Old 11-22-2011, 03:46 PM   #2311
motu
Loose Pre Unit
motu's Avatar
Oddometer: 4,536
Originally Posted by Benesesso View Post
Big difference between "cannot" and should not.
I've done a lot of should nots...some times best practice is just not an option. A boiler maker I once worked with said there was no such thing as a vertical down weld,he called it a farmer's weld. Of course there was a reason he would tell me that,but sometimes you just have to do the only weld you can do.
motu is offline   Reply With Quote
Old 11-25-2011, 09:02 PM   #2312
KTM640Dakar OP
Motorsick
KTM640Dakar's Avatar
Oddometer: 2,089
Originally Posted by JagLite View Post
Here is the deal, I have a DR650 and want to mount up a GSXR muffler (a popular mod)
I want to make up my own exhaust midpipe by cutting and welding the stock stainless tubes into a new shape. (from another bike)
I have a Miller 220v and regular mix gas (c02/argon) and regular .30 wire.
The welds will not be seen and the pipe is mounted at 3 points so it should not see excessive vibration.
I really don't want to buy another tank for straight argon and a spool of ss wire to do the couple welds I need.
What happens when welding ss with mix gas and steel wire?
If this is a dumb question, I am not surprised, I am teaching myself how to weld as there is NO source of instruction here.
I asked at the shop where I bought my equipment, (they sold me a book and a video) the local university (have to take all required courses, not just mig) and I posted on the local forums asking about a private teacher but no luck. I do have fun though!
Use Blue Max 309LSi mig wire. You should use 98% Argon 2%Oxygen gas. Or a trimix of Ar,He,trace CO2.
It is possible to weld stainless with mild steel and 75/25 but it will rust. And is not recommended.
This MIG welder uses 110V or 220V.
POWER MIG® 180 DUAL MIG WELDER
PRODUCT NAME POWER MIG® 180 Dual MIG Welder
PRODUCT NUMBER K3018-1
INPUT POWER
120/1/60 or 208/230/1/60
RATED OUTPUT
120V:90A/19.5V/20%
208V: 130A/17.6V/30%
230V: 130A/20V/30%
INPUT CURRENT
20A
OUTPUT RANGE
120V: 30-140 Amps DC
230V: 30-180 Amps DC
DIMENSIONS (H X W X D) 14 in x 10.15 in x 18.16 in (357 mm x 258 mm x 472 mm)
NET WEIGHT 66.800 lbs. (30.300 kg.)
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
It is not the destination, it's the journey.
KTM640Dakar screwed with this post 11-25-2011 at 09:17 PM
KTM640Dakar is offline   Reply With Quote
Old 11-25-2011, 09:33 PM   #2313
KTM640Dakar OP
Motorsick
Oddometer: 2,089
Originally Posted by kubiak View Post
is it ok to weld chromoly tubing with a mig welder that has flux core steel wire?
Chromoly tubing is usually welded with E80S-D2 mig wire (Lincoln Superarc LA-90). The flux cored wire would be Outershield 91K2H.
Typically most mild steel flux cored wire like Innershield NR211 is an E70T-1 and is lacking chrome and moly so is 10Ksi less tensile strength. You can do it with mild steel fluxcore wire but it won't be the strongest weld you could get.
Old 11-26-2011, 03:41 PM   #2314
mark1305
Old Enough To Know Better
mark1305's Avatar
Oddometer: 6,050
Originally Posted by fxstbiluigi View Post
Most likly the welds were brushed with a mild steel brush or a stainless brush that had been contaminated with mild steel since stainless cannot be welded with mild steel.
Like some of the reply posts between the quote and this reply, yes you can and there is a big difference between cannot and should not. A quick check with a magnet told me there was mild steel filler in the header welds. Plus I have screwed around and tried mild steel filler on SS parent metal coupons and vice versa just to see wetting, puddle and flow characteristics when mis-matching materials.
Mark J
Merritt Island, FL
When a person asks you for advice, they don't want advice. They want corroboration.
mark1305 is offline   Reply With Quote
Old 11-26-2011, 05:49 PM   #2315
kirkster70
moto junkie
kirkster70's Avatar
Oddometer: 1,905
Mild steel E.M.T. TIG welded to stainless OEM muffler. Spraybombed with high-heat ceramic paint. No rust, no issues after over a year and many, many miles of riding in the rain.
kirkster70 is offline   Reply With Quote
Old 11-30-2011, 07:07 AM   #2316
FlySniper
Bleh...
FlySniper's Avatar
Oddometer: 1,662
Let's see how quickly I can make myself unpopular in this thread!
I just bought a HF arc welder.
This one:
http://www.harborfreight.com/135-ac-...der-97719.html
The specs say it's 135 amp AC and 105 amp DCEN/DCEP and will weld mild steel, stainless steel and cast iron.
I'd rather have a name brand welder, but I picked this one up on the last day of the recent sidewalk sale for $32 OTD.
I've taken welding classes years ago and really like stick welding, it's something I took to right off the bat. It didn't take long before I was good enough to lay nice welds (passed all the tests) and I even did well on small diameter tubing.
