Old 03-20-2011, 10:45 AM   #1876
domains
domains's Avatar
Oddometer: 162
scram1 If your into modding bikes start welding :)
I'm just a hobbie welder of a few years( used to get other people to weld my stuff)... My first welder was a Lincoln 120v mig that avertized it could weld 1/4 steel :) has a hard time doing 1/8.
I paved my driveway and the wire under it going to garage is only a 12 grade so I can only get a 120 welder.
I got a clark131 120v arc welder... Can buy 1/16 rods for light work and does 1/8 steel very nice with a 5/64 rod.
If I was to buy another 120v it would be a DC inverter... welds 3/32 rods with ease. mine can't even arc the 3/32 rods.
You can buy 4 diodes and turn a AC welder Into a DC welder.
Theres lots of projects on google for turning AC into DC
domains is offline   Reply With Quote
Old 03-20-2011, 11:08 AM   #1877
domains
domains's Avatar
Oddometer: 162
Look how nice this little 80 amp DC welder welds and cheap on shipping its under 10 pounds If you can buy a 220v welder it would be better. But with 120v You can do lots of projects with 1/8 steel.
GUY in video must me using cheap or high amp rods.
http://www.youtube.com/watch?v=9uzSR...feature=relmfu
domains screwed with this post 03-20-2011 at 11:15 AM
Old 03-21-2011, 08:15 AM   #1878
PJveetwin
LD-Ordie
PJveetwin's Avatar
Oddometer: 373
Originally Posted by Old_Lion View Post
Try this for a download of the manual in Acrobat pdf format for the Hobart ADI-364.
https://share.acrobat.com/adc/document.do?docid=39f80a75-ad14-4985-9c93-ab72359e0c49
If that does not work try this
https://acrobat.com/app.html#d=OfgKda0USYWck6tyNZ4MSQ
If you are unable to download it send me a private message with your email address and I will mail it to you.
George
Hey Old Lion,
I received all the info you sent me and now I have a lot of homework to do! I really appreciated your personal effort and also the wealth of information here on this thread. I'm looking forward to putting out a serious effort in improving my welding skills.
R/Jim
There are no problems that cannot be resolved with the proper application of explosives !
Jim
Member of "Team Pterodactyl"
Combat Touring!!
05-FJR 1300
05-650 Dakar
03-1150 GS Sport
70-FLH Shovelhead
50-FL Panhead
76- Bultaco 370 Pursang
98-Yamaha TW200
84-Yamaha TT-600
56-650 Triumph T-120, needs work......
1964 Land Rover Series IIA Gotta have at least one car
PJveetwin is offline   Reply With Quote
Old 03-21-2011, 09:27 AM   #1879
PJveetwin
LD-Ordie
PJveetwin's Avatar
Oddometer: 373
Originally Posted by KTM640Dakar View Post
Do not buy the SP250. It was a terrible machine. Your Power MIG 140 is much better.
Hey KTM,
Can you provide a little more info regarding your opinion on the SP250? I recently purchased one in new like condition with the original spool still in it. I would like to know it's flaws and current parts support.
Any info would be appreciated.
Jim
Combat Touring!!
05-FJR 1300
05-650 Dakar
03-1150 GS Sport
70-FLH Shovelhead
50-FL Panhead
98-Yamaha TW200
84-Yamaha TT-600
Old 03-21-2011, 10:23 AM   #1880
bobivey
Oddometer: 39
In response to the question from Ahar on 3-19. Take a look at the spool of wire to see if a stray piece of wire is touching the cabinet. I have seen this cause the problem you described.
bobivey is offline   Reply With Quote
Old 03-21-2011, 06:52 PM   #1881
Ahar
Retired in place
Oddometer: 407
Thanks Bob
I checked it, no metal of any kind touching the cabinet.
Sparked it up to do a little repair, the wire fused itself to the liner again and I couldn't pull it out. Wasn't going to waste $ on another liner, so I bought a new Tweeco gun. No problems now. I hope.
Ahar is offline   Reply With Quote
Old 03-21-2011, 07:23 PM   #1882
fxstbiluigi
crash test dummy
fxstbiluigi's Avatar
Oddometer: 12,187
Originally Posted by Ahar View Post
Thanks Bob
When you "pull the trigger" on the "gun" the entire spool of wire and the liner are "hot". Something has to be going to ground for there to be sparks between the liner and the wire.
Any bare spots in the protective coating covering liner and such?
fxstbiluigi is offline   Reply With Quote
Old 03-21-2011, 09:29 PM   #1883
Ahar
Retired in place
Oddometer: 407
not that I can see, but I am just as inclined to use a BFH on it now that the Tweeco is working with no problems. I will do an autopsy on the old gun to see what I can find out.
Old 03-21-2011, 10:11 PM   #1884
KTM640Dakar OP
Motorsick
KTM640Dakar's Avatar
Oddometer: 2,123
Originally Posted by PJveetwin View Post
Hey KTM,
The drop in spool holder is a poor design.
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
It is not the destination, it's the journey.
KTM640Dakar is offline   Reply With Quote
Old 03-22-2011, 04:56 AM   #1885
PJveetwin
LD-Ordie
PJveetwin's Avatar
Oddometer: 373
Does it ever fail? And if so, is there something better to replace it with?
Thanks,
Jim
Jim
Combat Touring!!
05-FJR 1300
05-650 Dakar
03-1150 GS Sport
70-FLH Shovelhead
50-FL Panhead
98-Yamaha TW200
84-Yamaha TT-600
Old 03-22-2011, 08:29 AM   #1886
David R
I been called a Nut Job..
David R's Avatar
Oddometer: 2,619
Laugh
I have a wirematic 250 which is a later version of the SP250. It still has the goofy way to load the spool. I have had no problems with it. I can get a pic if you need it. Now using a V350 pro power supply and LN9-GMA wire feeder. Wirematic 250 sits at home in the garage. Its one sweet welding machine, but inverters use less power in put for the same output. Cheaper to run.
David
2012 R1200R ! 2000 R1100RT (parts for sale!), 1976 R75/6, 2014 Vulcan 900 Trike
There is a seat for everyone.
David R is offline   Reply With Quote
Old 03-23-2011, 04:55 PM   #1887
oc_nightmare
Oddometer: 188
anyone here has welded steel a fuel tank with a smaw welder? It is so thin i'm afraid to make the hole bigger than it is now
oc_nightmare is offline   Reply With Quote
Old 03-23-2011, 06:12 PM   #1888
David R
David R's Avatar
Oddometer: 2,619
Thumbs down
I will not do them any more. I used to get them steamed out or cleaned by a radiator shop, but I'm too afraid of blowing up.
Measure the steel and weld some scrap the same thickness.
I have welded exhaust with stick, its a bitch.
David
Old 03-24-2011, 08:19 AM   #1889
Fe Man
I am Iron Moran!
Fe Man's Avatar
Oddometer: 8,513
I have a Lincoln Weld-Pak 100 and a question.
Is the cable liner a consumable; I have a spare.
It feeds fine but I have been using it for 10 years...
Thanks.
Physics, gravity, and law enforcement are the only things that prevent me from operating at my full potential
Fe Man is offline   Reply With Quote
Old 03-24-2011, 08:26 AM   #1890
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 15,231
Thanks.
You've got to run miles and miles and miles of wire before it wears out. If it feeds and welds, leave it alone...it ain't broke.
Times are GMT -7.   It's 09:48 PM.
