02-28-2007, 05:50 AM
#16 | |
Don't buy from Brad
Oddometer: 7,403
Yup, that makes it count.
On tap:Nada Aging: 3 experiments in mead - blackberry, apple, and straight honey |
02-28-2007, 09:50 AM
#17 | |
recreational menace
Oddometer: 164
Carefull......
02-28-2007, 10:01 AM
#18 |
Oddometer: 5,072
I've had good results with Real Gasket's stuff. No problems at all. They aren't cheaper from the manufacturer, but then again one is all you need.
02-28-2007, 10:09 AM
#19 | |
Don't buy from Brad
Oddometer: 7,403
02-28-2007, 08:14 PM
#20 | |
Oddometer: 674
02-28-2007, 08:48 PM
#21 |
The Dirty Knacker
Oddometer: 403
I've only used the float bowl gasket. Good result and (in my opinion) WAY better than the cork. I have not used any of the other gaskets so I can't give you any feedback.
Warping a valve cover is pretty crazy. |
03-01-2007, 09:18 AM
#22 |
recreational menace
Oddometer: 164
warping valve covers
Tell me about it... The fucker just would'nt seal without three times the torque. I still have a oilpan gasket that I keep on the bike as a spare... I figure it's better than a broken/distorted one if I'm broken down in the middle of nowhere. It packs down pretty small at that.
Still not a fan though. |
03-12-2007, 08:26 PM
#23 |
G(/)S ... what else!
Oil Pressure Switch
NAPA Oil Pressure Switch OP6065 (C$16) is a direct replacement and works fine.
Some of the above is fact, some is fiction, some is my personal imagination and some is just simple truth. [me] ... i'm not touring around the world, but neither are most of the guys i see running overloaded spam cans ... [bmwblake] Stephen Bottcher Ontario, Canada '72 R75/5 The Blues www.stephenbottcher.net |
03-12-2007, 09:26 PM
#24 |
Lost again... Yeah!
Oddometer: 191
broke my shift lever today
Opps... I broke the shift lever on my 86 R80. Does anything else work?
Ken |
03-13-2007, 12:25 AM
#25 |
Beemerholics Anonymous
Oddometer: 7,354
My concern using a silicone pan gasket is the bolts falling out. There's no way the bolt will bind in the hole with the gasket being soft and squishy. Do you use loctite? Those suckers fall out easy enough with the stock hard one.
03-13-2007, 08:04 PM
#26 | |
Oddometer: 5,072
1 5/8 hose makes a pretty good carb to intake fix for $3.49. So far, so good, on 32mm carbs.
03-14-2007, 06:00 AM
#27 |
I Miss the PartyBoss
Oddometer: 5,884
Is the Master Cylinder (under tank) "Rebuildable" on the R90/6?
Mine is leaking out of the back side, underneath the rubber boot. It's the pump-? shaft thingy that is connected to the cable, running to the handlebar. Is it just some "O-Rings"? I priced one from BMW,...........$400 OK, really $397.00. Any help would be appreciated! Boojum!
"I aint no ruff guy, aint no tuff guy. Don't get out much, and don't dress up fly" BMW's: 1999 GS 1100 "Work Horse", 1975 R90/6 "Black Betty", 92 R100 GSPD, 03 XR 650L with Farkles, KLR 250, 72 Honda CL-70 |
03-14-2007, 11:04 AM
#28 |
Oddometer: 7,354
It is rebuildable and the kit is around $35. Make sure the cylinder isn't pitted too badly before getting the kit, though. You'll need snap ring pliers to open it up, and then to hone I've used some wet or dry sand paper wrapped around a dowl chucked into my drill. Look in there real close and feel with a pick to make sure there isn't any pitting.
03-14-2007, 11:25 AM
#29 |
Oddometer: 5,072
I bought the rear MC kit for my RT from Max BMW. Around $40. Follow tvrla's instructions. Piece of cake.
03-16-2007, 12:38 PM
#30 |
Oddometer: 270
Real Gaskets are Great
I have used Real Gaskets valve cover gaskets for about 150,000kms now.
They have been on and off the bike 15-20 times,are still sealing fine, and have never leaked. The torque needed to seat them is minimal. If you need more torque to seat them that the specs, chances are your valve covers are warped. To check your valve covers simply place them on a sheet of glass and see if they rock. Cheers |
