Old 09-18-2012, 06:10 AM   #196
vtwin OP
Air cooled runnin' mon
vtwin's Avatar
Oddometer: 7,723
Hi RR, I think I spliced it in. I'll try to get you a picture tonight.
"Alles hat ein Ende--nur die Wurst, sie hat zwei"
Monroe.
"You only have too much fuel if you're on fire"
unknown
vtwin is online now   Reply With Quote
Old 09-18-2012, 06:16 PM   #197
vtwin OP
vtwin's Avatar
Oddometer: 7,723
OK, I checked it out and I just spliced in quick slide in connectors. The switch just has blade contacts. Hope that helps.
Monroe.
unknown
Old 09-18-2012, 06:44 PM   #198
radianrider
Adventurer wanna'be
radianrider's Avatar
Oddometer: 520
Sure does. Thank you.
radianrider is offline   Reply With Quote
Old 09-18-2012, 07:21 PM   #199
vtwin OP
vtwin's Avatar
Oddometer: 7,723
Let me know if you want me to post a picture.
Monroe.
unknown
Old 09-20-2012, 07:59 PM   #200
vtwin OP
vtwin's Avatar
Oddometer: 7,723
Ooops, I did it again!
Monroe.
unknown
Old 09-22-2012, 06:26 PM   #201
radianrider
Adventurer wanna'be
Oddometer: 520
Addictions can be beaten, VTwin. Just ask for help
Old 09-23-2012, 07:39 PM   #202
AtLarge
AtLarge's Avatar
Oddometer: 125
I can remember slobbering over that Susi as a child. If anyone can redo it you'd be the one VTwin. Good luck!
1973 CL70-K3
1983 KZ750-K1
2008 GSX1300-BKK8 #1120
Cardo Scala rider G4 PowerSet
AtLarge is offline   Reply With Quote
Old 09-24-2012, 07:22 AM   #203
Scrivens
Scrivens's Avatar
Oddometer: 603
The old T-125 Stinger. One of the prettiest bikes of its time, and very popular around here. 15hp @ 8500rpm, 13ft/lbs @ 7000rpm and about 200lbs. A mate had one and probably the most frightening time of my life was being pillioned on it for a 20 mile ride to uni when my bike was off the road, redlined all the way. Garry used to ride it WFO and it made a glorious wail. A lot of fun to have one, and it will be nice to see it rebuilt.
Scrivens is offline   Reply With Quote
Old 09-24-2012, 06:17 PM   #204
vtwin OP
vtwin's Avatar
Oddometer: 7,723
Thanks guys, have been wanting one for a bit. It's in rough shape, but came from the original owner. Trying to unfreeze the engine, bike has been sitting outside, uncovered for 10 years.
Monroe.
unknown
Old 09-25-2012, 08:39 PM   #205
vtwin OP
vtwin's Avatar
Oddometer: 7,723
Here are some more pictures, I know, pretty rough.
Monroe.
unknown
Old 11-08-2012, 06:56 PM   #206
vtwin OP
vtwin's Avatar
Oddometer: 7,723
Finally got CHP verification done and the DMV gave me their blessing in me owning this fine product. So now work begins.
No amount of PB Blaster was helping free up the engine. Time to pull it apart and see what's the hold up.
That's as far as I got tonight. Weekend is coming up and will try to get the cylinders off. They were on there with a death grip.
Monroe.
unknown
vtwin screwed with this post 11-03-2013 at 09:55 AM
Old 11-11-2012, 04:23 PM   #207
vtwin OP
vtwin's Avatar
Oddometer: 7,723
This a good lesson in get those bikes covered before the "ran when parked" happens!
Didn't get too far, cylinders still stuck to the pistons. I hope this doesn't end up like someone's BSA engine.
Looks like water and moisture got down the cylinders through the rubber intake boot that was cracked. I even removed the studs thinking I could tap the cylinder off, or at least pry it. I even tried twisting it since the studs were out. It's stuck fast.
That's a lot of rust down in the intake and with iron cylinders to steel rings, I'm pretty sure they're welded together.
MORE PB Blaster, or maybe I'll find some Kroil, torch perhaps?
Monroe.
unknown
Old 12-15-2012, 03:25 PM   #208
vtwin OP
vtwin's Avatar
Oddometer: 7,723
Ok, no luck on removing the cylinders. May have to break the pistons and use a press to get the remaining piston pieces out. Decided to check into get the tank cleaned up. Anyone know what one could expect to basically restore a tank?
Monroe.
unknown
Old 12-17-2012, 11:16 PM   #209
bmwhacker
Still on 3 wheels
bmwhacker's Avatar
Oddometer: 4,490
I love threads like this!
Nothing more fun than attempting to resurrect the dead.
http://jupiterhack.blogspot.com/
Living proof you shouldn't play with matches
ABC# 1992
Old 12-18-2012, 06:49 PM   #210
vtwin OP
vtwin's Avatar
Oddometer: 7,723
Thanks, I need all the encouragement I can get.
Monroe.
unknown
Times are GMT -7.   It's 09:39 PM.
