02-20-2007, 08:31 AM
#76 | ||
airhead or nothing
Oddometer: 7,934
Can I say I told you do (just kidding)
"punkrocks what it's all about" - J. Strummer Quote:
02-20-2007, 08:46 AM
#77 |
bikes, booze, broads...
Oddometer: 8,308
nowidall
...why yes, yes you can...
'08 R1200R / '10 WR290X/R '81 R100RS Rattlecandy Red '06 950 ADV Orangeboom '05 R12GS Wedding Bike '91 R100GSPD Derelict |
02-20-2007, 10:42 AM
#78 |
Oddometer: 476
I found this article about hard starting, which relates to choke springs and thought I would add it here:
http://www.airheads.org/content/view/233/98/ It goes a little like this: I have an R75/7 that, when absolutely cold, is a real pain to start.I had an R75/5 that also was a pain to start, La Vaca Guma, the "Mexico Bike." After doing all that you have recounted, most several times, over several years, I noticed that the slide was sticking and not coming all the way down (this totally defeats the choke action). Tried cleaning slide and carb body with a bit of fine sandpaper: didn't make much difference. Then I wondered: "Is this why they started putting the fine, fairly weak return spring in the R80/7s and R100/7s in 1978? The one that gently forces the diaphragm/slide assembly down? Will it fit in an earlier carb?" Well, folks, they do and the damn-hard-to-start-in-the-cold feature disappeared. No more push starting a fully loaded /5 down Mexican streets and alleys! Part # 13 11 1 335 324 if you want to give it a try.... |
02-20-2007, 06:48 PM
#79 |
Oddometer: 8,308
thanks for that.
i ordered new springs today...
02-20-2007, 07:08 PM
#80 | |
Oddometer: 674
Forgot
02-21-2007, 07:50 PM
#81 |
Don't buy from Brad
Oddometer: 7,403
So i took a peek inside the carbs tonight to decide if they needed major repairs.
All i did was drain the float bowls when i pulled them off the bike a couple weeks ago. I'm glad they're so clean. Bout time I had an easy one. Looks like being a daily driver had some advantages. My main jet is #145 FYI, it's written right on the face of the brass hex head in the center of the carb in the top picture. My springs don't look so good, but a little grease and they'll do. ![]()
On tap:Nada Aging: 3 experiments in mead - blackberry, apple, and straight honey |
02-21-2007, 08:00 PM
#82 | |
airhead or nothing
Oddometer: 7,934
Unscrew the main jet, pull it out and also the needle jet. crud collects around the innards.... found about a teaspoon of crap in mine, and they looked about as clean as yours!
02-21-2007, 08:03 PM
#83 | |
Don't buy from Brad
Oddometer: 7,403
THanks much.
02-21-2007, 09:02 PM
#84 |
Oddometer: 5,072
Clean the idle jet and mixture screws as well. New orings with a dab of silicone grease. Check the needles for grooves. Chemtool B12 rules.
02-22-2007, 07:58 AM
#85 |
Oddometer: 8,308
wow
...man, they look factory fresh! yeah, just some clearance of the passages should do. I don't think you even need the kits my man!
02-22-2007, 08:02 AM
#86 | |
Don't buy from Brad
Oddometer: 7,403
Even if I don't need to replace the #1 kit, i'll keep it as a spare. I'll need it sooner or later. What really sucks is how much they want for their diaphrams. $26.51 each!!!! He didn't even choke when he said it over the phone. Pass on those for now. I'll come back when I need them. By then they'll cost at least $50 probably.
02-22-2007, 08:15 AM
#87 |
Oddometer: 8,308
done
...I'll get it out ASAP...that said, I got my diaphrams form Chicago BMW...they discount all BMW parts, about $16-$18 a piece...order early, they may take some time to get to ya...
02-22-2007, 08:33 AM
#88 |
Don't buy from Brad
Oddometer: 7,403
damn... why are we shopping at bing then?
02-22-2007, 08:47 AM
#89 |
Oddometer: 8,308
Yep
...well. let's call it advice from ADVRider....Chicago and MAXBMW don't always have stuff in stock, the BING guys do.
That said, if your in a hurry you know they have the parts in stock. Just be clear about how you want it shipped! I called, ordered, ask Bing to ship PrioriTY MAIL!...instead they sent it snail mail then I re-ordered plus the jet kit (another $53 for next day)...to top that off I told them my jet sizes and they sold me the same jets...DOH! At any rate Chicago sells ALL BMW parts at I think 15% off retail always. Keep that in mind next time you need a piece of rubber...
02-22-2007, 12:45 PM
#90 | |
airhead or nothing
Oddometer: 7,934
I got my kits from some aftermarket supplier that used to advertise in Airmail... think I paid $32 for two kits, all rubber including the diaphrams (no jets or metal bits. I have their flyer at home and will post later.
Add your old diaphrams into the "breakdown" kit you carry on your bike.... good spare to carry!
