Old 02-19-2007, 08:54 AM   #1
lorazepam OP
Two fisted burger
lorazepam's Avatar
Oddometer: 8,173
R80ST vs R80GS rear shock fit
is the rear drive on the ST the same as the G/S? I was looking at wilbers shock and springs for the ST, and asked them about the G/S shock to raise the rear a bit.
They didnt seem to know if they were, and were reluctant to say it would work.
"In the end, I just want to break even."
R. Manuel
lorazepam is offline   Reply With Quote
Old 02-19-2007, 09:32 AM   #2
jtwind
Wisconsin Airhead
jtwind's Avatar
Oddometer: 3,476
The BMW parts fiche shows the g/s and the st with different shocks, which probably isn't surprising. Works performance shows that the ST shock is 12.75 inches long and list two g/s shocks one at 13" and one at 13.31". I'm guessing if you increased the st shock by 1/2" you'd be OK. There are other factors to consider, front end height etc. JT
jtwind is offline   Reply With Quote
Old 02-19-2007, 09:41 AM   #3
norton73
drinkin'
norton73's Avatar
Oddometer: 8,316
When we were looking at bikes for the wife, one offering was a g/s that had been lowered by using a st shock. At least that what the seller said.
Loose nut holding the handlebars
He’s one of those who knows that life is just a leap of faith. Spread your arms and hold your breath, always trust your cape. Guy Clark "The Cape"
norton73 is offline   Reply With Quote
Old 02-19-2007, 11:03 AM   #4
nick_rhinocycles
nick_rhinocycles's Avatar
Oddometer: 508
The ST and the G/S are essentially the same bike but with some small differences.
The G/S rear shock should fit and work perfectly on you ST.
Many people convert STs to G/S, and mostly you only need forks and a Shock.
I also have an ST!
--Nick
nick_rhinocycles is offline   Reply With Quote
Old 02-19-2007, 12:41 PM   #5
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,191
The rear ends are exactly the same except for the length of the shock. I don't know what effect raising the rear would have on steering geometry, but that's the only effect I can see from installing the G/S shock.
Old 02-19-2007, 01:11 PM   #6
lorazepam OP
Two fisted burger
lorazepam's Avatar
Oddometer: 8,173
Thanks for the help guys, I may just go with the stock shock, to avoid any handling problems.
R. Manuel
Times are GMT -7.   It's 07:53 AM.
