Old 02-20-2007, 08:12 PM   #16
datchew OP
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
thanks all.
I have some #000 steel wool or maybe it's #0000
I'll give several methods a try in obscure locations before i get into it.
One of the header rings (metal thing under the exhaust nuts) has a break in it. Is this a big deal when I put the exhaust back together or should I just squeeze it in there?
datchew is offline   Reply With Quote
Old 02-20-2007, 08:22 PM   #17
RocketJ
Oddometer: 674
It is supposed to
Are you talking break or not a complete circle?
RocketJ is offline   Reply With Quote
Old 02-20-2007, 08:24 PM   #18
Mugwest
Mugwest's Avatar
Oddometer: 6,768
Dat, item 12 (or it might be 13, can't remember the order just now) above is split intentionally. It's the compression ring, and it tightens as the finned nut is tightened.
(also note that the order of assembly is bassackwards in the diagram-- the two tapered rings 12 and 13 obviously go between the finned nut and the head stub)
Mugwest is online now   Reply With Quote
Old 02-20-2007, 08:44 PM   #19
Gezerbike
Hey Rocky...........
Gezerbike's Avatar
Oddometer: 3,577
Originally Posted by SOLO LOBO
Be careful of the exhaust gaskets on the headers and muffler... I made the HUGE mistake of thinking changing these would be a good idea... then after 5 hours of fitting, swearing, sanding and cutting I got the stupid thing back together... serious PITA
I put in all new ones on my 95 when I had the exhaust off and they were not fun to install. Get everything to fit while it is still in pieces then install everything...makes the job much easier.
___________________________________________
Mike
2012 R 1200 GS RALLYE
Gezerbike is offline   Reply With Quote
Old 02-21-2007, 06:01 AM   #20
datchew OP
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
um.... uh... i'll have to look at it again.
Also, I think there was only 1 ring under each exhaust nut. If there's supposed to be two, i guess another item for the list. I'll check again tonight.
Times are GMT -7.   It's 11:36 AM.
