Old 02-10-2007, 09:36 AM   #76
PassTheGravy
Oddometer: 758
Originally Posted by twinrider
It's as wide as a car and steers like a car. I'll take this instead thanks.
Not for $16,000.
Whether the Spyder is my cup o' tea or not, I think it will sell like hotcakes at that price. Most of you guys are young and can't imagine yourself being older and having difficulty holding up a 700 pound bike with a passenger perched on the pillion seat. But, time marches on, and there are plenty of guys that want to keep riding with mama, but just don't have the muscle to do it, especially with touring bikes getting heavier and fatter all the time.
Personally, I'd rather have the Piaggio MP3 since it leans. But they are gonna have to put something more than 250cc's in it if they want to sell many of them in the U.S.
"Women come and go, motorcycles are forever." dlearl476
PassTheGravy is offline   Reply With Quote
Old 02-10-2007, 09:53 AM   #77
Kritter
Kritter's Avatar
Oddometer: 175
Here are the specs from the brochure:
Engine
Manufacturer................................BRP-Rotax
Type.............................................. 990 V-Twin
Displacement...............................60.90 in3 (998cc)
Bore.............................................. 3.82 in (97 mm)
Stroke...........................................2 .68 in (68 mm)
Cylinder........................................2
Valves per cylinder.......................DOHC 4
Max output...................................106 hp @ 8500 rpm
(79 kW @ 8500 rpm)
Max torque...................................77 lb-ft @ 6250 rpm
(104.3 Nm @ 6250 rpm)
Compression ratio........................10.8:1
Ignition type.................................Electronic ignition with
dual output coil
Lubrication....................................5W4 0 BRP synthetic oil
Exhaust system.............................2-into-1 with catalytic converter
Cooling.........................................Li quid cooled
Injection........................................M ulti-point EFI with 57 mm
diameter throttle bodies
Drive Train
Gear box......................................Sequentia l Manual 5-Speed (SM5)
with transmission-based reverse
Optional gear box........................Sequential Electronic 5-Speed (SE5)
Final drive.....................................28/79 ratio final drive with
Carbon-reinforced drive belt
Clutch...........................................W et, multi-plate, manual operation
through a hydraulic piston
Electric Equipment
Magneto.......................................500 Watt
Starter........................................... Electric
Battery..........................................D ry Cell, 12V, 21 Amp
Geometry
Front suspnsion..........................Double A-Arm with anti-roll bar
Front suspension travel................5.67 in (144 mm) with adjustable cam
Rear suspension...........................Swing-arm with monoshock
Rear suspension travel.................5.71 in (145 mm) with adjustable cam
Chassis type.................................SST Spyder
(Surrounding Spar Technology)
Steering........................................DP S (Dynamic Power Steering)
Tires & Wheels
Front tire.......................................KR21 165/65R14
Front nominal pressure................13-17 psi (89-117 kPa)
Rear tire........................................KR21 225/50R15
Rear nominal pressure..................13-17 psi (89-117 kPa)
Wheel size, front...........................Aluminum 14x5 (355x127)
Wheel size, rear............................Aluminum 15x7 (381x178)
Brakes
Type..........................................Foot-actuated, fully integrated
hydraulic 3-wheel braking system
Front braking system................4 piston calipers with 10.2 in x 0.25 in
(260 mm x 6 mm) discs
Rear braking system.................Single-piston caliper with 10.2 in x 0.25 in
EBD..........................................Elect ronic Brake Distribution
ABS...........................................Anti-lock Braking System
Parking brake...........................Mechanical, foot actuated to the
rear caliper
Safety & Security
VSS...........................................Vehi cle Stability System
TCS...........................................Trac tion Control System
SCS...........................................Stab ility Control System with
Roll-Over Mitigation
DPS...........................................Dyna mic Power Steering
DESS.........................................Digit ally Encoded Security System
Vehicle Dimensions & Weights
Dry vehicle weight....................697 lbs (316 kg)
Front storage capacity.............2,685 in3 (44 l)
Front max load capacity...........30 lbs (15.9 kg)
Total vehicle load allowed........440 lbs (200 kg)
Fuel capacity............................7.13 US gal (27 l)
Oil capacity..............................1.19 US gal (4.5 l)
Coolant capacity......................0.85 US gal (3.2 l)
GVWR.......................................1,188 lbs (540 kg)
Ground clearance.....................4.5 in (115 mm)
Vehicle overall height...............45.1 in (1,145 mm)
Vehicle overall length...............105 in (2,667 mm)
Vehicle overall width................59.3 in (1,506 mm)
Seat (top) height.......................29 in (737 mm)
Wheel base..............................68 in (1,727 mm)
Wheel track, front.....................51.5 in (1,308 mm)
Type of gas...............................Unleaded, 87 octane minimum
Color choices...........................Full Moon, Millennium Yellow
Instrumentation........................Dual analog and LCD w/speedometer, tachometer, electric fuel gauge, daily trip (A & B) meters, engine
temperature, ambient temperature and gear position indicator. Information
displayed in either metric or US Standards
Main options............................Fog lights, xenon lights, mono seat cover, racing exhaust pipe, travel bags, cargo liner, passenger backrest, low and high windshields
Warranty...................................2 years
Jamie K in Sooke BC
Kritter is offline   Reply With Quote
Old 02-10-2007, 10:27 AM   #78
Kritter
Kritter's Avatar
Oddometer: 175
I don't think the appeal will be just "the older crowd" or "the Ski-Doo/water craft crowd" or "the physically challenged crowd". I'm 42, in good shape, look ten years younger than my age and feel ten years younger than that...I think the Spyder is a very interesting machine and I see it stretching my riding season to nearly 12mos here in Alberta. I would likely keep the B12 or something like it for some rides but I could see riding the Spyder on a daily basis as a commuter and also as a primary tourer...hell I'd even take it out to track days for shits and giggles
Jamie K in Sooke BC
Old 02-10-2007, 11:07 AM   #79
Ergo
Ergo's Avatar
Oddometer: 805
Wink Sicles...
