Old 12-23-2012, 02:57 PM   #12781
Andy_P
Oddometer: 449
Whats the trick with the clutch adjustment. Its all working, but feels like just a little to much play. I tried to wind the adjustment all the way in on the level and tried to get one more spline on the clutch housing, but could not do it. Had to wind out the adjuster on the lever. I notced there is another adjustment on the cable, whats the deal with that?
Andy_P is offline   Reply With Quote
Old 12-23-2012, 04:57 PM   #12782
KIZ
Marty
KIZ's Avatar
Oddometer: 525
I put the lever adjustment half way push the rubber back on the cable adjuster loosen the locknut and adjust the cable.
KIZ is offline   Reply With Quote
Old 12-29-2012, 10:48 PM   #12783
dirtkiwi
Oddometer: 46
Procycle 790 kit
OK, so having just built a new shed, having no project to get on with, and having a little bit of money in the toy account, am thinking of pulling the pin on a 790 kit. Anyone here already done one??, would like to hear some thoughts on reliability, against fun factor. The bike only has 16000 k on it, so no reason other than to do it........ which is reason enough
Thoughts anyone???
dirtkiwi is offline   Reply With Quote
Old 12-30-2012, 05:26 PM   #12784
trgbox
Oddometer: 151
Procycle 790 kit
I too are almost ready to buy the kit. I have a second hand head just waiting on a barrel to swap as I wanted to keep the bikes original bits for resale/update. Keep me posted on how it goes if you install before me.
Everyone I know with lots of DR time reccomend the kit if you can afford it. I think it's a goer....790cc power to weight ratio on a 165kg bike!
Cheers
Thoughts anyone???
trgbox is offline   Reply With Quote
Old 01-04-2013, 03:33 AM   #12785
choccoloco
Cabin Fever....
choccoloco's Avatar
Oddometer: 798
I'm sure some of you will recognise these pictures instantly...
After warming up the bike, I dropped the oil for the first time and immediately after removing the sump plug, I hear PLONK and find this;
I had assumed this was part of a gears..... however it doesn't look like its from a gears or clutch plate. No other debris fell.
I've done less than 500 km's since owning it, don't have the mechanical history. It has less than 9500 km's on it, a '97 model. My last ride was the snowy ride beginning of November but didn't feel or hear anything untoward, didn't feel any different to DRF's DR.
Sunday I'll take off the clutch cover to have a good look, sift through the oil hopefully find finer residue instead of going back up a barrel.... nothing has exploded yet.... I guess it's probably best to just replace what broke, do a few oil changes with some old diesel then ride it.... Any opinions otherwise?
choccoloco is offline   Reply With Quote
Old 01-04-2013, 04:23 AM   #12786
Davemate
Davemate's Avatar
Oddometer: 21
Eek
Hey choccoloco,
I think your NSU has fallen apart :(
Does your neutral light still work?
btw
Hi
I'm Dave
I'm new here
I'm the one who has to die when it's time for me to die, so let
me live my life, the way I want to.
https://www.facebook.com/planBracingg
Davemate screwed with this post 01-04-2013 at 04:28 AM
Davemate is offline   Reply With Quote
Old 01-04-2013, 04:31 AM   #12787
rowie
Oddometer: 228
Bugger! Looks like one of the dogs from one of the gears.
Rowie's DR650RS Rebuild
rowie is offline   Reply With Quote
Old 01-04-2013, 04:40 AM   #12788
Davemate
Davemate's Avatar
Oddometer: 21
Cry
On closer inspection, I think you might be correct rowie.
Sorry chocco, that's worse news.
Old 01-04-2013, 04:58 AM   #12789
rowie
Oddometer: 228
It's either from the 3rd drive or 4th driven. You might have caught it just in time.
Edit: Just looked at the old gears out of my 90 model and I'm 99% certain the piece is off of 3rd drive. All of the gears (except 3rd driven) are the same from 90 to now.
Old 01-04-2013, 05:22 AM   #12790
choccoloco
Cabin Fever....
choccoloco's Avatar
Oddometer: 798
Thanks guys, Rowie you don't think it could have come from the clutch sleeve hub?
Just finished having a look at your thread from your signature, nice job on the DR. You also told me that this is probably going to be a big job..... soon find out.
EDIT: Just found a great picture displaying my part.....
http://www.advrider.com/forums/showp...&postcount=533
choccoloco screwed with this post 01-04-2013 at 05:34 AM Reason: Found the part....
Old 01-04-2013, 05:35 AM   #12791
DRjoe
DRjoe's Avatar
Oddometer: 5,096
That is definitely a dog of one of the gears.
You got seriously lucky.
Split that motor before you run it again.
Oh happy new year
Old 01-04-2013, 05:47 AM   #12792
choccoloco
Cabin Fever....
choccoloco's Avatar
Oddometer: 798
Oh happy new year
Happy new year yourself,
Lucky definitely, I don't have a magnetic sump plug and that last ride doing the snowy ride, coming back from Cooma at about 9pm..... stopping would not have been nice.
Old 01-04-2013, 06:00 AM   #12793
DRjoe
DRjoe's Avatar
Oddometer: 5,096
I've had third gear go before and take out the entire engine.
It was not amusing
Old 01-04-2013, 12:36 PM   #12794
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,137
Yep.
DR650 Wiki
NordieBoy is online now   Reply With Quote
Old 01-04-2013, 01:27 PM   #12795
B1
Carbon-based bipedal
B1's Avatar
Oddometer: 3,345
damn. despite the low kms it's a pretty old bike. if you aren't looking foward to a rebuild you could always part it out (minus the gearbox as a working unit of course). all the parts will fit every DR from 1996 to current... a mate of mine had his KLR650 seize and he got around $3000 parting it out, would have only got that for the bike in running order!
B1 is offline   Reply With Quote
Times are GMT -7.   It's 09:27 PM.
