Old 04-21-2007, 11:10 PM   #166
markjenn
Oddometer: 9,698
A friend of mine was cleaning out his garage and it looks like I've inherited his small MIG welder (A "Multi-Mig 90090" - I have no idea how old it is). So I thought I'd give this welding thing a try. Looked at the local community college and there appears to be a two-evening MIG course not too far away (Discover U in Seattle) so maybe I'll sign up.
My friend included his welding helmet, but strongly recommended I invest in one of the auto-darkening models. Any recommendations in this area for something that isn't too expensive, but is also safe for the eyes?
- Mark
Old 04-21-2007, 11:20 PM   #167
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,285
Cool, you'll have great fun.
Aww heck Mark, I think you're gonna need one of the $300 models with the optional 'sparkles'. The $50 Harbor Freight auto-dark will leave you blind
- Jim
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List
Poolside screwed with this post 04-22-2007 at 02:22 PM
Poolside is offline   Reply With Quote
Old 04-22-2007, 10:28 AM   #168
markjenn
Oddometer: 9,698
AMy friend included his welding helmet, but strongly recommended I invest in one of the auto-darkening models. Any recommendations in this area for something that isn't too expensive, but is also safe for the eyes?
I looked on a few of the welding forums and found that this question is essentially the welding equivalent of of an "oil thread", particuarly the range of opinions on the HF auto-darkening model.
- Mark
Old 04-22-2007, 02:19 PM   #169
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,285
Heh heh. VERY true.
The auto-dark isn't as much of a convenience with MIG because the torch and wire are right where you want them before you flip the helmet down and pull the trigger.
An automatic lens is a lot more useful when trying to start a stick electrode. At least for a novice end-user like me
A first timer gotcha that's relevant to any type lens. Any light behind your head will reflect off the back surface of the glass like what happens to a computer monitor facing a window.
And a gotcha for for LCD automatics . . . The LCD lens has multiple layers of glass and plastic. There is internal reflection between layers, and refraction within the layers. This creates a 'ghost image' visible from the subjective surface. It take a little practice to train your eye to select the 'real' image.
- Jim
Old 04-22-2007, 08:28 PM   #170
Gasket
Wandering Samurai
Oddometer: 195
Originally Posted by KTM640Dakar
Do you have a question about welding? How to weld a material or which welding process to use? MIG, TIG, stick, oxyfuel?
I will tell you up front that I am a Welding Engineer for The Lincoln Electric Company so if I sound bias to my company's products, well.. I am.
So tell us about your welding project?
I don't want to slog through all of the comments so please to answer me one question. Do I want a MIG or a TIG welder? I am building a new garage next to the house in order to have room to work on my bikes and do a bit of restoration. I am one of those who is a bit confused as to the difference in welders. I want to have one to work my bike projects so if I can have one, what should it be....
Mike
Pacific Northwest
2007 Triumph Rocket III Classic Tourer
1967 Triumph TR6C
Gasket is offline   Reply With Quote
Old 04-27-2007, 08:20 AM   #171
KTM640Dakar OP
Motorsick
KTM640Dakar's Avatar
Oddometer: 1,703
Hi Gasket,
A MIG welder (Metal Inert Gas), is a welding process which uses a metal wire (on a spool) that is fed through a welding gun and cable and delivered to the arc at a constant rate. This electrified wire is considered the electrode. Unlike stick welding where you only have a 14 inch long electrode that melts after making a 4 to 5 inch long weld. A MIG weld can go longer since you can have a longer electrode that is in the form of a spool of wire. In both MIG and stick welding the electrode is used as the metal filler.
In TIG welding (Tungsten Inert Gas), the electrode is a sharpened piece of Tungsten that does not melt away or become part of the weld. The Tungsten electrode is a 6 inch long heat resistant material that carries the electricity and is used as a heat source. Your metal filler is usually in the form of a rod or stick of metal that you add seperately to the molten metal that melts under the Tungsten electrode or arc.
MIG welding is easier to learn, TIG welding requires more skill.
MIG welding requires you to change your filler wire in order to weld different metals. TIG welding can weld all metals (with a few adjustments to the machine and changing filler rods).
TIG welding equipment is usually more expensive than MIG welders.
TIG welders are more flexible when changing over from welding steel to aluminum.
A TIG welder will also stick weld.
If you only had one machine and are going to weld many types of metals and have time to learn to proper techinque then buy a TIG welder.
If you only plan to weld steel and want to use an easier process then buy a MIG welder.
Both will require you to buy a bottle of shielding gas.
If you want to avoid buying a bottle of gas then stick welding or use a gasless MIG wire (also called a Flux Cored wire or Innershield wire.)
FCAW is Flux Cored Arc Welding and is a variation of MIG welding. It uses the same MIG welding machine but the wire is hollow and contains flux in its core. Think of flux cored welding wire as stick electrode with the flux on the inside instead of the outside. It has the benefits of MIG without the shielding gas. The downside is the resulting weld will look like a stick weld instead of the better looking appearence of a MIG weld. Also you have to chip the slag off of your weld (like a stick weld) which you don't have to do with a MIG weld that uses shielding gas.
