Old 03-03-2007, 02:45 PM   #1
ktm950se OP
ktm950se's Avatar
Oddometer: 1,385
Which Heated Grips?
Greetings,
Having done a proper search I've narrowed my heated grip choices down to the following:
  1. Symtec Motorcycle Grip Heater Kit w/round rocker switch: http://www.casporttouring.com/store/...e=heated_grips
  2. Oxford Heaterz Heated Grips: http://www.bikesax.com/Merchant2/mer...egory_Code=HGR
  3. Hot Grips: http://www.hotgrips.com/
Can anyone recommend one over the others for my KTM 950 Super Enduro?
I'm leaning towards the Oxfords and Hot Grips for ease of installation, but don't want hard plastic grips that will cut into my hands and offer no vibration damping.
Thanks for your suggestions!
ktm950se
ktm950se is offline   Reply With Quote
Old 03-03-2007, 03:10 PM   #2
rnr
Simple. Fast. Paid for.
rnr's Avatar
Oddometer: 1,005
symtec, california
ktm:
I've put symtec on my BMW R80RT, and would again. Kept the stock grips.
I've ordered up another set for my DR650.
Order them from California Sport Touring, seem cheapest around. (My first set came from aerostich, with a klutzy switch. Bought a used BMW dash rocker switch.)
http://www.casporttouring.com/store/...gory_Code=SYMT
The boots stay on.
'08 Buell Ulysses
'97 BMW R1100RT
rnr is offline   Reply With Quote
Old 03-03-2007, 04:41 PM   #3
drmajor
drmajor's Avatar
Oddometer: 535
Heated Grips
Take a look at Dual-Star.com.
They have a lot of dual sport items, but thier heated grips are great! I put them on my RT and loved them.. Unlike many heaters, this one has a dual circuit so that when you are on LOW, it only heats one circuit and does not through electricity away.
$30.00.
drmajor is offline   Reply With Quote
Old 03-03-2007, 04:42 PM   #4
idahoskiguy
idahoskiguy's Avatar
Oddometer: 1,131
Besure you choose heated grips for a motorcycle and not an ATV or Snowmobile. The grips for bikes are specifically designed with a differentrial in heating to allow for the twist grip thottle the ATV grigs are the same for each side.
idahoskiguy is offline   Reply With Quote
Old 03-03-2007, 05:42 PM   #5
Fitero
Just One of Billions
Fitero's Avatar
Oddometer: 242
The Symtec and Dual-Star, are one and the same. I installed a set on my Gran Canyon, which worked very well, until the temps got down to @ freezing.
Another option, are the following; http://www.cbxman.com/detail.aspx?ID=504
I think that I am going to install the Koso grips this time, just to see if there is a difference.
Fitero is offline   Reply With Quote
Old 03-04-2007, 11:26 AM   #6
Dagny_Taggart
John Galt - 2014
Dagny_Taggart's Avatar
Oddometer: 858
Big fan of Oxford
I ordered a pair of Symptex (?) to put under the stock grips of my FZ-6... I just didn't like the way they terminated. It would be too easy to damage them.
I have installed Oxford Heaterz Grips on the FZ-6, the DRZ, and a ZX9R and I love them. They have an electronic controller included in the priced (which is slightly on the biggish side) so they make efficient use of the bikes available power. They do they job for me and I'll probably install a pair on every bike I ever own... I love them that much!
Thanks,
Dagny Taggart
Dagny_Taggart is online now   Reply With Quote
Old 03-04-2007, 12:05 PM   #7
soboy
soboy's Avatar
Oddometer: 2,293
I installed symtecs on both my bikes last year, they work well and are a great value for the money.
"Reason takes a holiday as Dr. Horrible spends money he doesn't have, on a motorcycle he doesn't need, in a misguided attempt to recapture his youth which, upon reflection, wasn't all that great in the first place."
"Ride to the bar in your pirate outfit, guzzle some beer, play "Free Bird' on the juke box and then go home. Badass."
soboy is offline   Reply With Quote
Old 03-04-2007, 01:14 PM   #8
ktm950se OP
ktm950se's Avatar
Oddometer: 1,385
Thanks for the advice!
Are the Oxford and/or Hot Grips "soft" like regular grips, or are they hard plastic?
ktm950se
Old 03-04-2007, 01:58 PM   #9
strommin
bending light
strommin's Avatar
Oddometer: 951
Polly Heaters
Have you heard about Polly Heaters?
Cartridges slip inside the bars - no change to the grips themselves.
Good price, fairly easy install, great heat.
Dave
strommin is offline   Reply With Quote
Old 03-04-2007, 03:25 PM   #10
caffeine
Oddometer: 962
i thought so too at first, but i gave it a shot anyway.....after quite a few thousand miles fallen over in streams, into trees, and multiple crashes...they are pretty solid.
caffeine is offline   Reply With Quote
Old 03-04-2007, 03:53 PM   #11
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,990
Dave
the best IMHO.
Old 03-04-2007, 05:03 PM   #12
enduro0125
Sticks and Stones™..
enduro0125's Avatar
Oddometer: 14,304
Bar Ends or "BarkBuster" type mounts
Does any one know if Polly Heaters will work with bar ends or the type of mounts used in "Bark Buster" type guards?
AMA 487807A
enduro0125 is offline   Reply With Quote
Old 03-04-2007, 11:06 PM   #13
TwoShots
Vagabond
TwoShots's Avatar
Oddometer: 1,451
kt,
I recently installed the Oxford Heaterz. They are not soft. Not hard hard plastic, but more like hard rubber. They are a rugged design. The wiring alone is much heavier gauge than dual stars. Oxford's switch is pretty functional with eight settings. While riding 20 degree days in the mountains I have yet to get past setting #3.
Can't speak to the Hot Grips other than to say their web site sucks.
Good luck.
TwoShots screwed with this post 03-04-2007 at 11:08 PM Reason: clarity
TwoShots is offline   Reply With Quote
Old 03-05-2007, 02:07 AM   #14
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,990
yeah, they'll work. they get shoved in a little further, but they get so smoking hot it doesn't matter.
Old 03-05-2007, 12:29 PM   #15
jdmetzger
Lone Wolf
jdmetzger's Avatar
Oddometer: 3,384
Are you using the "motorcycle" ones, or are you using the snowmobile ones? They both use the same amount of power, but it says the motorcycle ones are set tp run a little cooler. Seems to me you'd want them to run as hot as possible...
jdmetzger is offline   Reply With Quote
Times are GMT -7.   It's 06:15 PM.
