Old 04-24-2013, 11:22 PM   #4606
MKJ
Married w/ Children
MKJ's Avatar
Oddometer: 557
Originally Posted by Motorfiets View Post
any know a good operating temps for the 525? I just installed my trailtech and curious what temp range I should set...
( KTM 525 temperature range ) <---- for google one day
My fan kicks on at 190. 180 should be a normal operating temp.
MKJ is offline   Reply With Quote
Old 04-25-2013, 07:56 PM   #4607
Hayduke
///SAFETY THIRD///
Hayduke's Avatar
Oddometer: 43,779
I had my trailtech set to light up the yellow light at 200, and the red light at 225, I believe.
"What these people need is some mental psychology."-Bonnie Abbzug
Hayduke is offline   Reply With Quote
Old 04-25-2013, 08:15 PM   #4608
Motorfiets
Motorfiets's Avatar
Location: North of Jack Daniel's, South of Country Music
Oddometer: 2,997
awesome thanks
Ben
My Photo's
Motorfiets is offline   Reply With Quote
Old 04-26-2013, 12:11 AM   #4609
Al-X
Al-X's Avatar
Oddometer: 217
Need some advice from you clever dudes.
Will a steering dampner from an 07 250XC-W 2t fit my 07 525XC?
Can get one for cheap as my bike have a real bitch slap some times
98 Honda XR600R, 06 Suzuki DL1000VS ADV, 11 Honda XR125L, 01 Honda CR250R
90 Yamaha DT180, Yamaha PW80, for the laaitie.
PREV: 95 DR250S, 04 KLR650, 96 R1100GS, 06 WeeStrom, 05 DRZ400, 00 XR650R, 07 KTM525XC
Al-X is online now   Reply With Quote
Old 04-26-2013, 12:12 AM   #4610
Al-X
Al-X's Avatar
Oddometer: 217
Ben, how reliable is the Trailtech there by you guys? Here in SA every one is complaining about them not handling heat or moisture?
I want to put my RS concepts back and need a proper speedo set up?
Old 04-26-2013, 07:56 AM   #4611
Hayduke
///SAFETY THIRD///
Hayduke's Avatar
Oddometer: 43,779
I had a Trailtech Vector, and had it in a HDB protector. Worked great for the couple years I had it, and is still going for the guy I sold the bike to. Never an issue at all; I really liked it.
Old 04-26-2013, 12:02 PM   #4612
Swarthy_Red_Beard
Oddometer: 153
I'd say call the manufacturer. Both Scotts and GPR have really helpful guys that will point you in the right direction and make sure you have all the needed components. That's the route I would go.
-Matt
Swarthy_Red_Beard is offline   Reply With Quote
Old 04-26-2013, 01:50 PM   #4613
mb300
mb300's Avatar
Oddometer: 47
Try going to a 14 or 16mm triple clamp if you can find one, really helps out stability. One of the best mods I ever made to my 525.
mb300 is offline   Reply With Quote
Old 04-28-2013, 09:01 AM   #4614
The Rizz
The Rizz's Avatar
Oddometer: 634
Quiet exhaust
Looking for a way to quiet the beast. Anyone got a quiet exhaust or tip/insert they'd either recommend or be willing to sell? Even repacked, the stock exhaust is too loud for my liking.
Current: 2000 ZR7, 2006 450 EXC
Sold, stolen, or totalled: 1997 DR650, 2008 Versys, 2004 525 EXC, 2009 Street Triple, 2005.5 950 Adventure, 2003 DRZ400e, 2000 DR650, 2004 KLR650, 2003 DRZ400s, 2002 DRZ400s, 2003 FZ1, 1998 VFR800, 1996 Ninja 250 race bike, 2000 TL1000R, 2000 ZR7.
The Rizz is offline   Reply With Quote
Old 04-29-2013, 05:58 PM   #4615
GR0NK
Got some screws loose!
GR0NK's Avatar
Oddometer: 1,966
Pull the endcap off, there's a short section of tube that extends into the muffler. Drill a hole through both sides near the end and put a bolt through it. If you've ever seen the stock exhaust on some enduro bikes (like a Honda XR650L) you'll see the same thing from the factory. Takes the edge off the pops and deadens the boom at higher RPMs. I use this trick (with new packing) to make sure I pass sound checks at rallies and enduros.
Sean
Team Valley Bomb Squad
Nullus Vereor ex Terra Incognita
GR0NK is offline   Reply With Quote
Old 04-29-2013, 08:41 PM   #4616
The Rizz
The Rizz's Avatar
Oddometer: 634
Sean
Genius! That's a cheap fix. Will try it this weekend!
Old 04-30-2013, 06:07 AM   #4617
Al-X
Al-X's Avatar
Oddometer: 217
I need a favour. I have this RS Concepts kit that I got with the 525. Want to fit itagain but need some pics as to what goes where? Motorfiets has put up pics that has helped a lot, but I need a bit more detail from the side.
In the box is some aluminium brackets that must go somewhere, I just do not know where and the RS Concept website is also not really forthcoming with info or pics that I can get an idea of?
Much appreciated!
Old 04-30-2013, 07:22 AM   #4618
sweetlou
small body, big balls
Oddometer: 1,289
I know this is as an adventure bike thread, but how about as a supermotard??
Time to start working on the suspension....
Lou
[2013 KTM 990 SM-T] - Wings, LED aux lights, et al.
[2014 KTM 690 Enduro R] - Wings, Nomadic rack, et al.
[2009 KTM 250 XCW(e)] - NY Street Legal!
sweetlou is offline   Reply With Quote
Old 04-30-2013, 03:40 PM   #4619
bigtodd
Hi, wanna ride?
bigtodd's Avatar
Oddometer: 1,489
I recently picked up some small LED flood lights that I want to mount on my 525. Does anyone know of an existing aftermarket light bar that mounts to the 525? I have seen them on 950/990's.
Should be easy enough to make something that would attach to the lower fork brace between it and the fender. But if there is already a part out there, might save me some trial and error.
Life is an adventure that requires the correct equipment
SPOT - bigtodd - where I at now?
bigtodd.whereamiriding.com
bigtodd is offline   Reply With Quote
Old 04-30-2013, 11:03 PM   #4620
Wallrat
Wallrat's Avatar
Oddometer: 623
I just hacked some 1/4" aluminum angle. Plan on taking em off and trimming them up a bit with a die grinder to make em blend in a little better but fairly low priority so haven't gotten to it yet.
07 565EXC
09 F800GS
03 Beta 270
12 Kuberg Start
13 Kuberg Cross
Wallrat is offline   Reply With Quote
Times are GMT -7.   It's 12:43 PM.