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
It is not the destination, it's the journey.
KTM640Dakar is offline   Reply With Quote
Old 04-27-2007, 11:06 AM   #172
KLboxeR
Back in the game again
Oddometer: 3,644
Hi Gasket,
Fantastic rundown of the different processes
KLboxeR is offline   Reply With Quote
Old 04-27-2007, 11:14 AM   #173
KLboxeR
Oddometer: 3,644
I don't want to spam or hijack this thread, but I'm probably going to sell my high-end Jackson auto darkening welding helmet. There seem to be many new weldors involved in this thread so I figure this would be a good chance to pass along a great, lightly used, helmet to a fellow ADVrider at a terrific price. Nothing wrong with the helmet, I just have another that I like alot better. PM me if interested in details.
Mod: If this should go in FM, please delete or let me know.
Old 05-02-2007, 07:18 PM   #174
Ducky 149
Oddometer: 212
It appears that our welding guru (KTM...) is affiliated with team red. I was looking on Fleabay for a little garage mig welder so I dont have to take all my stuff into work to get welded. I found that Lincoln, Miller,and Hobart are the big players in this field. What are the Pros and Cons of the different brands? I am trying to compare apples to apples etc. Looking in the 135 amp area. Some thing I can learn to weld better on and not out grow in the future. I would like to stick to something that will run on 110V.
Thanks in advance for all the replies. Scott.
"I can't believe I threw up in front of Dean Wormer!!!! Kent, You threw up on Dean Wormer"
Ducky 149 is offline   Reply With Quote
Old 05-03-2007, 03:53 AM   #175
KLboxeR
Oddometer: 3,644
I've got a little Miller 135 that is a terrific machine. It gets thrown in the truck all the time to go out and do field repairs and consequently gets beat up alot. Still runs great after 4 years. I think it's the 140 now and they've added some features. Whatever you get, make sure it will run inert gas. Much better welds than the flux core only machines.
I doubt you'll find a stick machine in 110, but you can get a good tombstone (named because they are shaped like a tombstone) welder pretty cheap in 220. Just hook it up to the dryer or stove outlet with an extension cord. Make sure you don't exceed the amperage of the breaker or wire in the circuit, though.
Chris
Old 05-03-2007, 07:13 AM   #176
bmwblake
upside down parker
bmwblake's Avatar
Oddometer: 3,238
i ended up buying a millermatic 140 with autoset.
both the local welding shops have more miller stuff, and several local guys that do it for a living said to go blue.
it's a 110 machine and so far has worked well in the little bit of time that i've used it.
btw, sheet metal is way harder than heavier stuff.
bmwblake is offline   Reply With Quote
Old 05-03-2007, 09:17 PM   #177
Dano 407
One Man Wolfpack
Dano 407's Avatar
Oddometer: 5,621
Opinion: Red.
Run gas on it (and shut the bottle off at the end of the session!) and experiment with wire size .025 or .030 depending on what you are playing with.
Nothing at all against the other brands. I have 4 blue machines and 17 red ones. The blue ones are fine, as I am sure the Hobarts are, but I like Red.
D
Juggling the fun bags
Dano 407 is offline   Reply With Quote
Old 05-09-2007, 08:33 PM   #178
KTM640Dakar OP
Motorsick
Oddometer: 1,703
Gosh Ducky you know I'm going to recommend the 110V Lincoln Power MIG 140 as a new machine or an SP135T or SP135Plus from E-Bay. The key to sucess with the 110V machines is there low end. Being able to weld thin metal is why those machines are popular. Look for the quality and warranty that each manufacturer offers. Lincoln Electric has a three year warranty standard and you can extend that out to five years if you want for a small fee.
Old 05-29-2007, 06:08 PM   #179
nfranco
over macho grande?
nfranco's Avatar
Oddometer: 707
So I'm having my scotts damper tower welded on tommorrow and I just want to make sure I've got this right. I removed all the paint around the area to be welded, removed the tank and drained the carb and removed the battery. There is oil in the frame (KTM 640 Adventure) but the welding shop said it's not a problem.Anything else I've forgotten?
Thanks all. Nick
nfranco is offline   Reply With Quote
Old 05-30-2007, 08:17 AM   #180
boyscout
sittin' down
boyscout's Avatar
Oddometer: 1,319
Apologies if this is somewhere else in this thread as I haven't read the whole thing. There's a metal scrap yard in town that specializes in copper, stainless steel and aluminum. I was going to go down and pick up some aluminum to practice welding with. I know some aluminum alloys are weldable and some are not.
How can I tell whether a piece of aluminum scrap is weldable or not?
Who me?
boyscout is offline   Reply With Quote
Times are GMT -7.   It's 03:38 PM.
