by Trailtech a couple of weeks ago. I'll post it here in case anyone ever needs the info (for knowing when it's safest rpm wise to run accessories). I received it as 'KTM stator test 12182009.pdf' but it's easier to host it as a JPG. The tests I've run on my 07 450 seem to confirm the values but if you have questions about it, you should ask Trailtech.
