01-22-2013, 05:46 AM
#5956 | |
Brett
Oddometer: 4,720
I think there is some variability in the power figures posted.
I know the TU250 gets a LOT better after its broken in at around 3000 miles, and if you dyno a new bike, its going to show a low output. There is also the power curve, peak power vs broad power output, and the TU is very odd in that it has a lot of power (for a 250) starting at 4000 rpm building slowly to about 7600 rpm where it flattens out to the 8500 red line. What that means in the real world is good speed on the road wiithout high rpm's. Its also one engine you can do whatever you want with, without any concern about the engine. The engine runs smooth and cool, so you can scream the thing across the US and back without worry or discomfort. And even running at a low (for a 250) 5000 rpm you have no problems doing a real 70+ mph. Even running at 85 and 7500 rpm is nice and the bike feels like it will do it all day for months. Unlike some bikes, the TU seems to love heat, the hotter it is out, the better the motor seems to run. Its NOT a dual sport though, and it sucks in the rough dirt, the forks and 18 inch front wheel do not like rough stuff at all, plus, the way the engine is made to get a lot of mid range power makes it impossible to get much if any more power out of the bike. Airbox and exhaust mods seem to do nothing, but the FI system works very well, not feeling lean even if you do mods. For any off road use, its very risky, the brake and shifter stick WAY out past the motor, the gas tank is wider and tends to get dents, the headlight would break, levers snap off, etc. That big headlight is the best I ever had on any bike for night riding though. That is a shame, as the motor is great in the dirt, nice power curve, and the bike is fairly light. When I had my xt250, I do not think I could get the bike much over 70 mph under most situations, and it did not like real high rpm's a lot. It did not seem happy at higher speeds, but was one tough bike in the dirt. The XT250 motor sort of reminded me of the TW 200 motor, as not liking high rpms for long. Quote:
01-22-2013, 07:38 AM
#5957 |
Oddometer: 4,596
My son had a Super Sherpa, and after back to back riding both bikes (XT225), my impression was that the XT was lighter, and had much better brakes. Although the SS had discs front and rear, they just didn't do much. The rear brake actually seemed stronger than the front.
The SS had a nice digital speedo set up though. Other nice things about the SS were there were no weak rear spoke issues, and no starting issues, both of which the XT has in spades.
'01 Kawasaki W650 '05 Yamaha XT225 |
01-22-2013, 10:07 AM
#5958 | |
Dodgin' the Ditches
Oddometer: 1,159
The XT225's cold starting problems are easily cured by the "3 turns out" of the pilot jet screw that is common knowledge on the XT225 threads. Makes the bike very easy to start cold, and only needs about 15 seconds of choke, instead of the 5 minutes from the factory. It was an emmisions thing... |
01-22-2013, 11:51 AM
#5959 | |
Vintage Rider
Oddometer: 1,681
"I refuse to give up the thrill of living for the relative safety of existing" Nick Ienatsch "Life is not a race. Don't treat it as such. If you don't believe me, just have a look at the finish line" |
01-22-2013, 12:07 PM
#5960 |
Oddometer: 170
I'm in the market for a used Yamaha TW200 or XT225. Can't wait to try some minimal touring!
01-22-2013, 12:55 PM
#5961 |
Oddometer: 205
GW 250 Suzuki
Klay,
Looking at an earlier post I see you have seen the GW250. Your the first one I heard to view the GW. Is it the same as the GZ? I 'm aware of the changes but the bike it's self ,smaller or larger? and the seating position is it a little cramped as the GZ? Old style maybe ,but I still put a lot of miles on the GZ,as you on your DR 200. I overlook the bikes limits and enjoy the ride. I value your opinion. I hope to see one at the upcoming bike show. CMS [Terry]
09 DL 650 [Grey/Black] 09 TU 250X [Red] 08 GZ 250 [Grey] VSRI
01-22-2013, 01:15 PM
#5962 | |
plainsman
Oddometer: 89,128
The GW is completely different from a GZ. The seating position of the GW is more of a standard configuration, while the GZ is feet-forward cruiser-style. The motors are completely different...GW is a fuel-injected liquid-cooled parallel twin, and the GZ is a carbureted air-cooled single. The GW has a bigger frame and doesn't feel small like a GZ does. I didn't like the seat on the GW, though...I could tell it would be cramped with my riding suit on. I'm back to looking at the TU250...I may buy one next spring.
