Old 05-26-2012, 06:02 PM   #11956
Goosefeather
Captain Slow
Goosefeather's Avatar
Oddometer: 858
Originally Posted by cn47 View Post
Hi everybody, can anyone pleas tell me where can I find posts on this forum regarding DR650 gearbox rebuilds?...at least I think that's what I need anyway...the teeth on my output shaft that hold the front sprocket are completely rounded off so that involves taking apart the gearbox doesn't it?
Google is your friend . . . .
https://www.google.com.au/search?sourceid=navclient&ie=UTF-8&hl=en-GB&rlz=1T4GGHP_en-GBAU483AU484&q=dr650+gearbox+rebuild+site:www.advrider.com
or narrowing the search a bit:
https://www.google.com.au/search?sourceid=navclient&ie=UTF-8&hl=en-GB&rlz=1T4GGHP_en-GBAU483AU484&q=dr650+gearbox+rebuild+site:www.advrider.com#hl=e n&safe=off&rlz=1T4GGHP_en-GBAU483AU484&sclient=psy-ab&q=dr650+%2B+%22gearbox+rebuild%22+site:www.advride r.com&oq=dr650+%2B+%22gearbox+rebuild%22+site:www.advrid er.com&aq=f&aqi=&aql=&gs_l=serp.3...23183.29905.0.32035.4.4.0.0.0.0.245. 945.2-4.4.0...0.0.-eD2cAEa3Aw&pbx=1&bav=on.2,or.r_gc.r_pw.r_cp.r_qf.,cf.osb&fp=d528ee9db3ad030d&biw=1050&bih=1478
or
https://www.google.com.au/search?sourceid=navclient&ie=UTF-8&hl=en-GB&rlz=1T4GGHP_en-GBAU483AU484&q=dr650+gearbox+rebuild+site:www.advrider.com#hl=e n&safe=off&rlz=1T4GGHP_en-GBAU483AU484&sclient=psy-ab&q=dr650+%2B+countershaft+%2B+spline+site:www.advri der.com&oq=dr650+%2B+countershaft+%2B+spline+site:www.advr ider.com&aq=f&aqi=&aql=&gs_l=serp.3...17222.22575.3.23469.4.4.0.0.0.0.240. 932.2-4.4.0...0.0.-z9mwxuqbNs&pbx=1&bav=on.2,or.r_gc.r_pw.r_cp.r_qf.,cf.osb&fp=d528ee9db3ad030d&biw=1050&bih=1478
play around with the ' + ' and ' " " ' to change search
All the best with the work . . .
Goosefeather is offline   Reply With Quote
Old 05-26-2012, 06:11 PM   #11957
rowie
Oddometer: 226
Originally Posted by Born-to-ride View Post
Just got a email back from MX Rob. He wil make a few next week for US30 each. I wil get it shipped here with my carb and a few other goodies. Hopefully I will save some on shipping
Even better. At least you know it will fit
Rowie's DR650RS Rebuild
rowie is offline   Reply With Quote
Old 05-27-2012, 01:25 AM   #11958
ADV8
Taumarunui..Darwin..
ADV8's Avatar
Oddometer: 2,260
If you mean to change out that shaft only,the engine needs to be disassembled entirely so the cases can be split.
The output shaft at least can be changed easily unlike the clutch shaft that has second drive gear pressed on.
How do the splines on the output/counter shaft get rounded off ?
The person who got you the billet DR650 third gear set, you're welcome.
49 Sunbeam S7 Deluxe-57 TR6 Trophy-68 Huskys x 2-71 Commando Fastback-73 Ducati 750GT-73 Eldorado-74 TR5T x 2-74 Commando Roadster-73 and 74 H2A/B-77 and 81 900SD's-86 400WR-98 TL1000S x 2-08 DR780-07 Ducati HM 1100S
ADV8 is offline   Reply With Quote
Old 05-27-2012, 02:07 AM   #11959
fatgut
Oddometer: 629
Carby hose filter
Got the Dr out today to try out some .7kg front springs
The bloody thing would not run for longer than a few seconds.Bikes done 2500km without fault, All done in about 4 rides on WA red dust bush tracks.
