03-08-2007, 05:28 AM
#61 | |
True vulgarian
Oddometer: 4,188
03-08-2007, 04:07 PM
#62 | |
Oddometer: 95
Great idea! Since the protection is in the inner jacket that shouldn't cause any safety concerns. Thanks a lot for all the great info, makinwaves. Now I just need to find some way to afford one of these.
03-08-2007, 11:35 PM
#63 | |
Oddometer: 1,291
03-12-2007, 06:04 AM
#64 |
Oddometer: 12
So many Choices
Well after lurking here for a few months in search of gear, I had to become a member because of this thread. Unfortunately I don't think this gear will work for me because I do usually take tall sizes, especially in the pants. I can sometimes get away with jackets in normal size, but it never fits perfect. In any case I don't want to polute this thread with all my possible choices but to keep it focused on this stuff.
Questions I have: It's poly, what temp does it melt at? Do you have pictures of the armour in it? I know it doesn't have a back pad, but I'd like to see the arm/knee armour. How does it compare with others? How does the length run in the pants? |
03-12-2007, 06:30 AM
#65 |
Oddometer: 1,291
The sizing, the pants length... biker-land.de will send you a Jofama measurements list and get Jofama to recommend based on that.
The armour is the same as T-Pro Forcefield armour, which is probably the best there is. The Forcefield website has pictures. I don't what temperature the polyester fabric melts at but that's not a specification of the CE standard. Impact abrasion is and the Halvarssons Safety Jacket and Pants exceeds the specification.
03-14-2007, 01:12 PM
#66 | |
Oddometer: 1,804
Now for melting.... I've searched quite a bit trying to find more information about motorcycle jackets melting onto skin as a result of friction from a crash, and really can't find any reliable sources that says this happens. In particular, there are a number of studies out there that document motorcycle crashes and injuries; i.e., causes, gear choice, helmet colour, accident rates, body parts injured, degree of injury, etc.; however, none of them even mention a single occurrence where a jacket melted onto the skin. Until someone can show me there is a probable chance of this happening, I have omitted it from my criteria for defining a safe jacket. I did do some research into melting points and wow is there ever a lot of different clothing materials out there!! I'm far from anything related to a clothing expert, so I stuck to reliable or verifiable sources for information (e.g., DuPont, MSDS sheets, patent information, etc.). Here is what I found with the Halvarssons jacket slotted in to the mix:[Name of Material - Melting Point in degrees Celsius]
Ignoring Lycra and Kevlar, I would say that the Halvarssons Safety Jacket is in the middle of the pack with respect to melting temperatures. Kevlar is obviously the highest and technically it doesn't melt at all. At the temperatures noted the material kind of disintegrates rather than melt. I found a couple websites that inferred polyurethane coatings on the jackets (which aid in water proofing) can increase the risk of a jacket melting. I could not find any jackets that were completely free of polyurethane, including Kevlar clothing. For example, Cordura is described as "Type 6.6 polyurethane nylon". Motoport's Kevlar clothing and Keprotec clothing are actually 3 to 4 fabrics blended together as Kevlar on it's own cannot be used for clothing manufacturing. Usually, the blends consist of some form of Cordura and Lycra. Lycra is defined by its patent as having a minimum of 85% polyurethane. I'm not sure how much Lycra and Cordura ("polyurethane nylon") make it into a Kevlar blend, but I believe it is a fair amount. It would be interesting to know how that effects the "no-melting" claims of some of the Kevlar clothing manufacturers. Note, this is not a knock on Motorport or Rukka which produce Kevlar clothing and which I personally use (and love!) for pant protection, just a simple objective comment / question. At the very least the Kevlar blended clothing would have the least risk of injury due to melting as much of the material is made of Kevlar fibres that don't melt. Hope this is useful! |
03-14-2007, 06:00 PM
#67 |
Oddometer: 12
Yes, that is helpful. You knew exactly where I was going with this. I've been doing my homework and almost pulled the trigger on motorport but I just can't get myself to do it. The melting thing was 'bothering' me. I've also looked at BMW's street guard(Armocor) and some of their other stuff with the Dynatec. Recently I've started to look at leather again. I need to decide pretty soon, or my riding season will be over (just kidding).
