Old 02-23-2007, 12:15 AM   #1
opposedcyljunkie OP
Heavyweight Boxer
opposedcyljunkie's Avatar
Oddometer: 4,776
accessory socket on 92 GSPD?
I can't seem to find it, or if it's missing, where its location or mounting point should be. is the bike supposed to even have one right from the factory? thanks.
opposedcyljunkie is offline   Reply With Quote
Old 02-23-2007, 12:53 AM   #2
Joerg
Joerg's Avatar
Oddometer: 1,356
Yes, it should have one.
It's either on the left or on the right side of the bike, close to the side covers. In the picture below (my 1990 GS), it's visible between the air filter and the frame.
- Joerg
1990 BMW R80GS and K100LT * Lausanne, Switzerland
My Motorcycle WebPages - LED voltage monitor (aka charge light)
Joerg is offline   Reply With Quote
Old 02-23-2007, 01:36 AM   #3
opposedcyljunkie OP
Heavyweight Boxer
Oddometer: 4,776
Hey thanks Joerg. But I can't seem to make out the picture clearly. I can see it but not how it's mounted. Is there a hole or provision to insert the socket on the frame? Is it hanging onto something?
Old 02-23-2007, 02:51 AM   #4
Big B
Luft Kopf
Big B's Avatar
Oddometer: 242
Talking 93 is on the left
Mines a 93 R100GSPD and it is on the left hand side.
Big B
93 R100GSPD
Ride Reports
The Road to Nowhere
The Plan is there is NO PLAN! A Vietnamese Odyssey
"Semper in stercore versor, solum altitudo mutat"
Big B is offline   Reply With Quote
Old 02-23-2007, 04:14 AM   #5
Joerg
Joerg's Avatar
Oddometer: 1,356
Hi,
That is normal. The picture is on my website and is intended to show mainly the rear shock
There is an L-shaped mounting bracket that is itself bolted to the frame.
- Joerg
Old 02-23-2007, 05:11 AM   #6
hogmolly
Dude
hogmolly's Avatar
Oddometer: 3,142
On my two airheads, it's on the left under the battery box.
10 FLHCUSE-BLK, 09 FXDL, 08 FXDWG, 98 FLHR, 07 R1200GS Adv, 95 R100GSPD Classic, 93 R100GSPD, 92 CB750
hogmolly is offline   Reply With Quote
Old 02-23-2007, 08:56 AM   #7
Motocicletta
ridetowork
Motocicletta's Avatar
Oddometer: 550
The L Shape Bracket
Recently while replacing the transmission I bent that bracket. BMW no longer makes one that is speific to the GS but sells an airhead generic kit thant oin my GS does not fit as well as the original.
motocicletta
Santa Monica, CA
'88 R100GS
Motocicletta is offline   Reply With Quote
Old 02-24-2007, 09:04 AM   #8
opposedcyljunkie OP
Heavyweight Boxer
Oddometer: 4,776
thanks, guys. i found it, on the leftside bottom of the battery tray...
joerg, nice (and expensive) shock you have there
Times are GMT -7.   It's 11:42 PM.
