Old 04-01-2011, 04:06 PM   #1921
side-wayz
See Ya in the twisties
side-wayz's Avatar
Oddometer: 151
Originally Posted by Benesesso View Post
No gloves? Guess you don't do too much welding.
Just remember this: Be real careful if you weld with AC. A low AC voltage that ends up going across your chest can kill you "dead as a mackerel".
DC is far safer.
Thats whyn they don't use ac underwater. Only dc!
Side-Wayz
'00 KLR
side-wayz is offline   Reply With Quote
Old 04-01-2011, 04:15 PM   #1922
side-wayz
side-wayz's Avatar
Oddometer: 151
Originally Posted by Lomez View Post
Basic stick welder, no gas....the flux on the stick. Mine is AC output.
I'm talking about just using one hand to hold one of the items being welded, while wearing shoes....on concrete.
I use one hand to tack weld two pieces together all the time and have not been shocked, using welding gloves,and dc smaw gmaw and gtaw. I have a good ground clamp on the table. The only time I have had a little jolt is when tig welding and the end of the filler rod hit the lamp above me. I guess it shorted through me? My teacher always told us to keap the clamp away from our body because your keychain, beltbuckle etc. could hit it and light you up.
Side-Wayz
'00 KLR
Old 04-01-2011, 04:17 PM   #1923
side-wayz
side-wayz's Avatar
Oddometer: 151
Originally Posted by trailer Rails View Post
That is how you get the nice puddles. Drink more coffee.
Definately with 7018 rods!
Side-Wayz
'00 KLR
Old 04-01-2011, 04:51 PM   #1924
David R
I been called a Nut Job..
David R's Avatar
Oddometer: 2,484
Laugh
A friend was holding the bumper of a 60s VW I was laying under the car with the rod. Some how he got zapped and dropped the bumper on me. Not much to weld to under there.
I have only been zapped changing electrodes with wet gloves on. OR kept my foot on the pedal while changing tungsten.
I lean or rest on my work when I can. I always wear gloves. You only need to be burnt good once.
2012 R1200R ! 2000 R1100RT (parts for sale!), 1976 R75/6, 2014 Vulcan 900 Trike
There is a seat for everyone.
David R is offline   Reply With Quote
Old 04-01-2011, 06:18 PM   #1925
side-wayz
side-wayz's Avatar
Oddometer: 151
Once a week?
Side-Wayz
'00 KLR
Old 04-01-2011, 06:25 PM   #1926
side-wayz
side-wayz's Avatar
Oddometer: 151
Question
Got a tungsten question. We have been using pure tungsten while welding with ac with aluminum at school. I've been reading that the orange (cerium) and brown (zirconium), are better for aluminum, but have not tried it. Any advice or opinions?
Side-Wayz
'00 KLR
Old 04-01-2011, 06:56 PM   #1927
mark1305
Old Enough To Know Better
mark1305's Avatar
Oddometer: 6,029
Originally Posted by slidewayes View Post
how do i get my hand to quit shakeing
What type of welding? MIG is easiest to find a way to steady the gun on some of the workpiece or brace the gun hand with the off-hand and set up your work when possible to be able to rest one or both arms on sometung steady. Setting up the work and providing for arm rests and bracing one hand with the other will work with stick too. Steady the arms and the hands will be steadier.
I have trouble with hand twitching more than shaking, and it gives be a big PITA when cutting with OA. When I cut flat stock now, I use a piece of big angle steel sized just right to clamp along the cut line and let the torch slide along a smoothed edge. Keeps the torch the right distance off the work and makes steady clean cuts.
Hhmm..... I should make up a similar one for straight MIG welds where I'm working on a table/bench or an object I can clamp a guide onto.... Yeah, that's it.
Mark J
Merritt Island, FL
When a person asks you for advice, they don't want advice. They want corroboration.
mark1305 is offline   Reply With Quote
Old 04-01-2011, 07:14 PM   #1928
WIsixfitty
ceiling unlimited
Oddometer: 2,211
In a pinch I've used orange and red but green works the best.
sideways and smiling
WIsixfitty is offline   Reply With Quote
Old 04-01-2011, 09:38 PM   #1929
perterra
perterra's Avatar
Oddometer: 7,400
It wont produce a nice ball on the end if it's 2% cerriated or zirc, pure gives you a nice polished ball. 2% just kind of stubs off and gives you a funky pattern on a std old A/C tig machine. The newer dynastys and such allow you to adjust the frequency to use a 2% on alum.
Cerriated isnt radioactive after use as thoriated is.
perterra is offline   Reply With Quote
Old 04-02-2011, 10:18 PM   #1930
Ricardo Kuhn
a.k.a. Mr Rico Suave
Ricardo Kuhn's Avatar
Oddometer: 12,333
I have a Miller 211 MIG welder (Bigger brother of the 180) with the "110/220" capability, My problem is that I can not find the proper connector for the 220 mode, Do you guys know where I can find the part on the net since the shops around here (salt lake city) don't have a clue or maybe I'm just not looking on the right places.
Thanks in advance
Wanted: worn, ugly, cheap motorcycle cover for a big GS 1200
Ricardo Kuhn is offline   Reply With Quote
Old 04-02-2011, 11:19 PM   #1931
domains
domains's Avatar
Oddometer: 162
Trying to weld stainless for the first time with arc rods.
Will I see a bubble flow or will it welds like a mig?
welding it with ac
thx
domains is offline   Reply With Quote
Old 04-03-2011, 05:20 AM   #1932
David R
David R's Avatar
Oddometer: 2,484
Laugh Custom made my own.
Thanks in advance
I made mine. Using 12 gauge 110v extension cord and the proper plug.
I have a V160S and Miller passport. Both 110/220 Its easier using lengths of extension cord than running 60 feet of leads off my engine drive on the back of the truck. Both are pretty useless to me on 110.
I will take a picture if you want.
welding it with ac
thx
Welds like carbon steel with stick.
David
Old 04-03-2011, 09:46 AM   #1933
Strong Bad
n00balicious
Strong Bad's Avatar
Oddometer: 4,197
I like the brown, it seems to have a bit more stable of an arc. Never tried the orange.
"I couldn't wait for success, so I went ahead without it."
Strong Bad is offline   Reply With Quote
Old 04-03-2011, 05:03 PM   #1934
David R
David R's Avatar
Oddometer: 2,484
Laugh
I tried all colors of tungsten. Using an inverter, It doesn't seem to matter what I use. I do not use pure (green). A semi point is better than a ball for me on aluminum.
It does not matter what color the tip is when I dip it in the puddle which I seem to do a lot of. Carbon steel or aluminum.
I do have a sharpener with a diamond wheel. It was about three hundred bucks and worth it.
David
Old 04-03-2011, 05:21 PM   #1935
Ricardo Kuhn
Oddometer: 12,333
So where did you get the "proper Plug", yes I was ready to make my own too, In fact I have the "Cord" already as well as the "Wall Plug" but I'm missing the one that connects into the Miller receptacle.
Ps: I love the passport's reason why I got the 211, I just wish I have the extra money for one of them.
Times are GMT -7.   It's 12:28 AM.