The Rotax motor is a known quantity (hop on any full size Aprilia Mille, Futura, Caponord, Tuono and you get the idea pretty quick what it can do).
What I want to know is about the handling! Hi vs. LOW speed. Is it awkward in parking lots etc... That will be the deciding factor for many. Does it put a smile on your face mile after mile?
Will Iron Butt Association let it compete??
So many Can Am questions...
BBQ Tour guide! IBA# 20567
Ergo is offline   Reply With Quote
Old 02-10-2007, 04:38 PM   #80
KiLeR650
Renegade Wheel-peeler
KiLeR650's Avatar
Oddometer: 7,157
That MP3 is dumb. The Sypder is a bit of a mystery to me, it looks like tons of fun at first glance, but the more I think about it the more it sounds less fun. I think I'll have to ride one to really "get it".
Originally Posted by Pete™
It wasn’t one of the good days. It wasn’t one of those banner days that involved pants.
KiLeR650 is offline   Reply With Quote
Old 02-10-2007, 05:37 PM   #81
kootenay kid
Lets Ride
kootenay kid's Avatar
Oddometer: 2,614
That thing is friggin rediculous. Another great Canadian idea. EH?
kootenay kid is offline   Reply With Quote
Old 02-11-2007, 07:39 AM   #82
PassTheGravy
Oddometer: 758
Greetings and salutations, ORT. Your ToadKing was indeed a gorgeous bike - one of the best looking bikes I've seen in a long time. But, bikes are like women in that regard - looks aren't everything, especially for one that you consider to be a long term keeper.
I trust you and yours are doing well. Ride safe on your trip to AZ, and give the Senator my regards.
PassTheGravy screwed with this post 02-11-2007 at 07:54 AM
Old 02-11-2007, 07:04 PM   #83
mrfix
mrfix's Avatar
Oddometer: 98
I'm here in San Diego at the Can-Am spyder unveiling, it's the coolest bike I've ever ridden. The 990 rotax is smooth a produces gobs of torque. I've gone to the tech seminars and rode the bike, it goes like hell, handles like it's on rails and is as comfy as a gold wing with out looking like a scooter. I will have one in the stable, on the road nothing seams to upset it, it goes through potholes and over bridge seams like they don't exist, it has a 44 L trunk in the front and mant accessories already available for it. Oh, it does great burn outs, that fat tire lights right up with a twist of the throttle.
mrfix is offline   Reply With Quote
Old 02-11-2007, 08:18 PM   #84
Adios Pantalones
AdventureDeficitDisorder
Adios Pantalones's Avatar
Location: San Diego, not Mex, but I can smell it from here.
Oddometer: 2,331
Can Am Spyder
Can Am launched their new 3 wheeled Spyder thing here in San Diego this weekend. My first impression is that it's the type of thing that might be fun to rent for a weekend, but I'd never buy one. I feel the same way about jetskis and Harleys.
They look more like an oversized sled or PWC with wheels than they look like a bike. Only the rear wheel looks bikeish. Nice exhaust note tho'. Local press reported that they're targeted at 40-55yo boomers whose wife won't let them get a bike!
http://spyder.brp.com/en-US/
Adios Pantalones is offline   Reply With Quote
Old 02-11-2007, 08:22 PM   #85
Roadwarrior
Taking The Long Way
Roadwarrior's Avatar
Oddometer: 1,002
I'm guessing they are banking on them being popular with the Snowmobile/ATV crowd.
Roadwarrior is offline   Reply With Quote
Old 02-11-2007, 08:22 PM   #86
LMJ
Faceplant in progress
LMJ's Avatar
Oddometer: 822
Aww, I thought you were talking about this:
Trikes... Feh... If you want a bike, get a bike! You can always put a sidecar on.
LMJ is offline   Reply With Quote
Old 02-11-2007, 09:59 PM   #87
Komet
The Voice of Reason
Komet's Avatar
Oddometer: 38,096
ABS going to be an option?
Always mindful of obstruction, do your duty, never fail;
Keep your hand upon the throttle, and your eye upon the rail.
Komet is offline   Reply With Quote
Old 02-11-2007, 11:33 PM   #88
mrfix
mrfix's Avatar
Oddometer: 98
abs, vss (vehicle stability control, traction control, and anti theft is all standard equipment. Options are back rest for passenger, 3 different height windshields, driving lights, many different bags, race pipe, custom wheels and custom leather seat covers. Again, it's the coolest thing I've ever seen. and the most fun to ride.
Old 02-13-2007, 02:10 PM   #89
eric2
®egister this:
eric2's Avatar
Oddometer: 3,797
bump
Can-am is back
linky
Eric
'06 R12GS, '13 s1000RR
Originally Posted by Big Steve View Post
I've yet to see a poor person driving a real gas hog......
lottery: A tax for people bad at math
eric2 is offline   Reply With Quote
Old 02-13-2007, 02:37 PM   #90
Gregster
Gregster's Avatar
Oddometer: 988
Dammit - we want new Can-Am motorbikes !
Gregster is offline   Reply With Quote
Times are GMT -7.   It's 08:57 AM.