_______ |
01-22-2013, 05:37 PM
#5963 | |
Oddometer: 999
01-22-2013, 05:43 PM
#5964 | |
Oddometer: 117
08 Honda CRF230L (The wife's ride), 2010 Yamaha WR250R, 2011 HD FLHX Streetglide |
#5965 |
plainsman
Oddometer: 89,128
I'm hanging on to all my DR bikes...200, 350, 650.
_______ |
01-22-2013, 05:49 PM
#5966 | |
Oddometer: 999
01-22-2013, 06:56 PM
#5967 |
Oddometer: 409
I've put 8500 miles on an XT250 in the past two summers. Some of that was highway cruising unfortunately. Thought I'd chime in about what it is and is not capable of on the highway.
Flat ground cruising along with no head wind I put the speedo between 65-70 and go for hours. The speedo is off 10% so that's an actual speed of 60 or a little more. Fine for deserted 2-lane blacktops. If there is any traffic you'll be getting passed or pulling off and looking at your map for an alternate. I plan my trips for dirt roads and smaller highways that I know don't have traffic. On the mountain passes, or with a headwind, I downshift to 4th and put the speedo on 55, which is 50 actual. I've ridden like that for hours and the motor seems to just purr along, altho it will use some oil doing that. Not sure what the revs are in that situation but it's surely more than cruising in 5th gear at 60mph. In 4th gear I have looked down and found myself over 60 so it's not at redline yet. I would guess 7k. I can't get it over about 75 indicated on flat ground. On a downhill I can get it to about 82-83 indicated. Most of the time I'm cruising forest roads in 3rd or 4th gear so it works for me just fine. This is all with about 200 lbs of rider/gear and 50 lbs strapped on the back. Most of my riding is at high elev so I'm down on power a little. It's a fun bike but not for people who are in a hurry. -al |
01-22-2013, 07:55 PM
#5968 |
Oddometer: 350
Excellent pictures! I'd love to see that klx250 on a trip to Prudhoe Bay. I rode to Prudhoe bay this past summer on my F800GS. If I would of had the time I would of taken my klr250. Its great seeing little bikes on long trips. How did the klx250 do at altitude? Any starting or running issues?
http://www.advrider.com/forums/showthread.php?t=467256 http://www.advrider.com/forums/showthread.php?t=588296 2300 miles on a 250 all for a sticker http://www.advrider.com/forums/showthread.php?t=616239 http://www.advrider.com/forums/showthread.php?t=754065 |
01-22-2013, 08:40 PM
#5969 | |
Brett
Oddometer: 4,720
Not sure why, but the TU with the same power, or less, will do 85 mph (actual) on the interstate in traffic.
I have done 50 miles at a time at that speed quite a few times. The cars set up a big draft which pulls me along, and maybe tires come into play, you have to loose some speed with dual sport tires. No traffic, no wind, 80 mph is likely tops, but the motor and the bike is very happy there, no oil use, no noise, low oil temps. So the XT and TU sound close, with the TU having street tires, being lower (less wind drag?). As far as the TW200 goes, it made noises at higher rpm's letting me know it was not happy. It does not hold much oil, runs hot (not a plated bore), and an aftermarket oil cooler is a popular mod for people that run them hard. Short bursts were fine, say in the dirt, but on the street I would get what sounded like ignition knock, and I had increased the main jet a step and shimmed the needle. Quote:
01-22-2013, 08:49 PM
#5970 | |
lucky dog
Oddometer: 254
I switched the main from 120 to 115 and dropped the needle a notch. Even so, it got breathless/powerless at 12,500', but so did I. Always started easily though. .
KLX250S.TE630.GL1800.CBR900RRturbo.919 DYNOBOB screwed with this post 01-22-2013 at 08:54 PM |
