08-10-2007, 03:21 AM
#226 |
Ravening for delight
Oddometer: 8,645
Thank you.
I was beginning to have weird thoughts of solid copper bus-bars. I'm going to give it a try. I'll get the heaviest damned extension I can find or fab and go for it. I really need to get that leg fixed before it rusts out completely, we've had a lot of rain lately. Raining right now, as a matter of fact. From the chart you posted, it looks like 10 gauge can carry 14.8 amps safely, but 8 gauge can carry 23.6, so unless I am missing something fundamental, I ought to be OK with 8 gauge wire out to a distance rather greater than I need.
Why did I drink all of the ingredients for vomit? "Used to be Man vs. Nature.. then Man vs. Space.. then Man vs. the Moon. Now it's Man vs. Food" - Dalar "you cannot reason a person out of something they were not reasoned into." - Jonathan Swift |
08-10-2007, 07:42 AM
#227 |
Oddometer: 8,645
OK, another question.
I have not as yet tried welding aluminum, but it seems that my machine (as mentioned earlier, the WeldPak 3200HD) is capable of it with an accessory kit: http://mylincolnelectric.com/Catalog...127#disclaimer I have a few questions: First, is it generally worth trying to weld 6061 aluminum with this box, regarding weld quality and material capability? Next, is it an awful, time-consuming switchover between steel and aluminum? It looks like a new drive wheel, and a new liner... Does that mean I have to thread the whole kit through the hose? And then swap back for steel? That would get kind of old. I am beginning to wish I hadn't purchased a rig until the new ProMIG came out that can take the spool gun. Thanks a lot!
08-12-2007, 08:41 PM
#228 | |
JWAT
Oddometer: 435
Joel Dallas, TX |
08-13-2007, 11:54 AM
#229 |
Iowhat?
Oddometer: 478
Recently while taking off my home-made Pelican racks, I noticed that the turn signal mount broke and half the tab came off in my hand. My question is if I disconnect the battery from both terminals, can I weld the tab back on w/out tearing the bike apart to get the rear sub-frame off?
--JOsh |
08-13-2007, 01:03 PM
#230 |
Motorsick
Oddometer: 1,704
Welding Aluminum using the MIG process.
MIG welding is a wire feed process that uses drive rolls to push the welding wire. MIG welding with steel wire it is quite easy and is sucessful because steel welding wire has plenty of collum strength that allows the drive rolls to easily feed the wire through the welding gun conduit. This conduit or "liner" is inside the gun and guides the wire to the end of the gun where it exits the contact tip (copper tip) of the gun. Because steel wire is strong it is easy to push through a long liner. Aluminum wire on the other hand has a relatively low collum strength. This causes the aluminum weld wire to sometimes buckle inside of the liner. (often refered to as trying to push a wet noodle through a tube) If the wire does not feed at a constant rate then you will experience problems with the wire burning into the copper contact tip (burnback). As soon as the contact tip gets melted by the arc it stops the wire from feeding and fuses into a melted mess. At this point all welding stops and you will have to replace the contact tip. Also when this occurs you may have what is called a "bird nest" in the wire feeder. This is caused by the wire stopping at the tip while the drive motor is trying to push it out and it tangles and causes a bird nest. This will all need to be cleaned up and straightened out before you can get back to welding. With most MIG welders you can help solve this problem by using a liner that is made out of a low friction material like teflon. Most gun liners made specially for aluminum are made from teflon to reduce friction and help get the aluminum wire smoothly fed out of the gun. This improves the feedabilty of aluminum wire. Also most drive rolls for steel wire are vee grooved and the ones for aluminum are u-grooved. You use a u-groove set of drive rolls for aluminum wire so that you can get a better grip on the wire, again to help with feedability. The last trick is to keep the MIG gun as straight as possible with as few kinks and turns in the gun itself as possible. This also helps reduce the friction on the aluminum wire. This is why special equipment is designed for MIG welding aluminum to overcome these feed problems. A spool gun is for welding aluminum and the roll of wire is right on the gun so it only has to push the wire a couple of inches instead of 10 or so feet depending on how long your conventional MIG gun is. You can convert a steel MIG gun to weld aluminum and most manufacturers have kits available to do this. In the kit you will recieve drive rolls, a plastic gun liner, aluminum contact tips, and sometimes a set of lighter drive roll springs so that the tension on the drive rolls is less to reduce bird nets that may occur. You will also need 100% Argon shielding gas. If you are going to use a MIG gun also use 5356 Aluminum welding wire. 5356 has a higher tensile and collum strength than 4043 Aluminum welding wire. The extra strength will help with feeding. Better yet buy a spool gun for your MIG welder. All of the Lincoln Power MIG units have spool gun capability. In fact the new Magnum 100SG Spool gun will fit both the Power MIG 140 and 180 MIG welders. This spool gun is $200. A mig convertion kit is $100. The frustration saved by using a spool gun will easily offset the $100 difference.