But I've read several threads here and abroad where people are pretty much of the opinion that arc welding isn't good enough to do anything with. What's up with that? I was going to pick up one of those hobby MIG welders... would that be a better idea?
FlySniper is offline   Reply With Quote
Old 11-30-2011, 09:40 AM   #2317
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,887
This one:
Those are just the Pretentious Welder Fookwits, don't mind them.
I have this one from Harbor Freight http://www.harborfreight.com/80-amp-...der-91110.html
What I need these days are prescription magnifying monofocal glasses, with a solenoid flip up mechanism. (Read: Prescription single-grind high-diopter glasses, with an electric flip-up mechanism. Similar to MLB flip-up sunglasses, only remote-controlled/automatic.)
http://www.franklinsports.com/fsm/b2.../2007/2125.jpg
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside screwed with this post 11-30-2011 at 09:46 AM
Poolside is offline   Reply With Quote
Old 11-30-2011, 10:16 AM   #2318
tmgs
...Trailers are for Boats
tmgs's Avatar
Oddometer: 1,005
or a set of these http://pixeloptics.com/pages/electronic_eyewear.html
I'm actually going to go look at pair soon, I have got to check them out
55 FLH, 58 FLH, 60 FLH, 61 FLH, 2 69 FLH's
06 GS, 07 GSA downsizing finally!
tmgs is offline   Reply With Quote
Old 11-30-2011, 11:29 AM   #2319
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,887
Neat idea!
I've tried both the visible and the invisible/gradient bifocal lenses, and I don't like them. I don't need a lens out past 18 inches or so. And I just can't seem to get comfortable having 2 different 'fields' in view at the same time.
Old 12-03-2011, 06:13 AM   #2320
dan0
just going with it.
dan0's Avatar
Oddometer: 452
Question on welding and electricity. Just got my bill and wow, I had to go check the meter because I was in shock. My average electric bill is $50, this month $90. I had my friends over using my garage for an engine swap and my welder was pulled out for three things.
1. Repairing engine mount cradle - 10 minutes at most
2. Welding a bracket onto steering rack - Couple minutes
3. Welding together one section of exhaust - 5 to 10 minutes
dan0 is offline   Reply With Quote
Old 12-03-2011, 06:19 AM   #2321
bosco
Raybanned
bosco's Avatar
Oddometer: 11,701
You got of cheap.
Did you factor in daylight siavings? My light bill always goes way up in the winter because the lights are on longer every day. That combined w/a bit of welding could be the difference.
___________________________________
"It's called the American Dream - because you have to be asleep to believe it." -George Carlin
bosco is offline   Reply With Quote
Old 12-03-2011, 06:23 AM   #2322
dan0
just going with it.
dan0's Avatar
Oddometer: 452
Originally Posted by bosco View Post
You got of cheap.
Nope didn't factor that in, or a couple loads of laundry through the dryer, since drying outside isn't as effective now. Just shocked. I've been in my house for 3.5 years and other than one month trying to run an a/c unit 24/7 my bill has never been over $50.
Old 12-03-2011, 03:45 PM   #2323
Skippii
Hookers, my lad.
Skippii's Avatar
Oddometer: 6,505
Just got given a lot of industrial cleaner.
It says it's 20% Phosphoric Acid, supposedly great for cleaning stainless steel and porcelain sinks and removing rust and calcium from stuff. I've got like 6 spray/squirt bottles (1 quart each)
I was wondering if it would be good for prepping steel prior to welding.
Is it? Any fumes/hazards I should know about?
"Umm be careful what you say, this is Skippii....
You may get it delivered in the form of a shake or some interperative dance routine that involves nakedness, pizza and a stuffed raccoon..." -DCrider
Skippii is offline   Reply With Quote
Old 12-07-2011, 04:32 PM   #2324
KTM640Dakar OP
Motorsick
Oddometer: 2,089
Welding Safety
This link has everything regarding welding safety that you should know.
http://www.lincolnelectric.com/en-us...ng-safety.aspx
Be careful with solvents when welding. Make sure that they are evaporated away before welding on the metal both for explosive reasons, as well as, fume/poison reasons.
Old 12-12-2011, 11:02 PM   #2325
xymotic
xymotic's Avatar
Oddometer: 8,367
I'm shopping for Plasma cutters...
I have maybe a dumb question. I need to replace some rusted 1/8" plate.
would it be possible (plausible/advisable/dumb?) to just c-clamp a new piece on top, and then use a plasma cutter to cut the old and the new together at the same time and then just weld it in?
Seems like you could do pretty complicated shapes really quickly if it can be done, but also seems too good to be true so
Originally Posted by Just_Sean
Oh for ***k's sake Aaron. Please link us to my fascist, racist or homophobic posts.
"Anyone who doesn't take truth seriously in small matters cannot be trusted in large ones either."
Albert Einstein
Baja trip to the tip
6:10 to Yuma
trials and tribulations in the Mojave
Baja Blitz Yard sale
View Current Location via Spot Tracker
xymotic is offline   Reply With Quote
Times are GMT -7.   It's 07:55 PM.
