Thread Tools Rating: Thread Rating: 13 votes, 5.00 average. Display Modes
Old 03-21-2010, 03:53 PM   #151
Coho911
Coho911's Avatar
Oddometer: 1,369
I completely agree with the Gillette hate. They are over priced pieces of JUNK. blade edge goes off after like 3 shaves & they charge $4.00 a blade. VERY poor product. (like selling AXE as a cologne ! HAHA - YEAH RIGHT !)
Here's my current razor & it's 5 times the razor Gillettes are:
Schick Quattro.
Still a SIMPLE design (designed to SHAVE - NOT vibrate, or self lube, or tell you when you need to change a blade, etc. etc. etc.)
Yes it does have 4 blades - BUT it DOES shave SUPER close in ONE pass & they last a couple weeks per blade AND cost about $1.80 a blade.
*** So good in fact - the Girlfriend passes on the brand new 'Super Gillette' in the drawer and goes for my Schick everytime.
2007 KTM 640 Adventure 'Bricktop'
----> LC4 Info Thread <----
So many places to go and see, so little time...do it whenever you can, cause too late comes fast. - Coho
The internets BEST Site for Image Hosting ---> Smugmug <--- SAVE $ 5.00 on smugmug membership with this COUPON - hUuJ7EHBKXWDU
Coho911 is offline   Reply With Quote
Old 03-21-2010, 04:02 PM   #152
Rider
Moderator Emeritus
Rider's Avatar
Oddometer: 3,080
Originally Posted by VonHelm
same thing I was thinkin'...
hiya Dan!
get anything done on yer "vacation"?
Mmmmmmmmmmmmmm ... not so much.
2012 FJR1300 - In Search Of Fast Sweepers
My Voice
Rider is offline   Reply With Quote
Old 03-21-2010, 04:03 PM   #153
Rider
Moderator Emeritus
Rider's Avatar
Oddometer: 3,080
Originally Posted by Waco Kid
A shaving forum? That's lamer than flashlights.
Ooooooooo. There's a flashlight forum?
My Voice
Old 03-21-2010, 04:05 PM   #154
CGH
Polluting the ether
CGH's Avatar
Oddometer: 22,531
Flashlight, not fleshlight.
Third-rate poster.
CGH is offline   Reply With Quote
Old 03-21-2010, 04:07 PM   #155
Bimble
In giro in moto
Bimble's Avatar
Oddometer: 8,350
But what a waste of cheap vodka.
Always the pragmatist.
And in keeping with that vein (and not slitting it with a dull blade), if vodka works, so must a much cheaper bottle of isopropyl alcohol, no?
Siamo tra qui e lì.
Bimble is offline   Reply With Quote
Old 03-21-2010, 04:15 PM   #156
a1fa
Throttle Jockey™
a1fa's Avatar
Oddometer: 13,855
This is typical marketing. You have to keep reinveting the same product over and over so it sells more... You noob.. You fell for it.. I buy crappy disposable razors for $8 for 5 pack. Each one lasts me 10 shaves..
But yet It takes me two weeks to get to this point:
Learn to ride. Ride to learn.
a1fa is offline   Reply With Quote
Old 03-21-2010, 04:16 PM   #157
a1fa
Throttle Jockey™
a1fa's Avatar
Oddometer: 13,855
Run your cheap Votka through a charcol filter.. Give it 3-4 passes.. It will taste like $100/bottle crap.
Old 03-21-2010, 04:18 PM   #158
yater
yater's Avatar
Oddometer: 8,517
Originally Posted by Coho911
Schick Quattro.
I use the same. I shave my face (every 3 days) and legs (1x/week) and get about a month out of one blade.
yater is offline   Reply With Quote
Old 03-21-2010, 04:18 PM   #159
Waco
Renegade Sickle Hound
Waco's Avatar
Oddometer: 14,977
Would vodka ruin the color strip that tells you when to replace the razor (as if it's not obvious when your blade is dull)?
Support the AMA.
Waco is offline   Reply With Quote
Old 03-21-2010, 04:19 PM   #160
wsdbikes
New Max is Mad
wsdbikes's Avatar
Oddometer: 1,281
and who is reading it?
Wsdbikes
"I only wish I had video running when WSD did a no footed can-can over some boulders on mainline....two feet of air easy..." -Abdelhub
Yeah, on the GS http://vimeo.com/3232838
Notable Past-'01 KLR 250, 95 R1100GS, 06 KTM 950 SM, 69 Bridgestone 90
wsdbikes is offline   Reply With Quote
Old 03-21-2010, 04:31 PM   #161
Waco
Waco's Avatar
Oddometer: 14,977
Originally Posted by OGW
old fashioned single blade double edged razors work very very well.
buy a quality one, strip it and dry blade after use, make sure to use a good soap and really let it work into your beard to soften the bristles. that part is important!
HOT water on a towel helps to make it a better shave by causing the pores to relax.
there was a reason a shave took so long back in the day at a Barbershop... it was done properly!
So what is a good, reasonably-priced single blade double edge razor?
Support the AMA.
Old 03-21-2010, 04:31 PM   #162
GR0NK
Got some screws loose!
GR0NK's Avatar
Oddometer: 2,315
Doesn't a sauna make you sweat a lot? My face burns if I happen to break a sweat not long after shaving.
You go into the sauna to shave, not after. Just go in, throw some water on and give it about five minutes until you start to sweat. Grab a bowl of hot water to rinse your razor and go at it. Do not toss your rinse water on the stones!
I'm usually in there for a bit longer afterwards and then take my shower and toss some aftershave on. I don't get any irritation.
Sean
Team Valley Bomb Squad
Nullus Vereor ex Terra Incognita
GR0NK is offline   Reply With Quote
Old 03-21-2010, 04:35 PM   #163
wsdbikes
New Max is Mad
wsdbikes's Avatar
Oddometer: 1,281
When I was stationed in Okinawa I had a barber shop shave from my female barber. Hot towel, brushed on soap and a straight razor.
Best shave i ever had.
Wsdbikes
Old 03-21-2010, 04:39 PM   #164
PunkinHead
Moobless Adventurer
PunkinHead's Avatar
Oddometer: 6,103
I use an old Gillette "Super Speed" I found in a box of stuff that was probably my father's or grandfather's. Gave it a good cleaning and it works better than any of the disposables or cartridges on the market and blades are less that 15 cents apiece. I imagine you could get one off ebay for pretty cheap.
PunkinHead is offline   Reply With Quote
Old 03-21-2010, 04:40 PM   #165
invisible monster
invisible monster's Avatar
Oddometer: 485
Schick Quattro.
I gotta go +1 on this. Used a Mach 3 for years and thought it was alright. Got a Quattro for free at the Winter X games a year or so ago. Found it in with some other stuff while moving recently and decided to give it a try. This thing blows away the Mach 3. Of course I have a big pile of Mach 3 blades that I got in a jumbo pack at Costco... Convinced myself not to buy any more Quattro blades until I use all the ones I have for the Mach 3.
invisible monster is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 12:08 AM.
