02-17-2007, 07:38 PM
#121 | |
Oddometer: 1,258
02-17-2007, 08:03 PM
#122 |
Cheese and Rice!
Oddometer: 4,608
Yes, it is difficult to get the proper tension on the KTM. I pull my shock and run it through the full range of motion to ensure the proper tension.
Part of the issue is that I have an awesome z sprocket on the rear which is indestructable. It is probably hard on the chain. The other part is that I'm not 100% trusting this lube. I use the honda red can, which is well regarded, but this chain was trash when I was finished with it. It was like a noodle and had very worn rivet internals. |
02-17-2007, 08:59 PM
#123 | |
AKA -Evel Kneilson
Location: Liberal ShitHole, San Fran-sissyco, Kalee-Fornee-a
Oddometer: 314
Dude!
There is no way a 300 should be stretching a 520 chain.....try lots more slack
DaddyBigDaddy 1998 KTM 620 Adventure |
02-18-2007, 04:50 AM
#124 |
Oddometer: 6
got one !
hello girls ! well we will see what this ktm 525 is all about in the next 10 days, tomorrow morning ( 19 feb ) im leaving my home in thailand and going to cambodia first then laos,. ,the bike is an 05 525mxc ( fan and a bigger tank )and this will be my first ride on it, ive done this trip before but on an xr650 ,first thing i noticed is the weight ( lack of ) and that button on the bar that makes the engine go,, heaven ! ,.all in all ill do 3000 miles if all goes well ,spent the day today on maintenace ,you know, polish and stickers etc so should be fine ( gulp ) ,i ran the xr650 out of oil once and stretched the timing chain, so im a bit concerned by the ktms 1.2 litres ., bit concerned about the plank for a seat but i do tend to stand a lot, ,it will be 85 per cent dirt, ill give an honest opinion when ( if ) i return ,.ps how the hell do you add a pic to this ?
02-18-2007, 11:23 AM
#125 |
Oddometer: 8
Good luck with the trip and do post up when you return. I am contemplating taking my 450 SMR on some or possibly all of the Transamerican trail with the addition of a larger tank, fan and some 17" knobbies. I am curious to see how well everything holds up.
Cheers, Steve |
02-18-2007, 12:47 PM
#126 | ||||
Oddometer: 126
How many miles would you expect the chain to last? or just change it at the same time the rear sprocket gets changed? May have to mail a few chain and sprocket sets (hmm... and inners/repair kits too) ahead of me.... or leave instructions for them to be mailed at specific times. Quote:
'07 KTM 950 Super Enduro '04 KTM 525 MXC '00 Ducati 748 Biposto '89 Honda Camino (The Adventure Moped) |
02-18-2007, 12:53 PM
#127 | |
Oddometer: 126
Oh yes, the 525 is SO light. Lighter even than a DR350 or XR400... which is pretty cool I'll be very interested to hear how you find the bike for such a long journey. Hopefully if you find anything that really causes problems I'll be able to fix it on my bike before I do a similarly large journey at the end of March. I guess between the two of us, we should be able to prove whether or not these bikes can hold up to distances like that! BTW - STAND! that seat is a bitch. I rode my 525 back home (on the road) after I bought it. About a 3 hour journey - my arse was still hurting a week later!
02-18-2007, 01:38 PM
#128 |
I know a shortcut!
Oddometer: 9,481
PotatoHo- those Primary Drive chains are shit. I think once you upgrade to a nicer quality chain you will agree with me on that one.
I also switched to a steel 50 tooth rear sprocket. Those aluminum ones wear too damned fast for my taste. |
#129 |
I know a shortcut!
Oddometer: 9,481
This is a great thread...
02-18-2007, 05:55 PM
#130 | |
Cheese and Rice!
Oddometer: 4,608
If you want a long lasting rear steel sprocket, try the Sunnex (Sunstar) Z Sprocket. Weird circular saw looking thing. I've not worn one of them out yet. I got it from ktm-parts for $35. It comes with special bolts but no nuts. Have to use your old nuts. I use a moose front sprocket. |
02-18-2007, 06:00 PM
#131 |
Cheese and Rice!
Oddometer: 4,608
The seal on my 2003 EXC shock started leaking, so I bought a used 2004 SX shock with some race-tech mods (P20 spring, different bladder etc). This thing is pretty cool! Not sure about the mods, but the SX shock is trick because it has both a low speed and high speed compression setting. So you can set a nice and plush low speed compression which actually works great on the street, and then have the high speed compression set for the harder stuff.
02-18-2007, 07:01 PM
#132 |
Oddometer: 112
525 ADV - the real reason
This thread is great. I'm in the process of doing the homework to decide what my next direction will be. The real reason for some one like me to do a 525 ADV is that building the damn thing will be as fun if not more fun than actualy riding it. I'll be out of med school and working full time in orange county by the end of the summer and I'll FINALY have the money to do this stuff! But that 690 sure sounds tempting. Both mabey!?
02-19-2007, 04:47 AM
#133 |
Oddometer: 126
This thread also compliments what we're discussing here quite nicely http://www.advrider.com/forums/showthread.php?t=202555
A lot of it is still relevent.
02-19-2007, 05:33 AM
#134 | |
I know a shortcut!
Oddometer: 9,481
I'll have to check out that sprocket on the next go-round. Thanks for the tip. |
02-21-2007, 06:48 PM
#135 |
Buffo Maximus
Oddometer: 850
Rear Cush Hub & Wheel
OK--got the hot scoop on the rear wheel: get the LC4 wheel for an '02 thru '05. Get the matching backing plate. The part number ends in 144. The other two plates that end in 044 and 344 have the support bearing in the wrong location for our RFS needs.
Assemble with lots of silicon or soap on the rubbers. Put the tire (or rim) on a couple of 2x4 hunks of wood to protect the brake rotor. Then get on the sprocket and bounce up and down until the hub seats in the wheel. You will hear an audible "splork" as it goes together. It will then fit in the RFS swing arm with ease. It will not until you jump on it. This is the secret KTM tool to mounting this wheel. I have had great luck with the trackmaster chains. They last and are fairly inexpensive. I have my 525 geared 15/52 for all around riding. When I do technical off road I can put on a 14 and just flip the rear axle blocks to pull the wheel back and I am good to go. Stu |