03-16-2007, 08:31 PM
#68 |
Oddometer: 1,804
Robare:
Maybe you could get the motoport pants so you can get the length custom sized, and then the jacket of your choice (of course, I'd recommend the Halvarssons... I took some photos of the Halvarssons CE armour from the jacket, as well as the armour in my now retired Joe Rocket jacket and the armour from my Motoport pants. Pics below. To be fair, I don't think any physical inspection of armour is going to tell you a lot and what you really need is to test it on a machine to see how much energy is absorbed by the armour. But for what it's worth....
Then I conducted a highly scientific study to test their real world properties... One by one I grabbed each of the armours and with the same hand held it against my palm. I then punched the armour with a blunt, but pointed heavy object. The amount of pain sustained by my palm was how I ended up with my rankings....(I did mention how scientific this was didn't I?? ). So here's how they faired, in order from best to worst:
03-18-2007, 09:58 AM
#69 |
Oddometer: 12
Thanks again for your information. For some reason your pictures do not show, says bandwith exceeded. However I have managed to track down some sites with pictures of the armour. I like your test, I have received samples of motoport padding and stretch kevlar. I did the punch wall test with the padding from motoport and thought it was ok, but didn't have anything to really compare it to. I did my own 'abrasion test' also comparing the kevlar stretch material from motoport, icon barrier pants with the aramid material and a 30+ year old leather jacket. I took a dremel tool to each timing how long it took to wear through. The icon pants did very poorly, about 1/6th of the time the kevlar took. To my surprise the 30+ year old weather battered piece of leather still did better than the kevlar. I'd say the kevlar was 3/4 what the leather was. I know this wasn't too scientic either, but felt it shows something. Under normal circumstances I would expect the kevlar to do better because it would flex and move more in a slide.
Maybe the motoport pants and the Halvarssons jacket would be do able for me. Some Jackets fit me OK, but usually a little to loose in the arms for the armor. |
03-18-2007, 11:10 AM
#70 | ||
Oddometer: 1,804
Interesting test. It'd be nice to see results on how the Kevlar blends fair under CE testing. Quote:
Good luck! Hope you get something before the riding season kicks in fully! |
03-18-2007, 02:31 PM
#71 | |
Oddometer: 99
This has been covered before, but it remains true - a lot of people at least on this forum would love to see the Motoport stuff go through CE testing. For me, their clothing looks really bad and the one thing they've got going for them (unless you're into expensive, dumpy-looking clothing in mostly garish colours) is the safety/comfort factor. It would be great to know just how safe Motoport stuff is in comparison to other brands. |
04-12-2007, 09:59 AM
#72 |
Oddometer: 1,291
Outlast
Keeping this thread alive while I try - struggle- to find out what size Halvarssons pants I should get for my long legs and skinny waist.
I just found this pdf about the Outlast temperature-regulating fabric that Jofama/Halvarssons use. Very interesting. Nice pictures of various gear that uses it. Spanish police boots, French police gloves made by Furygans Leather, UK motorcycle police hi-vis jackets made by Jofama (way better than any we've seen here), Rome police jackets, and nice desert type camo made in Serbia lined with Outlast. Outlast is a company based in Boulder, CO. http://www.outlast.com/fileadmin/use...-270405-gb.pdf
04-12-2007, 10:09 AM
#73 | |
Kountersteering Krew
2012 Speed Triple 2005 R1200GS 1998 FXDL |
04-12-2007, 10:14 AM
#74 |
Oddometer: 1,291
It would be the same as anything else - send it to them and they fix it, or replace it. Which is not so good for us that aren't in Europe. I don't know if they say anything about it on the website, but the impression I have is that they'd sort it out - it's their "high-end" top of the range gear, it's not mass-produced.
04-12-2007, 10:31 AM
#75 | |
Oddometer: 3,479
It's funny. When you look at the material label on the jacket, it says "Paraffin -- 22%." That's right. The jacket is 1/5th wax. |
