02-12-2007, 03:50 PM
#91 | |
I know a shortcut!
Oddometer: 9,481
02-12-2007, 04:05 PM
#92 | |
fishing with dynamite
Oddometer: 2,030
02-12-2007, 04:30 PM
#93 | |
Runs at Mouth Adventurer
Oddometer: 1,214
The BPD guards are a work of art and will please you enormously when you see them on your bike. http://www.spokanister.net/ktm_bullet_proof.html Note in this pic the difference in widths between the two guards (steel guard under, both positioned as they would mount to the frame): Please keep us updated with this project, once you get wrenching! John E Davies screwed with this post 02-12-2007 at 04:42 PM |
02-12-2007, 04:44 PM
#94 | |
Oddometer: 126
270 watt stator is on shopping list, as is the Acerbis tank. With the Scotts damper, do I need any other kit with it? triple clamp? bar adaptors? I've seen pictures of it, but I dont understand how it works - its way different to a steering dampener on a sports bike! I'm buying stuff this week - Wolfman luggage (once I've decided which ones), HT oil cooler, 270w stator, 22L Acerbis tank, TT mounting for GPS, and Renazco seat In the meantime I'll look on Ebay for the rest...
'07 KTM 950 Super Enduro '04 KTM 525 MXC '00 Ducati 748 Biposto '89 Honda Camino (The Adventure Moped) |
02-13-2007, 12:47 AM
#95 | |
Bend it Bend it
Oddometer: 5,437
02-13-2007, 09:07 AM
#96 |
Pretty much...
Oddometer: 374
Stu,
Ok, part numbers. '05 Adv rear wheel complete - 582 10 00 11 44 30 has been changed to '06 wheel. Same thing. Sprocket carrier - 583 100 50 144 Dampners - 546 10 45 9 000 Leesbian - Find the dampner first. Scotts is very specific with their mount and the position of your handle bars (1 through 4). You must know this before you order your stuff from them. Bolt-on post mount is the way to go.....unless you like welding to the frame. Pics of Wolfman Luggage - rear bag mounted for pic. |
02-13-2007, 09:24 AM
#97 |
Pretty much...
Oddometer: 374
Stu -
Ahhhhh, I know what you mean. My space for the gap is more like 3 mm. No calipers yet. I've had 0 problems. Does this help? |
02-13-2007, 01:08 PM
#98 | |
Oddometer: 126
Will phone my local dealer in the morning to get a price on the rear wheel... what year is your bike? or would a better question be, do you know the part numbers (on your bike) that these replacements for? (I can find out what the part numbers for my bike are in the manual). I just want to be sure that there arent any variations for different year models (and I'm pretty sure that the guys at the KTM dealers won't know about sticking an LC4 rear wheel on an EXC/MXC). Sorry for all the questions! The luggage you recommended looks great - I was worried cos the tank bag looked huge on the Wolfman website, but I guess it can be compressed down. I'll order those tomorrow - waterproof is definately the best idea (dont want all my gear getting wet/muddy or dusty). I think I need to give Scotts a call - another thing I need to think about is finding heated grips that will either fit the bars I've already got, or find bars to fit whatever heated grips are available (looks like over hear the choice is limited to Oxford products). I know - heated grips on one of these bikes sounds not terrifically rock n roll, but I think on a RTW trip, they're gonna come in handy! Going to order my Acerbis tank tonite, or first thing tomorrow...
02-13-2007, 01:17 PM
#99 |
Buffo Maximus
Oddometer: 850
Cush Hub
Vuugti,
Thanks for the info! I also posted a note on KTMTalk to see if anyone has made the wheel work. I will let you know what I find out. On my '06 wheel with the '06 backing plate (p/n ending in 344, not 144) I could not get the backing plate to squeeze into the wheel with the cushion rubbers installed. I used the axle, axle nut and some tubing "spacers" to draw the whole thing together. You got 3mm, which would be tight but it would work (you did it) and I got 8 to 9 mm of backing plate sticking out. No go. I will try your part numbers and see what I can come up with! Thanks!! Stu |
02-13-2007, 01:24 PM
#100 |
Oddometer: 126
Having just talked about checking part numbers in manuals, I've discovered 2 things :
1) the part number for my complete rear wheel appears to be 548.10.001.244 which appears to be an EU only part number. I'm hoping you're going to tell me the part number for your original rear is either that or 548.10.001.344 2) my bike is a 2004 model, I'd assumed it was 2003, cos thats when it was first registered. Apparently it aint, cos all my manuals have 2004 all over them
02-13-2007, 02:05 PM
#101 |
Buffo Maximus
Oddometer: 850
Euro Wheel
Leesbian.
KTM USA does NOT want the RFS on the streets here and has made that clear over the years. I suspect it has something to do with our government regulations and enforcement, but I am speculating. KTM USA says that the LC4 wheel will not work on the RFS. Not what they supply, that is. I will check on the 244 wheel. If I have to I will get one from over there. Thanks! Stu |
02-13-2007, 02:21 PM
#102 |
Pretty much...
Oddometer: 374
Stu -
Pat indicated he had a bunch of guys buying the EXC wheel for their 640 Adventures and none of those guys are having problems. Also, I had the gap you have now they I understand the problem fully. After 100 mi no gap. It fit really damn tight too. Now, no problem. I also used some alcohol upon assembly to lube things up a little hoping they'd slide together easier. Leesbian - I sold my stock rear wheel, sorry I don't have any part numbers. The bike is an '05 525 EXC. Cheers, Andy |
02-13-2007, 03:33 PM
#103 | |
Oddometer: 126
Wonder how much that'd cost to ship over here... will still get quote from local dealership.
02-13-2007, 04:36 PM
#104 |
Pretty much...
Oddometer: 374
Not sure, Pat has a 304 area code phone number though. Super cheap and a stand up guy. I can PM you his number. At any rate, that is what I paid. Remember the carrier and the six dampners. The "complete" wheel does not include that. The ol' bait and switch.
If you have a problem with shipping let me know. I've shipped untold amount of P-car parts back and forth across the pond. Andy |
02-14-2007, 05:08 AM
#105 | |
Oddometer: 126
Just to clarify - I need the complete rear wheel, the sprocket carrier, and 6 dampeners? Also, what size bags are your tank and rear bags? (small or large). Want to get those ordered today.
