Old 06-25-2010, 05:32 AM   #7516
ADV8
Taumarunui..Darwin..
ADV8's Avatar
Oddometer: 2,297
Originally Posted by b0mber
They look horny ... thanks
Both cost under $100 off US Ebay,but then I needed mirrors and a hydraulic banjo bolt but it is a lot tidier than stock and got some fold away mirrors later on.
If these are of any use,PM a address and I can get them in the mail.
They were spares I kept in the tool tube and never used.
Cut down stockers.
The person who got you the billet DR650 third gear set, you're welcome.
49 Sunbeam S7 Deluxe-57 TR6 Trophy-68 Huskys x 2-71 Commando Fastback-73 Ducati 750GT-73 Eldorado-74 TR5T x 2-74 Commando Roadster-73 and 74 H2A/B-77 and 81 900SD's-86 400WR-98 TL1000S x 2-08 DR780-07 Ducati HM 1100S
ADV8 is offline   Reply With Quote
Old 06-25-2010, 05:53 AM   #7517
Dusty Rhodes
Yowie Chaser
Dusty Rhodes's Avatar
Oddometer: 1,558
What ya planning
Nothing big in the pipeline old mate......just a few local tracks that need to be dusted one day
I wondered why the frisbee was getting bigger , and then it hit me.
Dusty Rhodes is offline   Reply With Quote
Old 06-25-2010, 06:47 AM   #7518
BurnieM
Nipple boy
BurnieM's Avatar
Oddometer: 4,104
Why cut down levers ?
Just get Barkbuster VPS handguards
BurnieM is offline   Reply With Quote
Old 06-25-2010, 06:50 AM   #7519
b0mb3r
Old Git
b0mb3r's Avatar
Oddometer: 1,842
Cut down stockers.
Thanks ADV8 but ive cut the stockers, was hoping to find some 2 finger type levers ..... will keep looking
White pig
b0mb3r is offline   Reply With Quote
Old 06-28-2010, 07:46 PM   #7520
dave43
Oddometer: 239
Originally Posted by markwrich1
I'm on the south coast of WA so there's a lot of tarmac to get to any of the desert raids so will compromise a little I think. Need the 30l for the desert and so have to be set up before I leave home
I got Vince Strang to set me up for a Kimberley trip and for around $650 I got a shock service and 8kg spring plus a set Racetech fork springs which give you the option of .4, .43, .46 and I used .43 plus Vince's recommendation of 15wt fork oil. He is good to deal with, easy to talk to and knows his stuff with DR650. I sent him all my details including type of riding , bike details etc and then had a chat on the phone. I have an IMS tank so a bit lighter on the front than a full Safari.
Set up worked well on the trip and only bottomed out a few times on dips with dip in the bottom and that could have been avoided with a bit more standing up or a bit more compression damping on the shock. Can't recommend Vince highly enough to deal with. All up bike weight loaded and with full tank and 2x 5lt jerries full was 220kg plus me with gear and backpack around 98kg. Most of the time the jerries were empty as we only needed extra fuel on a couple of legs.
Dave
dave43 is offline   Reply With Quote
Old 06-29-2010, 03:12 AM   #7521
outback jack
outback jack's Avatar
Oddometer: 6,839
couple of quick questions
Hey fellars, just a few Questions about the DR set up, getting ready for the OCR.
1. Can i make the stock headlight brighter with a better globe without draining the battery or needing a bigger alternator when the engine is running, if so how big, or watts?
2. How easy is it to hook up a cigi lighter for phone charging.
3. Are there any tricks or special tools needed for changing the front fork springs. I have done plenty of MX bikes before, but no DR's.
4. What sort of stand or home made set up can you take on a trip other than a centre stand, for changing a flat, or do you just look for a log or dig a hole.
5. Are the old surfboard type straps good enough for tying on your load, or are better ones required.
There's something ugly about a NEW bike on a trailer.
CCC ride Cattle, Coal & Cane or Captains Crossing & Castlemaine.
http://www.advrider.com/forums/showt...1#post17025601
outback jack is offline   Reply With Quote
Old 06-29-2010, 03:15 AM   #7522
Ed Muggles
oh, the other left
Ed Muggles's Avatar
Oddometer: 250
i can answer question 2 really easily. the others not so
there is two spare circuits on the dr on under the seat and the other under the headlight (brown wire)
they are linked to the ignition circuit
i have my heated grips running on the under seat one and a cig lighter form behind the light
Ed Muggles is offline   Reply With Quote
Old 06-29-2010, 03:32 AM   #7523
blackcap
blackcap's Avatar
Oddometer: 538
1. upgrading the globe poses no problems with the battery or alternator. i ran one for over 30 000km and never had a problem except for the 3 pin connector melting a little.
2. cigi lighter only requires 1.5m of wire, an off the shelf lighter and an inline fuse. you can wire it directly to the battery or get all fancy with a switch inline.
3.springs can be changes out with a shfter and a milk crate. get the front wheel off the ground with the crate, top of the forks off and the springs are sitting right there under a spacer. you may want to look at doing more later on though and adding some valve emulators or similar device that will require further dissasembly.
4. there are centre stands available but ive left the extra weight off and just use a log or rock.
"One must die sometime and to die with ones boots on is very noble" - Carl Stearns Clancy, first RTW motorcycle, 1912-13
Australia to Iceland on a DR650 http://oztoice.wordpress.com
and facebook https://www.facebook.com/oztoice
blackcap is offline   Reply With Quote
Old 06-29-2010, 03:51 AM   #7524
outback jack
Oddometer: 6,839
Very good! What size globe or wattage did you use in the headlight? Thanks for the reply :
Old 06-29-2010, 03:55 AM   #7525
woopwoop
will think for food
woopwoop's Avatar
Oddometer: 5,345
I've got a centrestand, but some blokes use this jack outback.
http://www.ibbikelifts.biz/lifts-emergencylift.php
woopwoop is offline   Reply With Quote
Old 06-29-2010, 03:55 AM   #7526
Big Willy
two dementional
Big Willy's Avatar
Oddometer: 2,216
I carry this on trips. Haven't had to use it for a tyre change yet but it's primary purpose is to lube the chain.
Ally tent pole. 360mm long 22mm diameter 100grams weight.
I've also put a small screw in the swingarm drain hole to locate it
A vewwy good fwiend in Wome
Big Willy is offline   Reply With Quote
Old 06-29-2010, 04:05 AM   #7527
outback jack
Oddometer: 6,839
You see Dave, all that fancy stuff made for Harley's isn't a patch on Big Willy's piece of art. I shall send BW a royalty cheque or buy him a beer at the OCR if he's attending
Old 06-29-2010, 04:14 AM   #7528
woopwoop
will think for food
woopwoop's Avatar
Oddometer: 5,345
What is the standard carby needle clip position?
Cheers
Dave
Old 06-29-2010, 04:25 AM   #7529
greendude
greendude's Avatar
Oddometer: 1,132
I use a 55\100w bulb with no problems
greendude is offline   Reply With Quote
Old 06-29-2010, 04:26 AM   #7530
greendude
greendude's Avatar
Oddometer: 1,132
Cheers
Dave
in the middle
Times are GMT -7.   It's 09:20 AM.
