Old 08-20-2007, 02:53 PM   #766
rjmorel
Dual Sporticus
Oddometer: 310
DR200 shifting hard to find neutral
I have an 03 DR200 that is very hard to find neutral when at a stoplight waiting for the light to change. Those of you who have DR200's is yours acting like this or does it go into neutral easily like my DR650? Any ideas as to why it is hard to get into neutral ? I have to push hard on the shifter to get it to move that I go past neutral and into 1st or 2nd depending on which way I'm pushing the shift lever. Just changed the engine oil but it has acted this way from the beginning and has about 2300 miles on it now. Shifts fine going through the gears but is very annoying when I have a long stop light and I want to kick it in neutral . Thanks, Rob in Walla Walla, WA
rjmorel is offline   Reply With Quote
Old 08-20-2007, 03:55 PM   #767
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,605
Sounds like the clutch may be dragging. First make sure there isn't excessive play in the clutch cable. There should be about 3 mm of play at the clutch lever. It's real easy to slip my DR200 into neutral.
Old 08-20-2007, 07:14 PM   #768
green hell
yawning or snarling
green hell's Avatar
Oddometer: 19,961
i had a similar problem and klay's advice was spot on.
tighten up the play in the clutch lever and life will improve dramatically.
( klay)
lookin' for a place to happen;
makin' stops along the way - the tragically hip
needless dickery
green hell is offline   Reply With Quote
Old 08-20-2007, 09:26 PM   #769
IDScarecrow
IDScarecrow's Avatar
Oddometer: 1,349
Originally Posted by steve gs
Just in time in the BMWMOA Owners News was an article on the product offerred by Innovative Balancing (www.dynabeads.com) for balancing wheels/tires. What this amounts to is the insertion of approx 1 oz of ceramic beads (for my application) into the tube through the valve stem.
Since the application I have put 200 miles on the tires the bike is much smoother. The front end is perfect but I may add another 1/8 oz to the rear. The tire noise is gone. This method may be an ideal solution for those of us using aggressive d/s tires on hardpack or surfaced roads at speeds exceeding 35mph, check it out.
I really like the sound of this, but the linked website only talks about streetbikes. Are these "approved" for dual-sports? I have a TTR250 that I have been struggling to get balanced, but my riding is 80% off road - do you know if these will work in this situation?
"Pain is inevitable. Suffering is optional."
IDScarecrow is offline   Reply With Quote
Old 08-21-2007, 03:40 AM   #770
steve gs
steve gs's Avatar
Oddometer: 375
Somewhere within the site is a bit of info on d/s machines. Either from the BMWMOA article/IB website is mentioned that the beads become effective at about 35 mph. For trail riding they won't do a thing for you but if you have to travel roadways at 35mph or greater to get there they will.
As you might have noted they will also maintain balance as the tire wears and it's balance point changes with the wear. I think this would be especially significant with the more aggressive d/s tires as the knobs wear. Per IB's info the retention of this perfect balance will give maximum tire life.
Also mentioned was that tube type tires present a perfect environment for the beads.
steve gs is offline   Reply With Quote
Old 08-21-2007, 06:02 AM   #771
CMS
CMS's Avatar
Oddometer: 282
Van/bikes information
[quote=steve gs]Somewhere within the site is a bit of info on d/s machines. Either from the BMWMOA article/IB website is mentioned that the beads become effective at about 35 mph. For trail riding they won't do a thing for you but if you have to travel roadways at 35mph or greater to get there they will.
Also mentioned was that tube type tires present a perfect environment for the beads. Thanks for the input ,I too agree on the Ninja 250 ,most ride Bikes for image only,I still get a kick out of the ride, especially on the smaller cc's. The Suzuki and Nina sites are full of long range trips on 250's . They are planned and attended by a good following, so I guess were not alone in this thought process. Both you and Clay live in the North ,I think the multiple bike Syndrome must be associated with the cold weather, my wife stated we weren't moving any futher North than we are now[Southern Ohio] and has limited me to three bikes max. Thanks again for the info,and keep your articles coming I really look forward to the postings. ////Cms
DL 650,TU250X,GW250
VSRI, FSSNOC
CMS is offline   Reply With Quote
Old 08-21-2007, 09:19 AM   #772
rjmorel
Dual Sporticus
Oddometer: 310
Well , I tightened up the cable and it worked like a champ. Thanks, Guys, This forum is an immense help and all within 24 hours problem fixed, Rob
Old 08-21-2007, 12:29 PM   #773
jgas
Stoogely Adventurerer
jgas's Avatar
Oddometer: 843
Cheap redneck McGuyver tip.
After a buddy called at the last minute to tell me they were going riding, I had to think outside the box a little. My beater XR 250 had a flat, and my KTM was down. I had no tube, so I had to improvise. I took a kids floatie toy, called a "noodle", styrofoam, wiggly, bright orange, you know what I'm talkin about. Wrapped it heavily with duct tape, and stuffed inside the tire like a Bib Mousse.
It actually was pretty good for about 25-30 miles, then it started breaking down. By mile 50, it was almost like riding on a flat, but at least I got to ride. It might have lasted longer but the area we rode in was the rockiest in the state.
I would'nt admit this on just any thread, you minimiist guys might be able to relate. I got laughed at by my buds, but it beat sitting on the couch all day.
jgas. " Most of the singletrack is gone. Forever"?
-Graduate of the "Rock on the side of the Trail as a Hammer" school of motorcycle repair.
"No matter where you go, there I was".
-DRZ 400, GasGas 275, Klein, zero cc.
jgas is offline   Reply With Quote
Old 08-21-2007, 12:34 PM   #774
hppyfngy
not dead yet
hppyfngy's Avatar
Oddometer: 4,143
Now that's inventive...