Pulled the carby apart and that fine red dust got in "F$^&" its a new bike. Fair bit in the top vacume area of the slid. Looks like the small standard filter on this breather hose is not the best against this dust.
After a carby clean the bike now runs fine again.
Is this a normal issue from new ?.
Fatgut.
fatgut is offline   Reply With Quote
Old 05-27-2012, 02:52 AM   #11960
davorallyfan OP
Commonist
davorallyfan's Avatar
Oddometer: 15,953
About 95,000km. Took her out today for a blat through the Brindabellas
A slippery 2km
7th Day Adventourist.
Re-incarnated
Terrafied
The best cure for Sea Sickness, is to sit under a tree.
davorallyfan is offline   Reply With Quote
Old 05-27-2012, 03:24 AM   #11961
racca
racca's Avatar
Oddometer: 321
fuel leak (kind of)
You guys are bad karma with all your talk of carbs lately!
Since I got back from a ride on friday I've smelt fuel from bike. Pulled the bashplate off this morning to find where it was coming from and found it dripping from the hose coming from the bottom of the carby. Would this be the float stuck?? If it is, is it just a matter of taking the bowl off and giving it a helping wiggle? Also is this a sign of other problems?
Thanks guys!!!
Mark
racca is offline   Reply With Quote
Old 05-27-2012, 04:34 AM   #11962
gavo
Slacker
gavo's Avatar
Oddometer: 1,796
Fatgut.
I cut out a round piece of foam, oil it and insert it into the top of the breather filter, works real good and can be changed easily and often
gavo is offline   Reply With Quote
Old 05-27-2012, 04:59 AM   #11963
sander
sander's Avatar
Oddometer: 313
Fatgut.
Make sure you clean and re oil that carb vent filter every time you clean your air filter.
A tm40 doesn't have this problem ;)
sander is online now   Reply With Quote
Old 05-27-2012, 05:44 AM   #11964
fatgut
Oddometer: 629
What happend to the buy a DR change the oil and just ride it. Shit its more maitenance than the KTM,
Going for a ride before India Alex, Only 4 more weeks. After the off on the 640 last week I better take it easy.
Kev.
Old 05-27-2012, 06:19 AM   #11965
sander
sander's Avatar
Oddometer: 313
Kev.
That's just because you can maintain a ktm while fixing the crash damage. I fixed the brakes and t-ed the carb vent lines on the dr this weekend, so I really want to take it for a ride between now and then.
Old 05-27-2012, 07:04 PM   #11966
ADV8
ADV8's Avatar
Oddometer: 2,260
India ?
Old 05-27-2012, 07:11 PM   #11967
fatgut
Oddometer: 629
Originally Posted by ADV8 View Post
India ?
Dehli up to Leh on Royal Enfield 500s. Going over Khardung Pass at 5570m. Bit differnt than riding round flat Oz.
Kev.
Old 05-27-2012, 07:58 PM   #11968
B1
Carbon-based bipedal
B1's Avatar
Oddometer: 3,267
had a similar issue a while back but mine was filling up the airbox with fuel. in my case, i had to pull the float assembly off and replace the small rubber o-rings. not sure if it will be the same thing on yours. happened on a bike less than 6 months old... next guess would be the float level.
free enduro training vids for gumbies here
B1 is offline   Reply With Quote
Old 05-27-2012, 08:07 PM   #11969
ADV8
ADV8's Avatar
Oddometer: 2,260
Kev.
Fixed
Dehli up to Leh on Royal Enfield 350's in August. Going over Khardung Pass at 5570m. Bit different than riding round flat Oz.
Les.
It should be interesting
I'm just about to shoot off and get a IDP.
Old 05-28-2012, 02:27 AM   #11970
greendude
greendude's Avatar
Oddometer: 1,132
Fatgut.
go to an auto shop and order a diff breather filter for a 4wd
K&N make one same size as the stock POS
once i replaced the filter on mine i didnt find dust in the slide anymore
or you could get a TM40 or FCR (they dont use one)
greendude is offline   Reply With Quote
Times are GMT -7.   It's 09:00 PM.
