Old 03-29-2013, 09:20 AM   #6226
Spud Rider
Spud Rider's Avatar
Oddometer: 3,814
Originally Posted by Slipinn View Post
I have been looking as well. Seems my local dealers here don't have a single dual sport in stock at any of the dealers in this area. I have a 96 xr250l but would like something that does not have to strain so much at interstate speeds. It seems you need a 400cc to do that. The wr is the highest priced in a 250 with more power so in the 250's I think the klx is the best buy so far and might be a little faster on the top than my xr but am betting holding it at 75 for anytime is a strain and near wot.
The DRZ 400s is big jump in price and getting into the price area of a DR or xr650. I am trying to stay light in weight to around 300 to 350 max and closer to 300 or less yet still be able to sustain 75mph if needed with a strong enough frame for touring gear without dealing with rear subframe breaks or cracks.
If the new 250 to 400cc bike I am looking at is bordering 6500 bucks then I am reluctant to spend that kind of cash on it when I could be buying a 650 dr or xr for the same amount.
Check out the new Honda CRF250L.
http://www.advrider.com/forums/showt...5#post21059735
Spud
Old 03-29-2013, 09:48 AM   #6227
Earthscape
Have ya got a helmut?
Earthscape's Avatar
Oddometer: 352
Engine size alone won't guarantee a better high-speed ride, or less strain doing so. The DRZ is actually a good example, because it has a very close ratio 5 speed transmission. So you either gear it for high speed, or you gear it for low speed, but not both. Most of the newer 250s have significantly wider ratio 6 speed transmissions, covering a wider variation of speed - able to go slow in tight terrain but still be geared high for faster travel. It is very difficult to find a bike that is perfect for what anyone in particular wants/needs. If you want to keep it light but need more power and easier cruising, there are options for big bore kits on some of the modern 250s.
Have a browse in this thread http://advrider.com/forums/showthread.php?t=281742
"You do your own thing in your own time, you should be proud."
2004 KTM 950 ADV : : : : : : : 1998 Triumph Tiger
1999 KTM 640 ADV : : : : : : : 1993 Kawasaki KLX650
2007 Kawasaki KLX350S : : : : 1996 Yamaha XT350
Earthscape is offline   Reply With Quote
Old 03-29-2013, 10:16 AM   #6228
Nanabijou
Nanabijou's Avatar
Oddometer: 779
Went for a ride yesterday on my 2011 CBR150R. First ride with the Thai CBR150R engine in my 2011 CBR125R chassis. I'd been waiting since October 2012 to take this thing out. The temp display on my car said 8C. Good enough for me.
Headed out on my usual run along Lakeshore Drive out to Wild Goose Beach. The bike felt great. Noticeably more power across the rev range compared to the CBR125R. And the sound is more throaty than its little brother too. It sounds great. With the 150R, you had better like the sound of a small displacement 4-valve single at high rpm - because that's where the tach will be sitting most of the time. Good thing it's relatively smooth when you wind it out. The road into Wild Goose was snow covered in places. But at around 300lbs wet, the bike is reasonably lightweight and easy to handle - apparently even through snow and ice.
You can see the remnants of our recent winter tale here. The snow is now melting fast (finally), but we got dumped on several times toward the end of the season.
It certainly doesn't look like good riding weather. But at no time was I ever cold. After a couple of hours - I was still cozy in my gear. The photo below is the beach parking lot.
And here is the Sleeping Giant and umm....the beach. You can see a section of an ice-racing track to the left.
I like comparing the same photo at different times of year. The contrast of seasons is pretty remarkable. The photo below was taken in July 2012. If you look closely, you can see people swimming in the cool waters of Lake Superior below. Hard to image this scene from the photo above.
Here's a closer look at the Giant. If you are wondering whether the Giant has somehow been decapitated, check out the other photos below that better capture the Giant in full glory.
From there I continued along Lakeshore and then took the Trans-Canada back to Thunder Bay so I could test the highway capability of the 150R. Overall - it did fine. However, I was facing a pretty severe headwind and found myself frequently dropping it from 6th (7800 rpm @ 100km/hr) to 5th (9000 rpm @100km/hr) in order to continue riding at my 100km/hr (GPS) goal. After taking some time to peruse the useful online Gearing Commander site, I think I might go with one less tooth on the countershaft sprocket. This would put me at 8400 rpm in 6th @ 100km/hr - right near the bike's torque peak at 8500 rpm. My older 2009 125R with this 150R engine ran similar lower gearing, and I think I like the extra jump the lower gearing gives me in the city, and I'm more satisfied with the way it works on the highway too. I also stopped at the Terry Fox Lookout too for a quick break and a few more photos.
Here is a plaque that describes Terry's "Marathon of Hope" journey.
Here is another gratuitous shot of the 150R (the wolf) in 125R (sheep's)clothing...
From there I visited the Bluffs overlooking the Current River for yet another view of the Giant. I didn't expect to see so many others enjoying the views and milder temps.....while pensively sucking back on some thinly rolled, sweet smelling...ummm... cigarettes.
I thought I'd stop by Hillcrest Park as well to take yet another shot of the Sleeping Giant. On the way there while waiting at a stop, a young guy drove by in a pickup and with the window rolled down yelled what sounded like "Nice Mike!" but I think it was "Nice bike!" Either way - I think the colours look pretty striking.
Here is another contrasting shot taken in June from a similar spot. You can barely see the outline of the Giant in the background.
I took one more photo before heading toward Oliver Road and onto the expressway. I wanted to stretch the 150Rs legs a bit.
