Old 02-20-2007, 10:16 AM   #1
Reformed DucFlogger OP
Inventor Of The Wheel Mk2
Reformed DucFlogger's Avatar
Oddometer: 1,445
Dulling Stainless
With the wrenching forum being pahsed-out, thought I'd post this here.
I have a polished SS exhaust can that I would like to give a uniform satin finish to (and possibly paint afterwards). Is there any better method than wet sanding the can with fine paper/pads to accomplish what I'm looking to do?
"...who gives a rat fornication?"
Reformed DucFlogger is offline   Reply With Quote
Old 02-20-2007, 11:43 AM   #2
honcho
Barley Adventurer
honcho's Avatar
Oddometer: 911
take a wire wheel to it.
it'll be an adventure!
honcho is offline   Reply With Quote
Old 02-20-2007, 01:02 PM   #3
Twin headlight Ernie
bar napkin engineering
Oddometer: 1,467
Wire wheel
Don't take a wire wheel to it unless the wire wheel is also stainless. Most wire wheels are regular steel and will etch a metalic residue (rust) into the stainless steel. I've purchased stainless steel flat washers in the past that rust. Turns out they were stamped from a steel die and it was the residue from the die that caused the surface rust. I'd use a scotch brite pad. The scotch brite pad can be used to give it a matte finish or etch it for surface prep. 2HE
Twin headlight Ernie is offline   Reply With Quote
Old 02-20-2007, 01:58 PM   #4
elmoreman
takin' a break, boss
elmoreman's Avatar
Oddometer: 1,767
Find someone who doesnt have stainless, buy it, paint it, then sell your stainless for a profit. Why would you devalue such a thing?
airhead aficionado
elmoreman is offline   Reply With Quote
Old 02-20-2007, 03:35 PM   #5
scibeer
Lost
scibeer's Avatar
Oddometer: 889
Pull it off and find someone to bead blast it.
scibeer is offline   Reply With Quote
Old 02-20-2007, 04:03 PM   #6
honcho
Barley Adventurer
honcho's Avatar
Oddometer: 911
sorry... forgot to say use a stainless wire wheel. good catch t.h.e.
Old 02-20-2007, 08:16 PM   #7
Jhammer
Jhammer's Avatar
Oddometer: 277
3m Scotch Bright, try the general purpose if thats not enough go to the Heavy duty they will leave a nice satin finish. http://solutions.3m.com/wps/portal/3...?PC_7_0_3777_r
Jhammer is offline   Reply With Quote
Old 02-21-2007, 12:25 AM   #8
ROSKO
The Dirty Knacker
ROSKO's Avatar
Oddometer: 413
if you REALLY want to...
These guys pretty much got you covered, stainless wire wheel, bead blasting or scotchbrite pad on a random orbit sander.....
ROSKO is offline   Reply With Quote
Old 02-21-2007, 08:40 AM   #9
Oddometer: 1,445
Thanks...
for the input. The exhaust is a nice system (DAM out of Belgium via Sommers KTM) but never felt that a nice polished can looked 'right' ona DS bike. Doing some paint work and mods on the bike and the can is likely on the list.
Think I'll start with the 3M pad idea first.
Gracias
Old 02-21-2007, 10:07 AM   #10
MysteryRider
Laughing at danger
MysteryRider's Avatar
Oddometer: 953
Scotch Brite and WD-40.
Ride Safe,
Vettster
MysteryRider is offline   Reply With Quote
Times are GMT -7.   It's 05:57 AM.
