Old 10-14-2010, 09:57 AM   #1576
Fe Man
I am Iron Moran!
Fe Man's Avatar
Oddometer: 5,937
Is there an easy way to determine which liner is installed in my Lincoln Weld-Pak 100?
They called my son a "subversive" because he wrote a story about cutting all his teacher's heads off...
2006 Tiger
2008 KLR (hers)
Fe Man is offline   Reply With Quote
Old 10-14-2010, 01:55 PM   #1577
fxstbiluigi
aka Road Monster
fxstbiluigi's Avatar
Oddometer: 10,628
Send a message via Yahoo to fxstbiluigi
What does it look like?
The basic question of politics is "Who does what to Whom?". -Vlademir Lenin.
"Politicians are always interested in people.
Not that this is always a virtue.
Fleas are interested in dogs." -P.J.O'Rourke
fxstbiluigi is online now   Reply With Quote
Old 10-14-2010, 01:56 PM   #1578
fxstbiluigi
aka Road Monster
Oddometer: 10,628
Originally Posted by pablo83
Can I weld 6061 to 3003? If so, would I use 4043 filler?
That will work.
Old 10-15-2010, 11:58 AM   #1579
Fe Man
I am Iron Moran!
Fe Man's Avatar
Oddometer: 5,937
Approximately the same as the .030 liner coiled up in the Lincoln plastic bag...
2006 Tiger
2008 KLR (hers)
Old 10-15-2010, 12:20 PM   #1580
fxstbiluigi
aka Road Monster
Oddometer: 10,628
The metal liner is for mild & stainless, The one that looks like a plastic tube is teflon an suiteable for alum.
Old 10-24-2010, 01:14 PM   #1581
DaBit
Oddometer: 344
I have some 1" round solid C45E H6 steel stock originally intended as 'shaft steel'.
Can I (TIG-)weld 4mm (5/32") thick 'normal' steel tabs on this rod? The C45/1045 steel contains more carbon than normal steel.
Regular ER70S2 filler rod OK? Preheat? If yes, how much?
I haven't yet welded such 'thin' metal to such a 'massive' block of steel before. Any tips?
(besides directing most of the heat to the massive block)
DaBit is offline   Reply With Quote
Old 10-24-2010, 02:38 PM   #1582
fxstbiluigi
aka Road Monster
Oddometer: 10,628
The ER70S2 will work. As for pre-heat 350 f should be enough. Depending on placement and number of tabs the shaft may wind up looking like a banana, you can either use heat or a hydraulic press to straightn the shaft after it has cooled.
Old 10-24-2010, 10:19 PM   #1583
DaBit
Oddometer: 344
OK, thanks.
I intend to make a few spacers out of it, so warping is not really an issue.
Old 10-26-2010, 05:36 PM   #1584
kirkster70
moto junkie
kirkster70's Avatar
Oddometer: 1,643
Question 1)
When MIGing a stainless exhaust tip to a stainless muffler, do I need stainless filler wire, or is ER70S6 (I think I got that number right) acceptable? Any drawbacks to this if it is acceptable?
Question 2)
Miller recommends an Argon / CO2 mix on my particular MIG for mild steel. If I temporarily used pure Argon until I get my C25 tank filled, would there be any negative results?
Thanks in advance.
kirkster70 is offline   Reply With Quote
Old 10-26-2010, 06:15 PM   #1585
fxstbiluigi
aka Road Monster
Oddometer: 10,628
Originally Posted by kirkster70
Question 1)
Question 2)
Thanks in advance.
Q-1. yes you need a stsinless fill wire. ER70S6 is a mild steel wire and SS cannot be welded with mild steel. However M/S can be welded with S/S (works but not recommended)...... Q-2 The recomended shield gas for MIG with S/S is either Tri-Mix (#1) or 75/25. Pure agon will work but it is kinda spendy to be using with a wire mach. CO2 will not work with S/S. When welding M/S to stainless use ER309L and Tri-mix, with wire mach or pure Argon with a TIG set up.
Old 11-04-2010, 07:25 AM   #1586
Pablo83
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,445
Just wanted to show off some recent work. Here is an intercooler I'm building for a bike. My aluminum welding has come a long way, but there is still a lot to be desired. My biggest problem is tacking up the work. No matter how much I clean the piece, I find it very difficult to get the filler rod to join the weld pool the first time I dip it. I've also tried pre-heating the work, but that doesn't seem to help either. Any suggestions?
Pablo83 is offline   Reply With Quote
Old 11-04-2010, 09:09 AM   #1587
fxstbiluigi
aka Road Monster
Oddometer: 10,628
Clean the fill wire.
Old 11-04-2010, 09:46 AM   #1588
Pablo83
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,445
with a wire brush?
Old 11-04-2010, 09:57 AM   #1589
fxstbiluigi
aka Road Monster
Oddometer: 10,628
with a wire brush?
Acetone,wood alcohol,MEC. NOT Brakekleen or any electricle cleaner. Good lookin welds btw.
Old 11-04-2010, 02:54 PM   #1590
Pablo83
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,445
Thanks, I'll try it.
Times are GMT -7.   It's 08:49 AM.