Mike
Nanabijou screwed with this post 03-29-2013 at 11:29 AM
Nanabijou is offline   Reply With Quote
Old 03-29-2013, 05:15 PM   #6229
2whlrider
2whlrider's Avatar
Oddometer: 983
T'Bay photo's
Great pics Mike. Looks like it was a nice day to get out.
On two wheels....That's my Happy Place!
2whlrider is offline   Reply With Quote
Old 03-29-2013, 08:41 PM   #6230
Rhompin45
Rhompin45
Oddometer: 251
I can't imagine riding in snow I don't even like driving in snow I have been in Arizona my whole life and it doesn't snow where I live. But I really am courious about that cbr150/ 125 before and after engine swap what is/ was the top speed. I started riding on a Chinese scooter 150 with a cvt it went about 55 on a good day. My gf is interested in riding but just wants something to cruse around town. I was looking at the old xl185 but there kinda hard to come by. I'm not sure that it would be any easier finding the cbr125 around here but I like the looks of it.
Rhompin45 is offline   Reply With Quote
Old 03-29-2013, 09:18 PM   #6231
Nanabijou
Nanabijou's Avatar
Oddometer: 779
A good friend of mine got his license on an 1980 XL185 when we were 16. He's been through many bikes since - but the 185 is the only bike he wishes he still had.
The top speed on the CBR150R varies - based on wind. I have a speedohealer attached to the bike, so the speedo displays accurately. The top speed is around 84 mph - in a tuck. Sitting up, with no headwind - by yourself on the highway - the top speed is around 75 mph. Riding on an expressway with other traffic creating favourable turbulence - around 80 mph.
Mike
Old 03-29-2013, 09:20 PM   #6232
Nanabijou
Nanabijou's Avatar
Oddometer: 779
Yeah - wanted to take advantage of the nice weather. It felt so good to be out riding again. Has the Winnipeg weather been favourable enough to do some riding?
Mike
Old 03-30-2013, 12:55 AM   #6233
2whlrider
2whlrider's Avatar
Oddometer: 983
Mike
Some of the local ADVers have been out but not me. Still doing a bunch of maintenance on the bike. Too much salty water for my liking anyway.
Soon I hope. You going to the Icebreaker?
Old 03-30-2013, 02:02 AM   #6234
EvilClown
Reality show stunt double
EvilClown's Avatar
Oddometer: 16,773
Originally Posted by SAPB View Post
What's the best/least expensive lift/stand for home wheel removal, ect?
Don't know about best/least expensive but I have one of these and it's pretty handy for the smaller bikes.
As sketchy as it looks up in the air it is actually pretty solid. YMMV. Gets the bike up to a nice height if you need/want it up there.
Click interweb pic for link.
These are our Golden Years. ~ EC
The future is no place to place your better days. ~ DMB
The world is a book and those who do not travel read only one page.
~Augustine of Hippo
EvilClown is offline   Reply With Quote
Old 03-30-2013, 05:34 AM   #6235
SAPB
SAPB's Avatar
Oddometer: 1,622
Thanks for the input, but I went with the Tusk, from Rocky Mountain ATV, $59.99 + $7 shipping.
http://www.rockymountainatvmc.com/p/...ble-Lift-Stand
C14 - CRF250L, always cleaned while it's raining
CRF250L Service Manual http://www.hondampe.com.au/docs/owni...F250L13_OM.pdf
SAPB is offline   Reply With Quote
Old 03-30-2013, 06:50 AM   #6236
Leo.G
Is still learning
Leo.G's Avatar
Oddometer: 399
Using that kind of elevators is worth when you have a repair shop or something similar..
Just for lubing the chain, taking the rear wheel off or things like that, I just use a car jack or a piece of wood/stick... (I think you know the technique )
2010 Honda XR 250 Tornado
Leo.G is offline   Reply With Quote
Old 03-30-2013, 07:13 AM   #6237
Nanabijou
Nanabijou's Avatar
Oddometer: 779
It's supposed to be 10C here today (even though right now it is raining and snowing). I hope to wash all the salt and mud off later on in the day.
I'm planning on attending the icebreaker. Not sure which bike to bring. Might be bringing the CBR150R. You're going to be there right? If I bring the WR250R - you can take it for a spin like I promised at our last icebreaker!
Mike
Old 03-30-2013, 07:44 AM   #6238
2whlrider
2whlrider's Avatar
Oddometer: 983
Mike
Yep I'll be there along with other Manitoban's. A ride on your WR would be awesome.
Old 03-30-2013, 10:26 AM   #6239
Spud Rider
Spud Rider's Avatar
Oddometer: 3,814
J.C. Whitney is once again selling travel trunks! They are now called Garage Pro Travel Trunks. The large travel trunk is on sale for $44.95, with free delivery, if you order before Tuesday! In addition, you can get another 10 percent off the price by using the promo code "zoom10."
http://www.jcwhitney.com/garage-pro-...58683y1989u0j1
My J.C. Whitney Travel Trunk has taken a lot of abuse for several years. I like it so much, I bought a spare when they were on sale for $48, delivered. At a price of $40.46, delivered, this travel trunk is an exceptional bargain!
These travel trunks come supplied with a very strong, metal mounting plate. The plastic mounting plates on some other trunks will fail.
You can pack a lot of stuff in the large travel trunks, and they are very easy to remove for the evening, or for hiding in the brush while taking an impromptu, off road excursion.
These travel trunks are very handy when taking a multi-day trip.
These travel trunks are also quite handy for grocery shopping, or running other errands around town.
Spud
Old 03-30-2013, 12:23 PM   #6240
SAPB
SAPB's Avatar
Oddometer: 1,622
Spud
Just got one, hope it's not the last one, thanks, Spud.
Times are GMT -7.   It's 07:50 AM.
