Old 02-23-2007, 05:33 PM   #1
opposedcyljunkie OP
Heavyweight Boxer
opposedcyljunkie's Avatar
Oddometer: 4,776
Question HELP!!! rear wheel removal 92 GSPD
My first time to do this for tire replacement. I removed the 4 bolts and the wheel wouldn't come off. Although it has somewhat loosened, something's holding on to the wheel. There's a a hole in the middle where I found a kind of stud with a threaded hole in the middle. It's a normal, right-hand thread and incidentally, my wheel bolt fits perfectly in it. Am I missing something here?
Thank you...
Rico
opposedcyljunkie is offline   Reply With Quote
Old 02-23-2007, 05:35 PM   #2
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,978
try loosening the brake .... the wingnut on the right hand side.
Unintentional psychokinesis.
Stagehand is offline   Reply With Quote
Old 02-23-2007, 06:30 PM   #3
RandyB
Oddometer: 5,072
If you need to remove the brake arm, make a witness mark first so reinstallation will be less painful.
RandyB is offline   Reply With Quote
Old 02-24-2007, 09:00 AM   #4
opposedcyljunkie OP
Heavyweight Boxer
Oddometer: 4,776
thanks, guys. yeah, i'm such an idiot. i turned back the brake wingnut for 20 half-turns and the tire almost dropped on the floor by itself!
Old 02-24-2007, 09:03 AM   #5
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,978
Hey! I got somethin right!
Old 02-24-2007, 09:21 AM   #6
Ricardo Kuhn
a.k.a. Mr Rico Suave
Ricardo Kuhn's Avatar
Oddometer: 12,411
RicoSuaveremove the brake actuator arm (the long treaded rod, no tools require) i'm sure the drum is binding on the brake surface
Wanted: worn, ugly, cheap motorcycle cover for a big GS 1200
Ricardo Kuhn is offline   Reply With Quote
Old 02-25-2007, 11:54 PM   #7
rowansride
recreational menace
rowansride's Avatar
Oddometer: 164
Then there's the other wingnut.....
the one on the handlebars.
rowansride is offline   Reply With Quote
Times are GMT -7.   It's 03:42 PM.
