Old 02-13-2007, 08:05 AM   #31
Rapid Dog OP
bikes, booze, broads...
Rapid Dog's Avatar
Oddometer: 8,327
floats
I'm not so sure these float levels are correct...input here...
Rapid Dog screwed with this post 12-16-2010 at 06:51 AM
Rapid Dog is offline   Reply With Quote
Old 02-13-2007, 08:14 AM   #32
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 8,327
choke
....there is alot of residue both black-ish and some corrosive white stuff...I''m wondering if the bike had saltwater in the carbs, the bottom area of the choke valve has some pitting at the bottom of the chamber...
Old 02-13-2007, 08:15 AM   #33
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 8,327
needles
the needles are set at the second notch from the bottom...
The main jet is a #45.
Old 02-13-2007, 08:28 AM   #34
wintonio
last of the Dum Dum Daze
wintonio's Avatar
Oddometer: 1,650
if you would do me a favor, please take a pic of this same left side choke body housing, but with the choke body properly oriented in it. I am not sure if I put mine in upside down or not, but I am learning, almost the hard way, that I need to start taking notes, either written or photographic, and quit relying on my faulty memory... the dumbass in me strikes again (coincidentally, I am at the part in The Art Of Motorcycle Maintenance when he is discussing ways to prevent some of the "gumption" busters)
wintonio screwed with this post 02-13-2007 at 08:33 AM
wintonio is online now   Reply With Quote
Old 02-13-2007, 08:33 AM   #35
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 8,327
...i am at your service sir ....
will this help, oh, incidently, I have a day job...
Old 02-13-2007, 09:11 AM   #36
lkchris
Albuquerque
lkchris's Avatar
Oddometer: 863
Originally Posted by SOLO LOBO
Absoutely toss the foam filter and return to the stock paper... when running that, I think it is fair to assume that the stock jetting would not be correct, and perhaps not close.
This is "general knowledge" NOT APPLICABLE to engines with constant velocity carbs with have AUTOMATICALLY ADJUSTABLE jetting via a tapered needle.
The part about using OE filter is right on, of course.
Kent Christensen
Albuquerque
'12 R1200RT, '02 R1100S, '84 R80G/S
lkchris is offline   Reply With Quote
Old 02-13-2007, 09:15 AM   #37
wintonio
wintonio's Avatar
Oddometer: 1,650
as usual, my requests are not as specific as they should be. What I was really requesting was the inside view, not that you would know what question was in my head and not specifically stated.
I thought, maybe, I was the only guy here with a day job, and that the rest of you were members of the "lucky sperm club"
Old 02-13-2007, 09:32 AM   #38
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 8,327
sir winton
sir winton, ya'll need to go fishin'...
Old 02-13-2007, 11:07 AM   #39
SOLO LOBO
airhead or nothing
SOLO LOBO's Avatar
Oddometer: 7,976
Interesting point, I do know a few who would disagree and need to think about this for a bit but I do not think this is correct, anyone else?
"punkrocks what it's all about" - J. Strummer
SOLO LOBO is offline   Reply With Quote
Old 02-13-2007, 11:37 AM   #40
Suppermotodd
Tag Thief
Suppermotodd's Avatar
Oddometer: 1,018
Turn the carb over
The carb must be upside down to measure the float height.
Man I'm broke as a stick! NoPC-Lance
http://www.motocompound.com
Suppermotodd is offline   Reply With Quote
Old 02-13-2007, 11:47 AM   #41
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 8,327
mm'S
and that height should be...(waiting for other shoe to drop...)
Old 02-13-2007, 12:01 PM   #42
RandyB
Oddometer: 5,072
IIRC, the needle adjusts the mixture in a ratio determined by slide height. That barely makes sense to me.
Leave the needle setting alone for now. I think new needles are about $7 each. While you're in there (TM)....
If it keeps stumbling, you're probably going to have to go to 145, 2.68 idle and I forget main jet size. Bing will happily fix it for $76. Trust me.
RandyB is offline   Reply With Quote
Old 02-13-2007, 12:59 PM   #43
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 8,327
a 145? 145 which?
2.68 idle jet?
Old 02-13-2007, 01:12 PM   #44
Suppermotodd
Tag Thief
Oddometer: 1,018
Factory Manual
Height is not listed in factory manual that I can find. I turned mine over and measured both carbs. If they are not the same you have a problem. The last bike I had a problem with had one side that was flooding because the floats were heavy and sinking. Weigh both of them and make sure they are the same. If you find a varience I would replace both of them. Here is the assembly pages.
Suppermotodd screwed with this post 02-13-2007 at 01:19 PM
Old 02-13-2007, 01:17 PM   #45
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 8,327
heck, these are way harder to get the float pins out of than my /7...matter of fact I can't seem to get them out atall....
Times are GMT -7.   It's 06:16 PM.
