Old 01-08-2011, 08:07 PM   #1711
fxstbiluigi
crash test dummy
fxstbiluigi's Avatar
Oddometer: 12,046
Originally Posted by perterra View Post
Avesta, they make or package about 20 different alloys; it will require machining likely if you get to the mating surface if you weld it with stick electrode.
Avesta 309-16 will weld cast iron , just like 7018 welds carbon steel. It will also weld carbon steel to cast iron or stainless to carbon. It runs down hill, side ways and flat. never tried it over head. Best rod ever for dis-similar metal. Spendy but it is worth every penny. Another option would be TIG with 309-16 fill wire.
fxstbiluigi is offline   Reply With Quote
Old 01-08-2011, 08:33 PM   #1712
perterra
perterra's Avatar
Oddometer: 7,400
Originally Posted by skrub View Post
I got the rods from Cody racing. Thay list them 15.00 ea. My local supply house could only order 10# at 600 bucks. I only need two to cover one shoe. Thay are listed by Stoody for use with a gas torch. The bottom of a shoe definitely looks like its done with a torch, all puddles and irregular. The rods are bare and round
They are torch rods if from stoody.
perterra is offline   Reply With Quote
Old 01-08-2011, 08:41 PM   #1713
fxstbiluigi
crash test dummy
Oddometer: 12,046
Cody racing is the problem there. go to your local welding supply dealer. I would be willing to bet you can buy them in 1lb increments . you may also want to look at a TIG outfit
fxstbiluigi screwed with this post 01-08-2011 at 08:50 PM
Old 01-09-2011, 08:40 AM   #1714
kellyk7
Who knows
kellyk7's Avatar
Oddometer: 1,746
I need Advice on welding Expanded metal grate
one of my biggest challenges is welding Expanded metal to angle or box to make a rack.
I need advice on how to accomplish this with the best result.
I have an AC - 225 buzz box.
my favorite rob is the 7014 followed by 6013
my biggest problem is that the thin metal does not tolerate much heat
There's a fine line between "RED ASS" and "DUMB ASS"
"Life isn't about waiting for the storm to pass... It is about learning how to dance in the rain" - HAWK
kellyk7 is offline   Reply With Quote
Old 01-09-2011, 04:13 PM   #1715
skrub
Oddometer: 258
Thanks for all the advice. I'll be talking with the fella at my supply shop this week, he uses a similar rod with abrasives to tractionize horse shoes for the winter. My nephew has offered me two machines all I have to do is make a trip to Texas and pick them up. Thermal Dynamics pak master 100xl plasma cutter and a Miller Syncrowave 250 200 230 460 volt. I think this is a Tig and stick. This is all the info he gave me. Got any more info ??
skrub is offline   Reply With Quote
Old 01-09-2011, 04:40 PM   #1716
Strong Bad
n00balicious
Strong Bad's Avatar
Oddometer: 4,198
I'm making my own steel shoe for flat track racing. I have a hard surface rod thats applied with a torch. Its not a flux core rod. I'm guessing this is like brazing and I need some form of flux. Thanks for any help.
I know this might sound strange....... but try using Borax hand soap. Heat the rod slightly and dip the rod in the Borax, it will stick to the rod. Super Old School.
"I couldn't wait for success, so I went ahead without it."
Strong Bad is offline   Reply With Quote
Old 01-09-2011, 05:21 PM   #1717
nessy357
Oddometer: 59
Try using 3/32" 6011P or 6011, faster freezing rod , with good penetration.
nessy357 is offline   Reply With Quote
Old 01-09-2011, 05:22 PM   #1718
perterra
perterra's Avatar
Oddometer: 7,400
You can find the manuals for the syncro 250 on Millers web site. Good machine, the pakmaster 100 is fine too.
Old 01-09-2011, 09:39 PM   #1719
mark1305
Old Enough To Know Better
mark1305's Avatar
Oddometer: 6,031
I don't have an arc welder, just MIG, but have had to stitch expanded mesh to flat and angle stock. I just try to make the mesh cuts along a line that gives me all closed ends in the mesh rather than open spots with two little ends to weld down. Then just zap each point quickly, starting the weld aiming at the flat or angle stock to initiate penetration then leading the puddle to the end point on the mesh. As soon as you reach the mesh with the arc, stop before burning through the smaller cross section of the expanded mesh.
More or less a "BZZZT...BZZZT...BZZZT..." as you move from each point on the eadge of the mesh to the next.
Mark J
Merritt Island, FL
When a person asks you for advice, they don't want advice. They want corroboration.
mark1305 is offline   Reply With Quote
Old 01-10-2011, 05:15 AM   #1720
kellyk7
Who knows
kellyk7's Avatar
Oddometer: 1,746
I have a can of 6011, it has been a while since I burned one, if I remember correctly i had trouble getting them to run right, I may have to burn a few on some scrap to get a feel for it.
Old 01-10-2011, 05:16 AM   #1721
kellyk7
Who knows
kellyk7's Avatar
Oddometer: 1,746
Thanks - I will try this . Like so many things welding seems to be one of those things that you just have to feel. and it takes time to get that feel.
Old 01-10-2011, 09:00 AM   #1722
Pablo83
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,809
I don't use my stick welding electrodes enough to keep them fresh, but I need to keep some around the shop for the rare times I need them. I currently keep them in the plastic tubes with the big rubber O-ring, but that's not doing the job. I guess I need an electrode oven, but I was wondering if there any cheaper options? If not, I guess I'm looking for a Keen K-200 oven. Anyone have any experience with this unit, or similar ones? I'll probably be storing about 5-10 different types of rod at about 10# each.
Pablo83 is offline   Reply With Quote
Old 01-10-2011, 09:14 AM   #1723
kubiak
Oddometer: 4,829
i use a old refrigerator that doesnt work anymore to store my tires, paint and welding rods. they keep the stuff pretty good in really hot or really cold temps form the different seasons. they keep the temps stable and moisture out.i have two refrigerators right now but waiting for another one to break so i have a third for storage!
Old 01-13-2011, 08:10 AM   #1724
newcastleadam
Artful Tagger
newcastleadam's Avatar
Oddometer: 3,455
Feedback
Local guy selling what he describes as a Lincoln 125 Nascar edition for $150. Pretty sure he means this unit (could also be this). Here's the pic he provided:
Going to look at it and a few other items tomorrow. Use would be 1/4" steel at most, would like to try aluminum, and really just start learning to weld. As such this unit sounds like a good deal. Thoughts?
Adam
86 KLR250 01 KLR685 06 K1200LT
As ever, buyer and seller of all things KLR
KLR Doohickey Wrench available!
The North Florida Tag-O-Rama wants YOU!
newcastleadam screwed with this post 01-13-2011 at 08:49 AM
newcastleadam is offline   Reply With Quote
Old 01-13-2011, 08:18 AM   #1725
Benesesso
Benesesso's Avatar
Oddometer: 9,898
Unless your metal is pretty rusty, forget 6011 and get some thin (3/32") 7024. It has a thick iron powder flux, so 3/32" looks as fat as 1/8" 6011.
Crank the amps way up and just shove the rod into the metal--zap, you're welding. Doesn't penetrate deeply, but the arc is very easy to start. Won't make very tough/ductile welds like properly stored 7018, but few of us need those properties.
US out of the UN, UN out of the US.
Benesesso is offline   Reply With Quote
Times are GMT -7.   It's 06:53 AM.
