07-05-2007, 12:40 PM
#196 |
Swabee
Oddometer: 5,525
I have a Lincoln 110 at home and a Hobart here at work, I prefer the Lincoln. No, KTM640Dakar didn't pay me to say that
Has anyone ever had flashburn? I did, only once, it sucked
06 KTM 950 Adventure S 08 Dodge 2500, QC Shortbed, Cummins 6-speed auto, Big Horn |
07-06-2007, 07:48 PM
#197 |
Oddometer: 22,983
I got to demo a Lincoln Invertec V205 today, nice machine. Seemed to have less arc wander than my Syncro 180, one day I may have to add one of these inverter technology machines.
07-11-2007, 01:57 PM
#198 | |
Motorsick
Oddometer: 1,707
Some good mig welders could spot tack over the holes then grind away the excess. This is probably the hardest way to fix it but it would be the least damaging.
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed. It is not the destination, it's the journey. |
07-11-2007, 02:03 PM
#199 | |
Motorsick
Oddometer: 1,707
http://www.lincolnelectric.com/produ...IG-Package.asp
07-12-2007, 08:47 AM
#200 | |
Yinz, blinkers are on.
Oddometer: 9,976
Somebody say they needed .017, 304 sheet for a Guzzi ressurection? Pm me.
If your looking for me. I will be at Rella's eating Blackberry pie. http://advrider.com/forums/showthread.php?t=791094 http://www.youtube.com/watch?v=_ampAFmwP_E |
07-12-2007, 01:15 PM
#201 |
Oddometer: 191
pan welding
I do some side work that involves chopping about an inch off of a subaru steel oil pan and then weld a 1/8 plate back on for offroad cars,I usually use ER-70-6 but have seen silicone bronze used, what do you suggest?The er-70-6 takes more talent and fitment ,but the silicone bronze is faster but looks cheap.....Steve
07-12-2007, 01:21 PM
#202 | |
Krusty Olde Pharte™
Oddometer: 4,849
[quote=KTM640Dakar]
MikeyT 86 Concours 90K75RT Non Illegitimi Carborundum Save $5.00 when you sign up for Smugmug. Use coupon code: vqfl6p4wLXH7s |
07-12-2007, 01:25 PM
#203 |
hayduke357
Oddometer: 464
ready welder
I have a ready welder works off car batties, it has worked well for the offroad stuff, but i was wondering if i could set up my old cj5 with a 24v set up and just step down the rest of the stuff like the guages that work and the lights. what ya think? then i could just leave the jeep running while welding and not have to worry about power drop? That is once i have some money just saying.
07-16-2007, 11:33 AM
#204 | |
Motorsick
Oddometer: 1,707
The ER70S-6 is classified as a mild steel wire with 70,000 pounds per square inch of tensile strength. Silicon bronze wire has much less tensile strength. The good thing about Silicone Bronze welding wire (SiBr) is that it is great for arc brazing very thin sheet metal. It is very forgiving since you actually braze the metal together rather than melting the parent metal. Typically I see a lot of MIG welding with Silicon Bronze filler wire in situations where you are welding two sheets of mild steel that are less than 1.2mm thick. Since it is forgiving you can get away with not burning through the parent sheet metal. And for the downside. Silicon bronze wire's strength comes from having a large surface area of the weld to gain it's strength. Since the tensile strength of a SiBr weld is say 1/10 the strength of steel you would need a 10X size weld. So you don't see alot of use of silicon Bronze weld wires for heavy or thick material. For a gas tank or other cosmetic application it works great. I would not use it to fix my kids swing set or build a skyscraper if you know what i mean.
07-16-2007, 11:38 AM
#205 | |
Motorsick
Oddometer: 1,707
[quote=RatBob]
07-16-2007, 11:40 AM
#206 | |
Motorsick
Oddometer: 1,707
07-18-2007, 05:58 PM
#207 |
Hit it
Oddometer: 31
welding on factor footpegs
i'm thinking about welding some plate steel on my factory pegs,after taking the rubber part off of course.Oh yeah i own a klr 650 so if anyone knows what i should do that would be great
07-18-2007, 09:29 PM
#208 | |
Don't harsh my mellow
Oddometer: 264
Thanks DK
I'll study this. . . obt |
07-19-2007, 07:27 AM
#209 | |
Oddometer: 9,976
Hey, at home I just use a lincoln stick welder. Nice cheapsetup. Will do just about everything. Including Alum with practice. But I use stick at work often on lots of crazy shit so, it doesn't bother me. Many feel mig is easier.
07-21-2007, 03:40 PM
#210 |
Old Guy nOOb
Oddometer: 2,692
Problem TIG welding a steel center stand
I was shortening my centerstand, and after grinding off the paint for about a inch around the area I was going to weld, and then wiping it down with Laquer thinner for good measure, I was having trouble TIG welding it. The puddle seemed to occasionally bubble and spark. I was using ER70S-2 welding rod, a Weldcraft WP-20 torch, 13N09 cup, a 1/16" Lanthanated tungsten, 15 CFH of Argon, a Thermal-Arc 185TSW set for 100A max current, DCEN and foot pedal control. Test welds on 1/8" mild steel seemed to be fine. It would seem like some kind of contamination but I don't know from what. Any clues as to what I was doing wrong?
It isn't the conditions its the decisions Don't bring a motorcycle to a car fight |
