Old 12-27-2011, 03:07 PM   #4576
jon_l
jon_l's Avatar
Oddometer: 3,307
Originally Posted by DR BrianO View Post
I have a 1999 Suzuki DR 200,
What oil are you guys/gals running? I have heard that Mobil's V twin is a great motorcycle oil, but wanted some imput.
As long as you change the oil regularly, in your DR it doesn't make a lot of difference which JASO-MA rated oil you use. Just get something close to the viscosity Suzuki calls for in the owner's manual.
Automobile engine oil generally contains friction modifiers like molybdenum with can do bad things to a wet clutch. JASO-MA oil does not contain "Energy Saving" friction modifiers and is safe in your engine.
I use Shell Rotella T6 full synthetic 5W-40 heavy duty engine oil. Walmart sells for ~$20. I buy several jugs annually when I drive South from Ontario because it is much cheaper than Canada, plus there less sales tax in the US. Good stuff, thousands of motorcyclists swear by it. The 15W-40 Rotella (not synthetic) is fine too. I have used Rotella in singles, twins, and 4 cylinder bikes (and I hope to use it in a Triumph triple one day).
Both Rotella types mentioned above meet the JASO-MA standard.
Lots of oil talk here:
http://www.bobistheoilguy.com/forums...Board=9&page=1
More good stuff to read here:
http://motorcycleinfo.calsci.com/Oils1.html
CBF1000 & PCX150
jon_l is online now   Reply With Quote
Old 12-28-2011, 05:34 PM   #4577
Skopelos
Skopelos's Avatar
Oddometer: 26
Originally Posted by jon_l View Post
http://welcometobaltimorehon.com/the-hollywood-diner
check out the comments below the map
Thanks dude
Dont know about DR 200 but Suzuki suggests 10W-40 for Suzuki DR 250S. You should choose an oil with JASO - MA, API SE/SF specifications.
I use CASTROL ACT>EVO X-TRA 4T and change it every 3000-3500 km with an oil filter. I have also used Bel Ray and Motul products.
Since my motor is old (98500 km) and the summers in Greece very hot I will start using 15W - 50 oil in order to decrease oil burn.
hope I helped
PS. Checking the oil in a Suzuki DR 250 can be tricky, because the oil passes through the frame, does the same thing happen to DR 200?
Suzuki DR 250S '91 (98500 km and going!)
Honda Transalp 600 '92
http://dr250.blogspot.com/
http://suzukidr250s.123.st
Skopelos is offline   Reply With Quote
Old 12-28-2011, 05:51 PM   #4578
Trailrider200
Trailrider200's Avatar
Oddometer: 334
incorrect on two points.
1. moly is not one of the common friction modifiers used in auto oils that affects wet clutches.
2. moly is not bad for wet clutchs until at 700ppm at operating temp. over 500 ppm at operating temps is bad for the starter clutch.
Mobil1 m/c oils have moly in them about 100ppm as do other m/c oils per oil analysis listed at bobistheoilguy.com.
see SAE tech paper #961217
1981 CB900C, 1998 GL1500C Valkyrie
2007 DR200
"Our Constitution was made only for a Moral and Religious people. It is wholly inadequate to the goverment of any other."
John Adams 10/11/1798
"If we ever forget that we're one nation under God, then we will be a nation gone under" Ronald Reagan
Trailrider200 is online now   Reply With Quote
Old 12-29-2011, 06:12 AM   #4579
DR BrianO
DR BrianO's Avatar
Oddometer: 41
Oil, Thanks.
Thanks for the links, explained it all very well.
1999 Suzuki DR 200se (fixed and sold)
1985 Honda Spree (fixed and sold)
1960 Honda S90 (restored and sold)
DR BrianO is offline   Reply With Quote
Old 12-30-2011, 06:34 AM   #4580
Krasi
Oddometer: 18
Well, I'm still off work and outside it still is like that
so I continue with my nonsense creations.
I made my self a DYI chain oiler. I've been making such basically for all my bikes using gardening taps and urinary tubes - local pharmacists were always looking strange at me Now, I decided to go the route, suggested by this fella:
http://www.youtube.com/watch?v=7xg1bOcV3rI
The "tank" is actually brake fluid container from Lada (the most popular Russian car brand, for our distant readers):
The personal touch I threw in, comes in the form of a fuel cut-off valve, which is very widely used around here as part of car LPG conversion kits:
The "holder" role of the tube to the swingarm is performed by a shoe-polishing sponge box:
The container is on the right-hand side of the frame, while the valve and tap are bolted on the front of the air box:
Valve power supply I took from the positive pole of the rear brake switch, because it was most easily accessible, so now when I turn the ignition on, it opens up.
On a side stand, in the cold garage it works:
When the weather outside becomes more rideable I'll check it in real life conditions .
Krasi is offline   Reply With Quote
Old 01-08-2012, 08:47 PM   #4581
Rainier_runner
Epic Adventurer
Rainier_runner's Avatar
Oddometer: 307
My minimalist ride!
