Old 05-13-2011, 11:18 AM   #1996
Tepi
Tepi's Avatar
Oddometer: 515
Looks like lack of gas or VERY dirty metal. Oh and one thing I consider necessary is a gas lens, my welds went 10x better after getting one.
Tepi is offline   Reply With Quote
Old 05-13-2011, 12:30 PM   #1997
bergermeister
housin'
bergermeister's Avatar
Oddometer: 1,634
sorry if this has been answered already, this thread is getting long...
can you mig weld on a steel bicycle frame? I've seen some high end tig, but that's outta my league.
thanks
bergermeister is offline   Reply With Quote
Old 05-13-2011, 01:57 PM   #1998
Strong Bad
n00balicious
Strong Bad's Avatar
Oddometer: 2,909
Can you mig weld on a steel bicycle frame? I've seen some high end tig, but that's outta my league.
yes
"I couldn't wait for success, so I went ahead without it."
Strong Bad is offline   Reply With Quote
Old 05-13-2011, 02:45 PM   #1999
bergermeister
housin'
Oddometer: 1,634
thanks
I'm thinking about a Miller 211. any thoughts?
Old 05-13-2011, 02:49 PM   #2000
Ironrdr
Pay No Attention...
Ironrdr's Avatar
Oddometer: 524
thanks
I was looking into this welder as well, with the thoughts of being able to weld aluminum.
Interested in the collective's thoughts on this model too.
Or another comparable model.
-darrell
It's a tough life, if you don't know how to live it.
2011 Ride West Ride Report
Ironrdr is offline   Reply With Quote
Old 05-13-2011, 07:38 PM   #2001
fxstbiluigi
aka Road Monster
fxstbiluigi's Avatar
Oddometer: 10,628
Send a message via Yahoo to fxstbiluigi
-darrell
Is the torch water cooled?
What is the duyt cycle of the machine? what is the max. amperage of the machine & torch?
and finaly what thickness of alum do you intend to weld?
fxstbiluigi is offline   Reply With Quote
Old 05-13-2011, 08:08 PM   #2002
David R
I been called a Nut Job..
David R's Avatar
Oddometer: 1,816
Laugh
A miller 211 is a mig welder. You CAN weld aluminum with a mig welder, but its a bitch unless you have spool gun or a TON of patients to try and get it to go through the machine. They make a nylon liner they claim will work. All they ever did is piss me off. I use TIG or if needed a spool gun.
Its like trying to push a rope.
Don't bother with the auto set feature, learn to use the machine and settings. Almost all have them inside the cover.
Here it is.
http://www.millerwelds.com/products/...p?model=M00245
I have this one, but the older model that will not take a spool gun. Its an awesome welder, I keep .030 ER70S-6 in it with C/25 or Co2.
http://www.millerwelds.com/products/...p?model=M00197
David
2012 R1200R ! 2000 R1100RT (retired), 1976 R75/6, 11 Versys
There is a seat for everyone.
David R is offline   Reply With Quote
Old 05-13-2011, 09:12 PM   #2003
bergermeister
housin'
Oddometer: 1,634
so, as far as mig welders go, you like it?
Old 05-13-2011, 11:38 PM   #2004
Ironrdr
Pay No Attention...
Ironrdr's Avatar
Oddometer: 524
I would purchase a spool gun with the 211. I'm not even gonna try to push aluminum wire through the regular set-up.
I currently have the Millermatic 130. I want to step up, but I don't know if the 211 is big enough of a step.
I can TIG weld better than I MIG, but the MIG is just so much easier and quicker.
Thickness of aluminum to be welded will probably be from .080 to .125.
-darrell
Old 05-14-2011, 03:49 AM   #2005
David R
David R's Avatar
Oddometer: 1,816
I love it. I have quite a few RED welders this is the only blue one. A lot of the time its turned all the way up. I have buned up almost 20 lbs wire since I bought it in December. The M10 gun is kind of cheesy and running the machine all the way up the gun cable can get warm. A bernard gun would be a good upgrade, but its not required. I have a OLD SP100 for the smaller stuff. I keep .023 wire in that one. At first I thought the passport would replace the old Lincoln, but only if I used .023 wire. This would limit the MAX output on the miller.
David
Old 05-14-2011, 12:46 PM   #2006
KTM640Dakar OP
Motorsick
KTM640Dakar's Avatar
Oddometer: 1,703
Originally Posted by Lomax View Post
I have a small crack in the mounting flange on my R100RS side bag rack. It is chrome plated.
Do I need to get all the chrome off before hitting it with a mild steel wire feed??
Marc
no. The chrome will just melt into your weld.
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
It is not the destination, it's the journey.
KTM640Dakar is offline   Reply With Quote
Old 05-14-2011, 12:55 PM   #2007
KTM640Dakar OP
Motorsick
Oddometer: 1,703
-darrell
http://www.lincolnelectric.com/en-us...g-welders.aspx
Power MIG 140 or 180 or 216 plus
The least expensive Lincoln Spool gun for aluminum welding using a Lincoln Power Mig is the Magnum 100SG spool gun. It is about $200 (at most)
The Lincoln Power MIG 140C (110Volts)or Power MIG 180C (230Volts) or Power MIG 216 (230Volts) all use the magnum 100SG spoolgun.
I have used all of them with great sucess. The bigger the welder the thicker you can weld.
Old 05-14-2011, 04:27 PM   #2008
fxstbiluigi
aka Road Monster
Oddometer: 10,628
That is why you need to grind the chrome off for about an inch all around the weld area.
By not grinding, before you weld the joint, you are adding chrome to the metal and changing the composition and grade of the steel.
Probably won't make much difference in the application you are talking about,
But I wouldn't want someone welding on a frame, of mine, with that same disreguard for the intergity of the frame material.
fxstbiluigi screwed with this post 05-14-2011 at 04:58 PM
Old 05-15-2011, 12:47 PM   #2009
the_gr8t_waldo
Oddometer: 1,852
thank you RD post 1995- one of my first stops was to the local welding suppy place. at that point i was starting to complie a very long, "what if" list. i asked and got a light weight fiberglass burn tarp/cloth. only 6 X6', but that was pleanty( along with lots of 4mmplywood (already on hand) to protect wooden stair treads and flooring. turns out that the fiberglass burn cloth was about the same price as the equivalent plywood!!! thanx again!!
the_gr8t_waldo is offline   Reply With Quote
Old 05-15-2011, 02:30 PM   #2010
Strong Bad
n00balicious
Strong Bad's Avatar
Oddometer: 2,909
Posted by the same guy who removes the copper coating from his filler rod!
Times are GMT -7.   It's 05:53 AM.
