Old 09-17-2010, 05:48 PM   #1546
P B G
Oddometer: 10,001
Originally Posted by Strong Bad
Filling with concrete is a brilliant idea!! The combo of through-bolts and concrete would work indeed!!!
Might want to coat the inside of the pipe w/ something too, i'm thinking, might not matter, but cap the bottom and roll it around w/ some por 15 inside, let that set, and that should further prevent the pipe rusting out.
Hope he never wants to remove them...
Old 09-17-2010, 06:07 PM   #1547
fxstbiluigi
crash test dummy
fxstbiluigi's Avatar
Oddometer: 12,112
6" sch. 40 pipe will hold roughly 1.4 cu.ft. of concrete per Ft. in length and @ 3,000 lbs/27 cu.ft. It don't take much 6" pipe to get really heavy and with about 4' of it burried in the ground and 4' or 5' above ground. You shouldn't have to worry about anyone moving it.
The basic question of politics is "Who does what to Whom?". -Vlademir Lenin.
"Politicians are always interested in people.
Not that this is always a virtue.
Fleas are interested in dogs." -P.J.O'Rourke
fxstbiluigi is offline   Reply With Quote
Old 09-17-2010, 06:10 PM   #1548
P B G
Oddometer: 10,001
Gate shouldn't sag very rapidly either...
Old 09-17-2010, 07:50 PM   #1549
big jer
big jer's Avatar
Oddometer: 86
tigging magnesium
i' have never tryed tig welding magnesium, have done lots of steel, ss steel, and alum. but ain't tryed magnesium. soo my questions are, what is the proper tungston pure, 2% thoriated? what gas argon, helium, mix, grind tungston, or ''ball'' it , ac, like alum? or dc? thanks for the advice.
big jer is offline   Reply With Quote
Old 09-18-2010, 09:32 PM   #1550
gatorgrizz27
Oddometer: 133
Originally Posted by sakurama
So after that I got cocky and decided to do a full stainless system for my Hypermotard out of 1.75 .035 wall (20ga I think).I found some test pieces and despite perfect prep I kept getting black crap at the back of the weld. I took it to my fabricator friend thinking I was just dumping too much heat (50-70amps) and I'd get a lesson but his welds weren't any better. Since he does heavy giant steel I guessed he lacked the touch only because our master builder in the shop welds that stuff all the time with no back purging and his welds are clean.
What gives? When I ask him he says, "I don't know - it's just how I do it. I'm not a welder either I just taught myself." So I'm confused.
We don't have a purge system in the shop. What do they look like and how do they work?
To get a good weld on stainless you do have to purge the backside of the weld with pure argon. You can do this with spare argon tank and reg, and with exhaust it should be fairly easy. After everything is tacked, tape up one end completely then the other end as well, and feed the hose through a small hole in the tape. Set the reg to around 15 cfh and let it run for a minute or 2 to purge out the oxygen in the pipe. After that you should be able to weld it perfectly.
gatorgrizz27 is offline   Reply With Quote
Old 09-19-2010, 07:43 AM   #1551
NitroAcres
MotoBiggots Suck
NitroAcres's Avatar
Oddometer: 524
AC is all I have ever used..
Tungsten choice depends on the machine, Older/Sq Wave= Pure (ball), Inverter=Ceriated, grind to a truncated point and it will slightly ball on it's own).
Gas choice is dictated by your machine again and how thick the section is, thinner stuff pure argon is good, thick/big sections that your machine is maxed out on go with Ar/He mix.
Wire and base metal should be CLEAN, and free from any oxidation, oil, etc. Mg wire will oxidize while you are watching it..:) (You can stick Mg to Alum...but it will not hold).
NEVER take the gas flow away from the molten pool...EVER till it is solidified.
It welds alot like aluminum only it solidifies quicker.
With ANY grinding / cutting / filing, it will make dust, with that you can start a fire with just the dust or saw chips and grinding steel sparks on the same machine (like a belt sander) or even one close to it...it will flare..and you won't put it out...till it runs out of oxygen or fuel...NO WATER...and a fire extinguisher only makes it worse, (unless you are trained to put it out).
I am sure I left out a TON of precautions to take...however it can be welded and it isn't that hard really, just be careful with it..