Loaded for day trips-
Mt. Rainier-
Mt. St. Helens-
Cold Water Lake-
My 1st and only weekend trip on my 250-
Somewhere in Capitol Forest-
2014 KTM 1190 Adventure R
2006 Suzuki DR 650 ADV
Rainier_runner is offline   Reply With Quote
Old 01-08-2012, 08:48 PM   #4582
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,648
Sweet!
Well, I ain't always right but I've never been wrong.
It seldom turns out the way it does in the song.
Old 01-08-2012, 09:38 PM   #4583
RAZR
yup ima hairstylist
RAZR's Avatar
Oddometer: 9,220
i had started a somewhat similar thread.
just thought some folks might find it useful as well.
http://www.advrider.com/forums/showthread.php?t=641622
"when there is no more room in hell, the dead will walk the earth"
YOUTUBE
SPOT
RAZR is offline   Reply With Quote
Old 01-09-2012, 04:54 AM   #4584
driller
Twist and Go
driller's Avatar
Oddometer: 1,326
Great Little Burro
Great pics of the PNW!
Those little KLR's do very nicely. I miss mine.
Now "Certified Scooter Trash"
2006 Yamaha Morphous, 2006 Fly 150 "BlowFly 200",2009 Buddy 125
driller is offline   Reply With Quote
Old 01-09-2012, 01:48 PM   #4585
Skopelos
Skopelos's Avatar
Oddometer: 26
Wink
I wrote the whole tour to Skyros Island with the DR 250S at the riding section of Advrider, have a look here:
http://advrider.com/forums/showthread.php?t=754924
Old 01-09-2012, 02:45 PM   #4586
Girlinagale
Girlinagale's Avatar
Oddometer: 36
Irish guy round the world on Sinnis Apache 125
There's an Irish guy posting vlogs on You Tube as he rides around the world on Chinese dual sport, Sinnis Apache. He is in Mongolia at present. It will be fascinating to see how the Sinnis Apache holds up. He seems to have began vlogging October 2011 and I cannot find any other website, or blog with details of the start of the trip. Quite a radical adventure on one of those untested Chinese thumpers. They are available on the road, brand new for 1800 in the UK. 100mpg, weigh only 107kg, Do 231 miles to a tank of petrol and look as pretty as the Honda XR125, but in orange.
I am in no way connected with Sinnis, I do not own a m/c, but in my research I couldn't help noticing this remarkable adventurer.
The You Tube link is: http://www.youtube.com/watch?v=Hywxo...c2H1VAbmuVku2Q
The ride, it's all about the vibe, You want to find the vibe? Slow down and there it is.
Girlinagale is offline   Reply With Quote
Old 01-09-2012, 10:23 PM   #4587
Spud Rider
Spud Rider's Avatar
Oddometer: 3,809
Thanks for providing the link to the video. I believe the Sinnis Apache is manufactured in China by Qingqi. Qingqi makes excellent motorcycles which employ copies of Suzuki engines. The Siniis Apache has an engine which is copied from the Suzuki GS125 motorcycle.
I have 42,000 miles on the odometer of my Zongshen 200GY-2 motorcycle, which employs a virtual copy of the engine in the currently produced Yamaha, TW200 motorcycle. If one wishes to learn more about the Sinnis Apache and other Chinese motorcycles, I welcome you to join us at the chinariders.com motorcycle forums.
http://chinariders.net/modules.php?n...wtopic&t=10077
http://chinariders.net/modules.php?n...wtopic&t=10075
Spud
Old 01-10-2012, 07:01 PM   #4588
1994klr250
1994klr250's Avatar
Oddometer: 693
Since there has been a few pictures of KLR250's over the last page or two I'll keep that going with the RR I'm currently writing over in ride reports.
Link to it: http://advrider.com/forums/showthread.php?t=754065
A glimpse of the trip.
2300 miles on a 250 all for a sticker http://www.advrider.com/forums/showthread.php?t=616239
Fall ride on a KLR250 http://www.advrider.com/forums/showthread.php?t=754065
1994 KLR250, 2009 F800GS, 2006 KLX351
1994klr250 is online now   Reply With Quote
Old 01-11-2012, 05:21 AM   #4589
wesdawg
wesdawg's Avatar
Oddometer: 168
Pics
Nice shots! get's me motivated to get the xt on an adventure!
wesdawg is offline   Reply With Quote
Old 01-11-2012, 08:37 AM   #4590
Hannda
Short, fat, bearded, slow
Hannda's Avatar
Oddometer: 28,202
Originally Posted by Krasi View Post
If it turns out that these sticking bolts get in the way, I'll swap them with rivets.
Rivets will still be a bit "catchy" and could cut/rip/tear what you put in there. If it were me, I'd cut down the bolts and use crown nuts. You'll get the strength you were looking for in a nut/bolt combination and retain the ability to remove whatever whenever that existed in your original plan. But now you'll have these smooth topped intrusions into your toolbox rather than something dangerous to your hands and your cargo. Just a thought.
Edit: Nice work.
Edit #2: If it in any way gets in the way of your left leg, I've seen these mounted from the rear underside of luggage racks with a pair of large hose clamps. Not much weight in them so it typically doesn't cause a problem with weight distribution.
Hannda screwed with this post 01-11-2012 at 08:50 AM
Hannda is offline   Reply With Quote
Times are GMT -7.   It's 05:28 PM.
