Old 12-28-2010, 05:22 PM   #1681
kirkster70
moto junkie
kirkster70's Avatar
Oddometer: 1,905
Fuel tank thickness...
Is 18 ga. mild steel heavy enough for fabricating a fuel tank?
Thanks, Kirk.
kirkster70 is offline   Reply With Quote
Old 12-28-2010, 05:26 PM   #1682
fxstbiluigi
crash test dummy
fxstbiluigi's Avatar
Oddometer: 12,114
Thanks, Kirk.
dementions of tank?
The basic question of politics is "Who does what to Whom?". -Vlademir Lenin.
"Politicians are always interested in people.
Not that this is always a virtue.
Fleas are interested in dogs." -P.J.O'Rourke
fxstbiluigi is offline   Reply With Quote
Old 12-28-2010, 06:19 PM   #1683
kirkster70
moto junkie
kirkster70's Avatar
Oddometer: 1,905
Originally Posted by road ranger View Post
dementions of tank?
Not sure off the top of my head, but I'm thinking of extending a stock DR350 3 gallon tank to closely resemble the Acerbis 4.25 gal. plastic tank.
I may go slightly larger to get 5 gal. capacity. I will also fab some crash bars for protection of the tank.
Old 12-28-2010, 06:27 PM   #1684
fxstbiluigi
crash test dummy
Oddometer: 12,114
So we are talking about compound angles and multiple joints? No flat surface larger than about 6" or so? Will you be able to make all the welded joints a "lap joint"? Use 14 or 12 ga around the fill spout? Gasoline weighs 6lb/gallon so any sloshing will cause flexing in the joints/welds. And you know what can happen when anything is flexed enough times in the same place. 18ga is really limber and weighs 2lbs /sqf. 14ga is considerably stiffer, and easier to weld, and weighs 3.12lbs/sqft. 16ga @2.50lbs/sqft would be the min. I would use. So figure up the total sq/ft + add some for weld and see if the weight difference between buying one or doing your own is worth the time and trouble.
fxstbiluigi screwed with this post 12-28-2010 at 07:02 PM
Old 12-28-2010, 07:31 PM   #1685
perterra
perterra's Avatar
Oddometer: 7,400
Thanks, Kirk.
Depending on the design it could be more than heavy enough. I'd skip the lap joints and go straight butt welds. The guys I know who do that sort of stuff say laps make for joints that are harder to leak proof. Your leak could be 4" from where it's seeping at with a lap.
perterra is offline   Reply With Quote
Old 12-28-2010, 08:56 PM   #1686
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,887
18 gauge is for sure fine, especially if you're shrinking the metal to make a typical fuel tank shape. Once the metal gets into a 3D curve/spherical shape it doesn't really flex.
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside is offline   Reply With Quote
Old 12-28-2010, 09:04 PM   #1687
kirkster70
moto junkie
kirkster70's Avatar
Oddometer: 1,905
I only asked about 18 ga. specifically because I have some scrap from a "repurposed" heavy duty shelving unit. I already made some panniers for the DR out of it today. I have 4 large shelves left and then got to thinking about the tank...hmm...I wonder! Ha Ha!
So yeah, it was free, so my cost would be my time.
Whatever joint I need to make, if I decide to go for it, I will coat the tank with POR-15, 2 part epoxy to seal the inside.
I've never made a tank before, so I wasn't even sure what thickness OEM is. The stocker already has a big dent in the side, and if I screw it up completely, no big deal. Just order the Acerbis.
If I need to buy a heavier gauge, I can do that, too.
Old 12-28-2010, 09:08 PM   #1688
kirkster70
moto junkie
kirkster70's Avatar
Oddometer: 1,905
I plan on using a bag full of sand and a body hammer / hand dolly to finesse the shapes before welding.
I've never tried this before, but I like learning new things. I'm pretty sure I can pull it off, and if so, it opens many more possibilities for ideas down the road.
Old 12-29-2010, 06:16 AM   #1689
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,353
Post that on a new thread, or your other one, when you get going. Sounds very interesting.
Jim
Old 12-29-2010, 07:45 AM   #1690
fxstbiluigi
crash test dummy
Oddometer: 12,114
Jim
Ya I'd like to see that too........... before any bondo is applied.
Old 12-29-2010, 12:01 PM   #1691
kirkster70
moto junkie
kirkster70's Avatar
Oddometer: 1,905
Will do.
I need to take some pics of recent progress to post to my rookie welder thread.
I've got my tubing bender all set up and I've been waiting 2 weeks for my tubing to show up to make racks for the DR.
Old 12-30-2010, 09:35 AM   #1692
Inane Cathode
Cheated Anion
Inane Cathode's Avatar
Oddometer: 4,601
Is there a trick to getting seamless welds (like around an exhaust fitting) with flux core mig? I can't for the life of me either a) get a good leak proof weld all the way around or b) get a seamless weld and not blow through it like its not even there.
_______
Pokey The Wunderbus
The VEEP Project
Inane Cathode is offline   Reply With Quote
Old 12-30-2010, 09:41 AM   #1693
fxstbiluigi
crash test dummy
Oddometer: 12,114
Practice,practice practice.
Old 12-30-2010, 10:18 AM   #1694
NitroAcres
MotoBiggots Suck
NitroAcres's Avatar
Oddometer: 524
A guy once ask me, "what the trick to sucessful brain surgery was", I told him to stop using a chainsaw...
NitroAcres is offline   Reply With Quote
Old 12-30-2010, 12:19 PM   #1695
kellyk7
Who knows
kellyk7's Avatar
Oddometer: 1,746
Question About Welding Stainless Pipes
I have been given a stainless mid pipe from a GSXR with carbon fiber Can that I want to put on my BWM F650 DAK I figure I can cut the Mid Pipe and then Cut the back section of the DAK pipe and weld the two together (or maybe have somebody do it)
I have a simple Lincoln AC buzz box for a welder
Questions are:
Can I use what I have to weld this pipe?
If So what rods would be recommended? I have no clue what type stainless this would be 300 / 400 series ect ?
If I can do this what would the recommended methods be?
There's a fine line between "RED ASS" and "DUMB ASS"
"Life isn't about waiting for the storm to pass... It is about learning how to dance in the rain" - HAWK
kellyk7 is offline   Reply With Quote
Times are GMT -7.   It's 10:28 PM.
