Old 02-22-2007, 01:22 AM   #1
cnycl OP
User Awaiting Email Confirmation
cnycl's Avatar
Oddometer: 106
gearbox overhaul
Before summertime I'm planning to overhaul my r80gs gearbox.
Since spare parts for airheads are scarce in Turkey I'll order them from UK etc.
Therefore I need to know what should be ordered for a complete overhaul before doing the job.
Bearings and seals can be sourced locally and I have the paper gaskets.
But I don't know how many sets of shims should I order in various sizes. I guess they are cheap items and could be ordered beforehand.
Also retain spring and neutral sensor are in my list.
Do I need any other items?
Thanks a lot.
cnycl is offline   Reply With Quote
Old 02-22-2007, 03:03 AM   #2
AntonLargiader
AntonLargiader's Avatar
Oddometer: 4,310
You'll need the 1mm washer that goes in front of the rear input shaft bearing. That gets crushed when you take the old bearing off. Maybe a new clutch boot. If the box is working fine, that should be about all you need.
AntonLargiader screwed with this post 02-22-2007 at 03:04 AM Reason: Input, not output
Times are GMT -7.   It's 09:04 PM.