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed. It is not the destination, it's the journey. |
08-13-2007, 01:07 PM
#231 | |
Motorsick
Oddometer: 1,704
Clamp the ground clamp from your welder close to where you are welding and at least disconnect the negative connection to your battery. Remember that the flow of current that goes from the welding torch to the ground cable should be as short of a distance as possible. Try not to clamp your ground cable too far away from where you will be welding and avoid touching wiring harnesses and battery cables.
08-13-2007, 01:16 PM
#232 | |
Motorsick
Oddometer: 1,704
Lincoln also supplies 4043 spool of wire with the kit. You may want to also get a spool of .035 5356 wire too. The 5356 is slightly stronger and will feed easier. You will notice a little more black soot on your 5356 verses the 4043 aluminum wire chemistry. Yes the Power MIG welders solve these aluminum problems.
08-13-2007, 01:19 PM
#233 | |
Motorsick
Oddometer: 1,704
http://www.mylincolnelectric.com/Cat...et.asp?p=42749 If you have 115Volt power then use the Power MIG 140. If you have 230Volt power then choose the Power MIG 180. For aluminum always pick the bigger machine if you can afford it. They both use this spool gun.
08-13-2007, 01:54 PM
#234 | |
Oddometer: 8,645
I wonder if I can talk my wife into understanding why I need a second rig, dedicated to aluminum work!
08-13-2007, 04:53 PM
#235 | |
Syndicated
Oddometer: 11,286
Teflon liners are expensive and not as good as PE. The two highest grades of Poly Ethylene have lower friction and are more durable than Teflon, at a fraction of the price. I'm not dissing welders, or welding. I wish the industry wasn't contorted so heavily by manufacturers. I mean, it's difficult to have respect for such an extreme level of marketing-department-driven design. Poolside screwed with this post 08-13-2007 at 09:16 PM |
08-13-2007, 09:24 PM
#236 | |
Motorsick
Oddometer: 1,704
Poolside have you ever welded?
08-14-2007, 02:28 AM
#237 | |
Syndicated
Oddometer: 11,286
Enough to understand the state of the industry. |
08-15-2007, 02:21 AM
#238 | |
get lost
Oddometer: 535
lead filling
![]() So now, I've got to deal with the pin-holes, most of which I'm convinced are simlpy dimples after grinding . None-the-less, I've decided to try to lead them up. Eastwood has a kit with an instructional DVD. I'm already in over head. Who knows lead work? School me. I'm off to fish out the slag.
Harrison, A&S BMW , DUCATI & TRIUMPH "I am here to tell you that fast is better. I've always believed this, in spite of the trouble it's caused me." H.S. Thompson |
08-15-2007, 03:02 AM
#239 | |
Syndicated
Oddometer: 11,286
As far as lead goes, the trowel on semi-molten lead with a wood spoon method is fine for the rough surfaces. To seal the pinholes before that process though, a good clean, flux, and tin should work. |
08-16-2007, 01:42 AM
#240 | |
get lost
Oddometer: 535