NitroAcres is offline   Reply With Quote
Old 09-19-2010, 11:14 AM   #1552
MODNROD
Perpetual ponderer
MODNROD's Avatar
Oddometer: 2,120
I just read the lot.
You blokes have no idea how much my head hurts........
Give me electrickery anyday......
I'm not a welder's bum, but I can weld stuff (mild steel) so it stays together. I was told welding stainless in thin guage like 1.2mm is the same as welding mild steel in 1.6mm thickness, due to the hardness of the stainless pipe. Is this the case, or is the 1.2mm stainless easier to put a hole through than 1.6mm mild steel?
Nothing structural, just exhaust systems.
Gasless MIG, 0.9mm flux-core.
Damn my head hurts......
Who the hell would drag race a Ducati?!?!?!?!
http://www.dragtimes.com/Ducati-Mons...lip-10329.html
MODNROD is offline   Reply With Quote
Old 09-19-2010, 11:31 AM   #1553
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,887
The same thickness of SS burns through easier because heat moves through the material slower.
You'll be using gassles SS flux core wire? I've never seen that.
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside is offline   Reply With Quote
Old 09-19-2010, 11:48 AM   #1554
MODNROD
Perpetual ponderer
MODNROD's Avatar
Oddometer: 2,120
No, me neither!
Just normal flux-core for mild steel, but was going to upgrade to a gas set-up if the test pieces worked out OK.
Just wasn't sure how the SS compared to mild when welding.
Old 09-19-2010, 12:08 PM   #1555
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,887
No, me neither!
Made me look! Check the bottom of this page for Flux Cored Stainless Steel Wire, ER 308 - FCO (For Gasless Welding)
http://us-forge.com/Products/Welding/mig.htm
Note: SS filler needs less current.
Old 09-19-2010, 01:13 PM   #1556
big jer
big jer's Avatar
Oddometer: 86
thanks for the help, pretty much like i had guessed. they were a set of twine arms off of an old freeman hay baler. an yes it does weld alot like alum, an prep is the same, CLEAN. i have heard iron powder will put out , or smother it out, i was quite careful with the grinding during prep. thanks again.
Old 09-20-2010, 09:04 AM   #1557
Fe Man
I am Iron Moran!
Fe Man's Avatar
Oddometer: 8,366
Originally Posted by P B G
He could just buy cattle gate style hinges with the 10" of allthread, drill holes and bolt the hinges to the post,
Sink the posts in concrete, then fill the post with concrete like those posts designed to stop cars.
It would hold together a good long time I'd bet. Particularly if once it rusts up they por 15 and then paint the iron.
How hard is cast iron to cut and drill?
Physics, gravity, and law enforcement are the only things that prevent me from operating at my full potential
Fe Man screwed with this post 09-20-2010 at 10:15 AM
Fe Man is offline   Reply With Quote
Old 09-20-2010, 04:08 PM   #1558
fxstbiluigi
crash test dummy
Oddometer: 12,112
Cast Iron is really soft. a good sharp drill bit will go thru quite easily and it can , if necessary, be cut without much effort with a hack saw. Drill mounting holes and mount the gate prior to filling with concrete, rent a concrete vibrator to get the mud past the mounting bolts and to make sure there are no voids in the pipe............ edit. Don't know if I need to mention this or not..... but here it is anyway... make sure the drill bit is at 90 degreess to the pipe when it penetrates the other side and use a good level, when you set the post in concrete, to be sure the post is plumb.
fxstbiluigi screwed with this post 09-20-2010 at 06:17 PM
Old 09-29-2010, 06:37 PM   #1559
xtop20A
xtop20A's Avatar
Oddometer: 1,599
correct filler rod for tig weldind side case
ok what i am trying to do is have the weld come as close as possible to the in color/shade of the original base metal.i am needing to weld a side case for an old italian bike.1965 parilla garelli kl125 to be specific. thanx fer any hep
xtop20A is offline   Reply With Quote
Old 09-30-2010, 07:27 PM   #1560
fxstbiluigi
crash test dummy
Oddometer: 12,112
Parts need to be wire brushed or chemicaly cleaned to remove oxidation and any other contaminates before they can be welded.Which will result in a bright finish. If your intention is to hide the welded part there are several firearms refinishing business that can probably oxidize the case to look authentic.
Times are GMT -7.   It's 04:44 AM.