Some say I'm apathetic, but I don't care. - Randy
'13 KLR 650 For Sale!
'07 KLX250s
hppyfngy is offline   Reply With Quote
Old 08-22-2007, 06:23 AM   #775
DualSportRider
Oddometer: 37
Now That is using your noodle! Good Idea LOL!
DualSportRider is offline   Reply With Quote
Old 08-22-2007, 07:56 AM   #776
Kaler
Oddometer: 44
gotta luv the MT bikes
That's using your noodle, jgas!
My minimalist mount, an XT225, is so easy to work on it reminds me of the old VW Bug ... tinker-friendly, fixable, lovable.
Kaler
Kaler is offline   Reply With Quote
Old 08-22-2007, 08:08 AM   #777
hockeygoon
Oddometer: 542
Kaler
I've been following this thread for a while, found this comment interesting. Despite it being the most low-tech car I have ever owned, I had a lot of fun in my old Bug. Maybe it was because I was a teenager and it was all I could afford at the time. Don't miss those heater-boxes in the winter though.
Despite being a XXL mega-primate type rider, I find a the idea of a small bike appealing. I might have to go with a ninja 250 or perhaps the taller klx250s as the others would be more clown-like with me on them I think.
hockeygoon is offline   Reply With Quote
Old 08-22-2007, 08:10 AM   #778
Kaler
Oddometer: 44
I'll be heading out for the JBR in just over 2wks and would prefer to take the 200 over the 650. Both bikes are prepared for a last minute decision. BUT I'll probably opt for the 650 only because I can compress the 2500 mi trip so I can spend several days exploring instead of being on the road from beginning to end of the 2wk period. With the 650 I can do higher mileage days in areas where I need to just burn the miles. Once I clear the traffic zones I settle ino a 45mph cruise with the 650 as I would the 200. Next year I will be on a new to me DR250SE which I will prepare this winter and expect to be a near perfect compromise for me.
I have just come up with a terrific spare fuel can system (IMO) which fits to my panniers. If it wasn't raining I would shoot and post a pic or two. Will try tomorrow. With two spare 1.125 gallon containers (one on each pannier) the range of the 200 is extended to 500 miles and my F650GSD to about 330. Needed to add fuel capacity because the JBR has a 225 mile gap where there are no services.
Steve,
Sure hope you take the 200 ... otherwise the ride report (which I look forward to reading) won't be on this MT thread.
BTW, have you got a pic of your spare fuel can system yet?
What's your departure date for the JBR?
Questions, questions ...
Kaler
Old 08-22-2007, 08:15 AM   #779
Kaler
Oddometer: 44
Ah yes, those cleverly designed heater boxes ... cough, cough ...
They worked great as long as they weren't sucking in exhaust fumes and then pumping them into the car's cabin -- which of course ... cough, cough, ... they always were.
Nice coughing -- er, talking -- to ya.
Kaler
Old 08-22-2007, 12:34 PM   #780
jgas
jgas's Avatar
Oddometer: 843
Speaking of bad heaters, I had a 1970 Toyota Landcruiser. It had a leaky soft top with plenty of duct tape holding it together, and just a little heater box in the back with hoses running to it from the radiator. Basically it was a pretty good hand/foot warmer, not much else. I had a van too, but it broke down and I had to go to Guard drill, about 50 miles away, on a zero degree morning in the 'Cruiser. I put on all my cold weather gear, and still froze my ass off. It was so cold that weekend, they let me sleep in the drill hall so I would'nt have to drive home that Sat. nite. I got so cold headed home on Sunday, I pulled off at an abandoned rest stop off the Interstate, and built a fire to warm up before going on. I literally could'nt drive anymore, my leg was shaking so much, I could'nt push the gas pedal.
Since ya'll seemed to like the noodle-tube thing, I'll admit to another one. A few years ago, I just barely had the $ to buy gas to go ride, but not enough to buy brake pads. I took some old Subaru disc brake pads that had just the right thickness of material left, and I took my Sawzall and cut the pad off flush with the backing plate. I traced them with my bike brake pads, and cut and ground them to the right size/shape for my bike. Then I used JB Quick Weld, and epoxied them to the backing plates of my bike brake pads, clamping them overnight with Vise Grips. I kinda thought they would come off under hard braking. but they lasted quite a while. They didn't have the same grab as real bike pads, you had to really press hard on the rear brake, but they worked.
A buddy of mine kept bending the rear disc on his XR. He got tired of spending 100$ every 6 months, so he went to a tractor salvage yard and found a huge 4 ft diameter disc off of a John Deere skidder, bought it for whatever the cost of steel was a lb, think he said 40 bucks. It was just a little thicker than a bike disc, but close enough. He cut the center out of it with a torch, and ground it down to the size of the bike disc, and cut out the center for the hole in the hub with the torch, then ground it to shape with a die grinder. He used the bike disc as a template to mark and cut the center and bolt holes. Took him all day to make the damn thing, and it's ugly as hell, but he raced A vet class in GNCCs with that disc for 3 years, rode it another couple years, gave it to his teenage kid, who abused the crap out of it. I bought it from his kid, and still ride it. That disc is so hard, it has dings on the leading edge from hitting rocks, but it won't bend. You can hit a rock with the disc that'll throw the whole bike up in the air, and it won't bend. You don't even need a disc guard. I wish I knew where to buy steel like that. He said it was so hard to grind, he had to go to the hardware store and buy several grinding stones for the die grinder. It took several to grind it down.
jgas screwed with this post 08-22-2007 at 12:53 PM
Times are GMT -7.   It's 07:17 PM.
