Thread Tools Rating: Thread Rating: 11 votes, 5.00 average. Display Modes
Old 01-16-2010, 10:12 PM   #91
Dragan
Oddometer: 99
Straight razors are AWFUL!!! the addiction develops fast, and it's worse than ANY narcotic.....
Bought one on impulse about 15 years ago, hacked the crap outta my face for a month until I figured out it needed to be properly sharpened ( DUH...)
Had someone that actually knew what they were doing hone it the first time, and.........nirvana.........addiction.........have n't shaved with anything else since.
I've also got about a dozen of them now. I use a japanese Tosuke most of the time now...it doesn't really cut whiskers; it scares them off your face.
Seriously though, a properly honed straight razor is a one way trip; shave with it once and you'll never go back to a disposable or an electric. NO comparison!
Dragan is offline   Reply With Quote
Old 01-16-2010, 10:41 PM   #92
bereahorn
Oddometer: 1,065
Amazon sells them:http://www.amazon.com/Merkur-Solinge...3706738&sr=8-9
bereahorn is offline   Reply With Quote
Old 01-16-2010, 11:07 PM   #93
Skred
Oddometer: 82
Hart Steel at http://www.hartsteel.com/.
American made steel. Scary sharp.
Get some Simichrome for your strop. The polish will make a scary sharp blade even sharper. Works for knives as well as razors.
Quality costs and the Hart Steel blade is worth every penny.
Skred is offline   Reply With Quote
Old 01-17-2010, 12:42 AM   #94
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 3,055
Originally Posted by wxwax
Those things totally freak me out. I've used them. Throwing them away is a safety concern. And I can't shake visions of sliced off fingers and stuff (when we were young my sister cut herself pretty badly with one. That's why she decided to go with a mustache, but that's another story.)
Usually the dispensers have a spot on the back to put the old blades. I use those double edge blades for cutting the tops of bread loaves.
Zak
ktm
old bmw
others
slackmeyer is online now   Reply With Quote
Old 01-17-2010, 02:30 AM   #95
reelfish
Oddometer: 86
My best advice is dont slip.
reelfish is offline   Reply With Quote
Old 01-17-2010, 08:44 AM   #96
flanga
Delusions of Adequacy
flanga's Avatar
Oddometer: 2,806
Originally Posted by Waco Kid
Ever been in the bathroom of an old house and seen a metal cover on the wall that's the size of a light switch cover and has a narrow slot? It's for disposing of razor blades inside the wall.
Some old between-the-studs medicine cabinets also had a small slot for dropping used blades into the wall cavity.
2005 GL1800
2005 KLR 650
fredlanga.blogspot.com
flanga is offline   Reply With Quote
Old 01-17-2010, 04:58 PM   #97
Cletus Hungwell
Cletus Hungwell's Avatar
Oddometer: 29
+1 on Badger and Blade.
I've shaved with double-edged blades for several years. I use a Gillette razor dated 1957.
To make a blade disposal unit, I took a can of chicken broth and cut a slot in the top with a knife, emptied the broth out then washed the can out with hot water. I slide the blades through the slot. It will probably take me a lifetime to fill that can up. If the wife finds it too ugly, hit it with a spray can...
For a great place to buy Merkurs and blades (brands shave very different) try http://www.westcoastshaving.com
"Democracy is two wolves and a lamb discussing what’s for dinner."
"Liberty is a well armed lamb willing to contest the majority decision."
Benjamin Franklin 1755
Cletus Hungwell is offline   Reply With Quote
Old 01-17-2010, 06:42 PM   #98
Jabba
"HOLD THE LIGHT!!!"
Jabba's Avatar
Oddometer: 12,550
Fuckers- this thread cost me about $250 this weekend. Anybody got a styptic pencil I can borrow?.....
"Everybody loves cunnilingus!" Chacifer
"The road to paradise is paradise" Jacques Yves Cousteau
Jabba is online now   Reply With Quote
Old 01-17-2010, 08:02 PM   #99
DirtyOldMan
Oddometer: 1,900
Indeed they did, can't tell you how many walls I've torn into remodeling houses and found the stud bay 6" deep in old rusty, mouse shit encrusted razor blades. Kinda creepy really.
Sandy Jackson
04 250 RFS
13 650 Terra
96 R1100R
DirtyOldMan is offline   Reply With Quote
Old 01-17-2010, 09:32 PM   #100
Chopperman
I am dead
Chopperman's Avatar
Oddometer: 27,033
Actually, if I did use this stuff I'd just use the soap puck and brush but a modern safety razor.
I have gone that route since about the time I started seriously shaving. My dad had given me his old Norelco electric, but once I had a serious beard, it just wasnt up to the task. Then I used the can of foam and a disposable blade. That worked okay, but when I tried a brush and soap it was night and day. You can really get the hair to stand up and soften.
For brushes go with the badger hair. Those might be spendy for an experiment. boar will suffice and is a lot cheaper.
For soap I have been using whatever I can find in the shaving aisle. Its just mild soap. nothing special. If you dont care to use a bar, I grabbed a tube of King of Shaves gel for a trip and started using it in the mug just to use it up. It works really nicely with a brush. Thick dense lather.
When using the brush, soak it in hot water (badger hairs are hollow and pick up the heat well) dont shake it out and whip up some lather off the bar in the mug. Then brush it on. But once on, work it around in circles to get it down to the skin. then finish up by brushing against the hair growth pattern.
scrape away with your 2 dollar disposable.
works like a champ.
I'm beard farming right now, but I still do this to clean up my cheeks and neck.
When I go skin on my head I do it this way too.
I would like to do the old fashioned safety razor some day, but its a bit of an investment to change something im not dissatisfied with.
So if you want to give it a whirl - just grab a tube of King of Shaves for about 5 bucks and a drugstore brush for 10 and an old coffee cup and see how you like it. If you do, you can go drop the cash on a proper shaving mug and brush.
EDIT - I had badger vs boar backwards.
dead
Chopperman is offline   Reply With Quote
Old 01-18-2010, 12:57 AM   #101
cornercarver
cornercarver's Avatar
Oddometer: 18,536
Has anyone correlated the names of folks posting in this thread with those who are making fun of the revival of working man's clothing in that other thread?
cornercarver is offline   Reply With Quote
Old 01-18-2010, 01:57 AM   #102
Erik the swede
Slacker
Erik the swede's Avatar
Oddometer: 2,304
Am i the only one using a kitchen knife?
Erik the swede is offline   Reply With Quote
Old 01-18-2010, 02:06 AM   #103
Firestorm
Firestorm's Avatar
Oddometer: 5,221
I use Derby Extra blades, 100 for $15.
And this for the shaving cream:
$12 for a tube and it lasts all year.
With an adjustable safety razor I got for $40.
Works fine, its cheap.
Firestorm is offline   Reply With Quote
Old 01-19-2010, 01:15 AM   #104
T-Stoff
T-Stoff's Avatar
Oddometer: 659
This is what I use.
[IMG][/IMG]
T-Stoff is offline   Reply With Quote
Old 01-19-2010, 05:59 PM   #105
Smithy
Avoiding the Skid-Demon
Smithy's Avatar
Oddometer: 7,992
You bastards are inspiring me. Forged, first grind, ready for drilling and heat treatment.
Proprietor of The Tidewater Forge Hot iron is my passion. Fire is my mistress. Let's dance.
35 Years of Scouting Blog for Bushcrafting and Boy Scouting experiences.
Smithy is online now   Reply With Quote
Thread Tools
Times are GMT -7.   It's 06:24 PM.
