Old 02-08-2011, 06:44 AM   #1771
trailer Rails
trailer Rails's Avatar
Oddometer: 4,306
Originally Posted by pablo83 View Post
The TTR125 is kind of a kid's bike. I can't imagine it has magnesium covers. All of the Yamaha's that I've worked on that have magnesium covers have the word "magnesium" cast into the cover. This cover has "Alumec" cast into it.
Does anyone know what Alumec is?
The reason I'm welding it instead of using epoxy is the oil fill hole is cracked. It needs to be welded so the threads can be re-cut.
That is a lot of work to save a clutch cover, have you priced a new one out to see if it is worth doing? Yamaha's prices for OEM parts can be pretty cheep sometimes.
Don't rule out the epoxy yet, you can cut threads into the quick steel epoxy too, FYI.
Sorry, I have no idea what Alumec is.
trailer Rails is online now   Reply With Quote
Old 02-08-2011, 07:23 AM   #1772
Rottweiler
I'm a Believer
Rottweiler's Avatar
Oddometer: 365
Google is your friend.
https://www.alcoa.com/mill_products/...ec/en/home.asp
http://www.uddeholm.com/files/PB_alumec_english.pdf
http://www.blackburnsmetals.com/prod...te-alumec.html
2002 Suzuki DL1000 V-Strom - blue
2001 Honda Reflex NSS250 scooter - silver
Real men wear boots. God is good.
"Liberalism is a philosophy of consolation for Western Civilization as it commits suicide." - Dr. Jerry Pournelle http://jerrypournelle.com
Rottweiler is offline   Reply With Quote
Old 02-08-2011, 08:50 AM   #1773
Pablo83
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,815
Thanks. It looks like some of the Alumec alloys are weldable, but filler info seems pretty sketchy. I guess I'll be trying 5356.
Pablo83 is offline   Reply With Quote
Old 02-08-2011, 09:26 AM   #1774
fxstbiluigi
crash test dummy
fxstbiluigi's Avatar
Oddometer: 12,121
thanks. It looks like some of the alumec alloys are weldable, but filler info seems pretty sketchy. I guess i'll be trying 5356.
4043
fxstbiluigi is offline   Reply With Quote
Old 02-08-2011, 06:45 PM   #1775
Pablo83
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,815
Originally Posted by fxstbiluigi View Post
4043
Something I read today also suggested that 4xxx filler might be better, but I had the 5356 in the shop already so I used it. It welded up just fine. I thought this would be a bit of a pain, but it really wasn't.
Thanks guys.
Old 02-09-2011, 06:55 PM   #1776
KTM640Dakar OP
Motorsick
KTM640Dakar's Avatar
Oddometer: 2,111
Yes 4043 filler. Here is a link to handy welding guides. They are free. There is one for aluminum welding C8.10 and also C4.200 is excellent info for MIG welding.
http://www.lincolnusmarketing.com/pr...asp?cat=CAT003
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
It is not the destination, it's the journey.
KTM640Dakar is offline   Reply With Quote
Old 02-10-2011, 04:55 PM   #1777
Shuffler
Hommes Grande
Shuffler's Avatar
Oddometer: 1,687
Originally Posted by Shuffler View Post
yeah I get confused with volts this and amps that....not being an electrician I dunno what it all means in terms of what I can run on my circuit...
I do know I have a 240v wall receptacle and my heater has a 240v plug, but the Lincoln info says inputs are 230v and 20a, so can I even plug the thing in without having to replace the receptacle or change the plug on the cord (?)
http://content.lincolnelectric.com/p...ature/e724.pdf
For those of you looking at MIG machines, per Lincoln tech support they say I need to have a dedicated 40A circuit for the 180C PowerMIG...so my setup won't work for that machine, or the Millermatic 180.
I may just go with the Lincoln or Miller 140 to start since I can use a standard outlet...
________________________________
AMA | COHVCO | TPA | NCTR | BRC
KTM 950A | KTM 300XCW | BMW R1100RT
Shuffler is offline   Reply With Quote
Old 02-14-2011, 08:34 PM   #1778
HickOnACrick
Groovinator
HickOnACrick's Avatar
Oddometer: 2,504
I wanna do some lernin'
I would love to learn how to weld. I want to learn the proper way so I am safe, and the things I make are structurally sound as well as aesthetic. Ultimately, I want to learn to weld aluminum.
Where does a guy go to learn something like this? I am willing to pay for classes.
I live in West Texas, BTW.
KTM 500 XCW, BMW K1600GTL
950 SER 300 XC
Composites 101
Utarded in Baja
Circumcising Utah
HickOnACrick is offline   Reply With Quote
Old 02-15-2011, 07:00 AM   #1779
Pablo83
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,815
Usually community colleges are a good bet. Your local welding supply store will probably be able to point you in the right direction as well.
Old 02-15-2011, 01:00 PM   #1780
kellyk7
Who knows
kellyk7's Avatar
Oddometer: 1,746
HELP I may be Hosed
Ok i took my Muffler to a welding shop and they said no problem, now they say that can not weld it
Does anybody know what metal the pipe/muffler on a BMW F650GS is made of
I also have the flange from a 2005 GSXR 1000 mid pipe to weld to the original BMW pipe
What I am trying to do is cut the muffler off the BMW pipe then weld the flange from GSXr pipe to that and make a mid pipe I can use to bolt the GSXR can to
the welder thought both pipes were same metal
neither are magnetic
any Ideas?
There's a fine line between "RED ASS" and "DUMB ASS"
"Life isn't about waiting for the storm to pass... It is about learning how to dance in the rain" - HAWK
kellyk7 is offline   Reply With Quote
Old 02-15-2011, 01:07 PM   #1781
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,527
You need a more knowledgable welder. The BMW pipe is definitely stainless. I am at my limit here though. Surely someone else will chime in.
Jim
Old 02-15-2011, 01:42 PM   #1782
kellyk7
Who knows
kellyk7's Avatar
Oddometer: 1,746
Ok I may have taken my hack saw to the pipe just a bit too quick
It appears that the Suzuki mid pipe is actually made of Titanium
if the BMW piece is stainless it would be a 300 alloy due to no magnetic
Old 02-15-2011, 05:59 PM   #1783
Pablo83
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,815
If you left enough room you could have a muffler shop flare the mid pipe and slip the muffer pipe into it.
Old 02-15-2011, 06:28 PM   #1784
kellyk7
Who knows
kellyk7's Avatar
Oddometer: 1,746
in a way that was my original plan but the mid pipe had a crazy little bend that was just not doable
I have found a source for 3 inch wide 304 stainless .25 thick strap they sell by the foot for about 14.00 so i can make a flange of stainless and have it welded to the pipe
should be easy and work pretty clean
Old 02-15-2011, 06:36 PM   #1785
fxstbiluigi
crash test dummy
Oddometer: 12,121
304 stainless isn't a real good choice for applications envolving much heat.
Times are GMT -7.   It's 10:42 AM.
