Old 02-15-2012, 02:42 PM   #526
subagon
Hopelessly lost
subagon's Avatar
Oddometer: 570
You might have better luck putting this in the Flea market.
I see that both Max and Bob's BMW have right covers (single, not a pair) for the /5 listed for around $115, but they look like /6 covers in the picture
Originally Posted by rudolf35 View Post
I have a 1971 /5 and it is missing the right side cover. The left one is perfect just missing it's mate. I found them new but $250 for a SET of tins? Any right side for a /5 would do, powder coat is cheap. If you have one do PM me.
Mike
Antioch, FL - Hopelessly lost, but making good time
Bike picts
subagon screwed with this post 02-15-2012 at 03:11 PM
subagon is offline   Reply With Quote
Old 02-16-2012, 06:53 AM   #527
CurlyMike
Formerly SaddleSoar
CurlyMike's Avatar
Oddometer: 978
I think he is looking for the toaster ones, and yes should be in FleaMarket
Giving the horses and the wife a break from riding...
CurlyMike is offline   Reply With Quote
Old 02-16-2012, 09:33 PM   #528
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 2,406
http://www.bmwbayer.de/Battery-cover...-/5-right.html
boxerboy81 is offline   Reply With Quote
Old 03-16-2012, 09:47 AM   #529
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,476
Source for airhead oil filters. thx to batoutoflahonda
Or Wix. For the R80G/S w/o oil cooler the P/N: 24945 which is a NAPA PS4945. Napa you can order it on line and pay for it when you pick it up at your local store. Double check the Wix P/N here:
http://www.wixfilters.com/filterlookup/index.asp
Note: When looking for the G/S #, use the R80G, and then the year goes back to 1981. WIX and NAPA kits both come with 'O' rings, shims, gasket, and drain plug seal washer.
'85 BMW r80G/S--Another G/S on the road--Central America on a Shoestring--Nova Scotia on a Shoestring--Never Leave a Man's Behind
Proud SmugMug User Support ADV: Don't give those cheap bums your discount code
bgoodsoil is offline   Reply With Quote
Old 03-24-2012, 08:23 AM   #530
ColininKodiak
(not in Kodiak)
ColininKodiak's Avatar
Oddometer: 713
Anyone know the thread size on a R100GS master cylinder? I've got all the bits to do a Brembo 4 piston caliper swap except for the banjo bolt for the Spiegler brake line. Better yet any one have the part # for the bolt?
2002 BMW R1150GS Garage Queen
ColininKodiak is offline   Reply With Quote
Old 03-24-2012, 04:32 PM   #531
mark1305
Old Enough To Know Better
mark1305's Avatar
Oddometer: 6,009
Damn! Another Coastie. Retired ship driver here.
I think I have a few banjos in the parts bins. Are you going to need a double, or single. Let me know when you figure out the size, and if I can match it I'll send you one.
Might be better to PM me just so I notice and don't forget to check this thread.
Mark J
Merritt Island, FL
When a person asks you for advice, they don't want advice. They want corroboration.
mark1305 is offline   Reply With Quote
Old 03-25-2012, 07:52 AM   #532
noman
Oddometer: 843
Question Low Profile R75/6 Headlight Socket Needed - source?
i had to replace the 3-prong headlight socket on my r75/6 and i noticed that the generic one i picked up is longer than OEM by about 1/4inch. it doesn't sound like much but it's real crowded back there (even after making adjustments to the wiring) and am worried that the socket will mash up against the wiring panel that's bolted to the rear of the bucket.
also, the OEM spade connectors are oriented at 90 degrees, while the replacement ones are straight back.
replacement socket with wiring was $3.50, OEM at max is $63 plus shipping.
anyone found a sutable replacement? many thx,
bobp
1976 r75/6 -- thx lloyd!
1985 vf500f -- v4, 6 spd, 16v, triple discs, water cooled
1997 900ss -- full sp spec
noman is offline   Reply With Quote
Old 03-25-2012, 11:52 AM   #533
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,537
bobp
I think you need something like this, I think I have some of them in my box of assorted connectors, so they are available there and there:
http://www.repairconnector.com/produ...bber-Boot.html
Have tools, will travel!
Old 03-25-2012, 02:06 PM   #534
Les_Garten
Les_Garten's Avatar
Oddometer: 727
That's a very cool site! Thanx for sharing that one with us!
Les_Garten is offline   Reply With Quote
Old 03-25-2012, 02:25 PM   #535
Zebedee
Zebedee's Avatar
Oddometer: 799
I've just googled H4 90 connectors and it seems like some H-D's use them on some models ... here
If it's not blasphemy/heresy to say it here, it might be a cheaper OEM solution, also it should open up a wider range of after market vendors too.
HTH
John
The perverse must persevere
Zebedee is online now   Reply With Quote
Old 03-25-2012, 06:48 PM   #536
noman
Oddometer: 843
yup!
that eagerbeaver site has just what i needed, an H4 socket with right-angled connections. thx!
bobp
Old 04-17-2012, 05:21 PM   #537
Boxer Metal
Mad Scientist
Boxer Metal's Avatar
Oddometer: 3,461
Late reply- A 71 did not have side covers
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 04-17-2012, 05:51 PM   #538
lockyv7
lockyv7's Avatar
Location: Sunshine Coast Australia, There is no winter here.
Oddometer: 1,022
I dont think he asked if the 71 had side covers, he said his 71 is missing one side cover. here are my two bikes a 69 and a 71 and they both have sidecovers.
lockyv7 is offline   Reply With Quote
Old 04-17-2012, 07:14 PM   #539
Boxer Metal
Mad Scientist
Oddometer: 3,461
The 71 does not have tabs on the rear frame to properly hold the side covers in place.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 04-22-2012, 07:13 PM   #540
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
bobp
Or, you could consider this.
http://www.wirewerkes.com/WIRING_1970_AND_BEYOND_.html
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
Times are GMT -7.   It's 04:19 PM.
