Old 10-13-2011, 06:15 PM   #151
vtwin OP
Air cooled runnin' mon
vtwin's Avatar
Oddometer: 7,473
I think I may have found my running problem.
Seal is pretty brittle and while spraying carb cleaner, idle picked up alot. I'll try it first and see how it works.
"Alles hat ein Ende--nur die Wurst, sie hat zwei"
Monroe.
"You only have too much fuel if you're on fire"
unknown
vtwin is offline   Reply With Quote
Old 10-16-2011, 04:49 AM   #152
radianrider
Adventurer wanna'be
radianrider's Avatar
Oddometer: 486
Save yourself some time and order the boots as well. I had to replace the boots and the orings to get the bike to run correctly. My boots looked to be in better condition than yours. Lots of discussion in the thegsresources.com about guys trying all kinds of repair techniques to keep the boots leak free. Consensus is that none of them work.
Same issues with mine. I could affect the idle by spraying around the boots. The orings just crumbled when I squeezed them.
I believe I ordered them from www.cycleorings.com. He puts the kits together for the GS series, so I ended with four. I also ordered the carb orings from him at the same time.
Here's his take on the orings you are fighting.
http://www.cycleorings.com/intake.html
radianrider is offline   Reply With Quote
Old 10-18-2011, 08:16 PM   #153
vtwin OP
vtwin's Avatar
Oddometer: 7,473
Yep, ordered them as well as oil filters. Seems that Bike Bandit is out of stock on one of the intakes, so I can't ride this week again.
Monroe.
unknown
Old 10-19-2011, 04:06 AM   #154
radianrider
Adventurer wanna'be
Oddometer: 486
That's a bummer! The good news is that the new rubber will make a world of difference in the way the bike runs. Got mine purring like a kitten with quick throttle reponse and easy startups.
Did you rebuild your front caliper? I'm planning on that job, with a stainless brake line, over the winter and am wondering if you found a source for a complete kit.
Old 10-19-2011, 05:31 PM   #155
vtwin OP
vtwin's Avatar
Oddometer: 7,473
Thanks, looking forward to getting rid of the miss at 4K rpms. Yes, I did replace the seals in the caliper and rebuilt the master. The caliper came out fine, but the master started leaking at the seal. So I replaced it with an EBAY GS500 master and it's worked out fine as long as no one notices the silver brake lever, kind of like C3PO. I got a black steel braided line from Cycle Brakes. I sent them mine and they sent back both. I highly recommend them.
Monroe.
unknown
Old 10-27-2011, 07:52 PM   #156
vtwin OP
vtwin's Avatar
Oddometer: 7,473
I got the intake boots in and the o-rings. Installed them tonight and the bike runs much better. A quick ride around the block and I believe my problem has been solved. The Mighty Tempter rides again!
This is what I used to prevent stripping out the made out of cheese screws.
Almost done.
Monroe.
unknown
Old 10-27-2011, 07:57 PM   #157
radianrider
Adventurer wanna'be
Oddometer: 486
Good deal, VTwin. Glad you got it running correctly again.
I've been looking for an inexpensive JIS screwdriver. Supposed to be much better with the old screws on these bike.
Slowly swapping all of the old screws out to allen heads. No more stripping out screws.
Old 10-28-2011, 02:52 PM   #158
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,941
Here is a lead on JIS screwdrivers:
http://www.advrider.com/forums/showthread.php?t=474338
"punk rocks what it's all about" - J. Strummer
R65LazaruS
So I sold my GS and went shopping for a G/S!
Solo Lobo is offline   Reply With Quote
Old 10-28-2011, 03:06 PM   #159
RideDualSport.com
TPB all the way
RideDualSport.com's Avatar
Oddometer: 1,589
Congratulations on getting the Tempter running! It takes a lot of patience an dedication to getting those older bikes going again.
"... I lock my rear up at least once every time I throw a leg over a bike."
The RideDualSport Forum
Mountain State Super Tenere Adventure
Alaska Deep Adventure
RideDualSport.com is offline   Reply With Quote
Old 10-28-2011, 08:00 PM   #160
vtwin OP
vtwin's Avatar
Oddometer: 7,473
Thanks. I've don't have much choice if I want to ride.
http://www.advrider.com/forums/showthread.php?t=354049
I'd also look funny and take forever to get to work if I ride the K11p with it's whole 80cc's
Monroe.
unknown
Old 10-28-2011, 09:04 PM   #161
radianrider
Adventurer wanna'be
Oddometer: 486
Thank you!
Old 11-05-2011, 02:50 PM   #162
Pablo83
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,813
Where do you get one of these?
Pablo83 is offline   Reply With Quote
Old 11-05-2011, 04:26 PM   #163
vtwin OP
vtwin's Avatar
Oddometer: 7,473
Hi Pablo, I have the older version of these...
http://www.amazon.com/Lisle-64250-Right-Ratcheting-Screwdriver/dp/B0002BC0S2
Mine are probably 25 years old and my phillips bit has long since broken. Good thing it fits a standard screwdriver shank.
Monroe.
unknown
Old 11-06-2011, 07:52 PM   #164
vtwin OP
vtwin's Avatar
Oddometer: 7,473
So we had our club meeting today and since it was local for me, I rode the K11p. Once the meeting was over, we went on a small ride to grab some lunch. Unfortunately, the K11p let me down again! Good thing I wasn't too far from home and was able to push it within a mile of home until I got it restarted and rode the rest of the way. Not really into naming bikes, but this one just comes to the top, "One-Way-Ki(1)p". It gets me to my destination, but never completes a ride. DNF king this one.
Monroe.
unknown
vtwin screwed with this post 11-19-2011 at 11:22 PM
Old 11-08-2011, 01:11 AM   #165
radianrider
Adventurer wanna'be
Oddometer: 486
At least it is a lightweight!
Times are GMT -7.   It's 09:21 AM.
