Old 08-17-2011, 04:58 PM   #2161
Fe Man
I am Iron Moran!
Fe Man's Avatar
Oddometer: 8,106
Originally Posted by LarryGee View Post
I have never welded anything and thought I would like to learn how. Bought a cheapo 80 amp dc arc welder at harbor freight. Won't do aluminum but will do steel. Says it will do up 1/4 plates ( doesn't seem that thick to me ).
Anyway, just really enjoyed following this thread. I now realize that I should use my welder as a boat anchor and start all over.
But, I will wait. I can't even figure out how to position two pieces together to form a right angle and stay put while I try to lay down a bead !!! I don't think I should try and hold one side with my left hand while guiding the rod with my right....bad idea.
I will check out the Lincoln learning link and see how it goes from there.
Go Larry!
Lots of online tutorials and fabrication forums just waiting to help you...
2006 Tiger
2008 KLR (hers)
Fe Man is offline   Reply With Quote
Old 08-17-2011, 08:11 PM   #2162
LarryGee
Oddometer: 358
OK. So, I have to weld a steel plate to cap the opening of this motorcycle tire changer clamp. The opening is about 1 1/4 wide by 1 3/4 long. I purchased a length of steel that I can cut to size.
My questions are:
1) I keep reading that everything needs to be clean, clean, cleaned before welding. Does that mean that I need to remove the paint from the material before I weld the cap to it?
2) I guess this weld is called a "fillet" weld, where I am filling in the edges together? If so, any tips on how to secure the plate to the cap opening so I can run a bead? Do I just do a spot weld on the far end just to hold it in place?
3) Any sugggestions?
________________
BMW 1200GS WC
"I've never met a man on his deathbed who wished he had spent more time at the office"
LarryGee is offline   Reply With Quote
Old 08-17-2011, 08:19 PM   #2163
victor441
victor441's Avatar
Oddometer: 898
My questions are:
yep, needs to be clean and definitely no paint, get a 4" angle grinder and a cup brush for it and you can clean the steel up and remove the paint quickly....also get some welding magnets to hold things steady until you can do a tack or two
victor441 is offline   Reply With Quote
Old 08-17-2011, 08:42 PM   #2164
fxstbiluigi
crash test dummy
fxstbiluigi's Avatar
Oddometer: 12,011
Be sure to have a good soild grip on the grinder and expecting it to 'kik back' cause it will.
The basic question of politics is "Who does what to Whom?". -Vlademir Lenin.
"Politicians are always interested in people.
Not that this is always a virtue.
Fleas are interested in dogs." -P.J.O'Rourke
fxstbiluigi is offline   Reply With Quote
Old 08-17-2011, 08:54 PM   #2165
hugemoth
hugemoth's Avatar
Oddometer: 2,790
Not only that but they often throw off wire bristles. Be sure to wear a leather apron, gloves, and most importantly eye protection.
Old 08-17-2011, 09:46 PM   #2166
victor441
victor441's Avatar
Oddometer: 898
and never use one handed, I foolishly tried that and wirebrushed the other gloveless hand I was holding the work with and got a very nasty wound....have caught a few thrown bristles below neck level (they will go through jeans) and that was not too bad but I always wear a full face shield
Old 08-17-2011, 09:49 PM   #2167
fxstbiluigi
crash test dummy
Oddometer: 12,011
And when you're using a grinding wheel........... becareful where all them sparks go cause they will start a fire.
Old 08-17-2011, 09:56 PM   #2168
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 51,678
My questions are:
Or:
Jim
JimVonBaden is online now   Reply With Quote
Old 08-17-2011, 10:31 PM   #2169
marchyman
Cam Killer
marchyman's Avatar
Oddometer: 7,341
Originally Posted by JimVonBaden View Post
Or:
Those numbers have to be off by at least a factor of 10. Did you perhaps mean cm?
marchyman is offline   Reply With Quote
Old 08-18-2011, 06:30 AM   #2170
David R
I been called a Nut Job..
David R's Avatar
Oddometer: 2,453
No one can weld "through " paint. WHATEVER it takes to remove the paint is fine. Sandpaper, a file, grinder, or sometimes I burn it off with a torch then wire brush. A couple of small tacks then let er have it. If your piece fits properly then the joint will be called an outside corner weld. Show pics when done please.
Sent from my C771 using Tapatalk
2012 R1200R ! 2000 R1100RT (parts for sale!), 1976 R75/6,
There is a seat for everyone.
David R is online now   Reply With Quote
Old 08-18-2011, 06:34 AM   #2171
trailer Rails
trailer Rails's Avatar
Oddometer: 3,370
My questions are:
Yes and no, If you don't care how the weld turns out and it is not structural then you only need to take a little paint off if you are using a Mig or stick welder. If you want a nice looking weld, it has to be able to hold a load reliably or you want to TIG weld it, it needs to be very clean.
trailer Rails is online now   Reply With Quote
Old 08-18-2011, 07:26 AM   #2172
JimVonBaden
"Cool" Aid!
Oddometer: 51,678
, uh huh.
Jim
Old 08-18-2011, 01:25 PM   #2173
LarryGee
Oddometer: 358
Why do I get the feeling that my welding skills are going to wind up being the subject of the days entertainment ?
________________
BMW 1200GS WC
Old 08-18-2011, 01:27 PM   #2174
LarryGee
Oddometer: 358
Or:
Jim
I saw this but I don't have the top cap into which I can insert the screw that holds the plastic piece in place. That's why I'm having to do this welding thing...
________________
BMW 1200GS WC
Old 08-18-2011, 01:29 PM   #2175
LarryGee
Oddometer: 358
+ 1 on the illustration. Thanks,
By the way, I'm confused. Does the ground cable that comes from the welder have to be attached to the actual piece i am welding or can I attach it to ANY metal surface?
________________
BMW 1200GS WC
Times are GMT -7.   It's 11:44 AM.
