Old 01-11-2012, 03:36 PM   #2416
NewMexico505
NewMexico505's Avatar
Oddometer: 697
Send a message via AIM to NewMexico505
Originally Posted by tmgs View Post
So anyone here know how to setup a CNC plasma table with Mach III ,a CancCNC controller and sheetcam?
not sure what I was thinking at this point
No - don't know anything yet..but you didn't state what the problem is.
I'm looking at getting a CNC plasma table ..so please share what you learn.
Erik
"It is inhumane, in my opinion, to force people who have a genuine medical need for coffee to wait in line behind people who apparently view it as some kind of recreational activity."
NewMexico505 is offline   Reply With Quote
Old 01-11-2012, 03:43 PM   #2417
NewMexico505
Oddometer: 697
what, huh...
Originally Posted by bergermeister View Post
what's the story with Cor-ten steel? is that stuff available and, if so, is it ridiculously expensive? mild steel wire ok?
Are you talking about the treated steel for aesthetic quality? To weld it?
Erik
Old 01-11-2012, 03:57 PM   #2418
tmgs
...Trailers are for Boats
tmgs's Avatar
Oddometer: 886
Erik
so far, don;t buy one that you have to setup unless your really familiar with the cnc stuff to start
I will add, CandCNC support is darn good, they are helping us best they can and we did not buy this setup from them, we bought it used, partially finished,
Candcnc.com if you are planning oppn building your own system, I would start there and join tht forum to learn as much as possible before you buy, unless of course your buying a $100k machine
tmgs is offline   Reply With Quote
Old 01-11-2012, 04:07 PM   #2419
NewMexico505
Oddometer: 697
Yea, I doubt I will want to set one up myself, but who knows.
I'm looking forward to FabTech 2012 in Las Vegas to determine what I need.
100K is above my budget.
Erik
Old 01-11-2012, 06:27 PM   #2420
bergermeister
housin'
bergermeister's Avatar
Oddometer: 1,636
Erik
yes, http://en.wikipedia.org/wiki/Weathering_steel#Use
just wondering if anyone has used it and availability
bergermeister is offline   Reply With Quote
Old 01-11-2012, 09:54 PM   #2421
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,286
Check out www.cnczone.com You can get lost in there.
Here are some of the main forums:
Machine Controllers Software and Solutions
Electronics
OpenSource CNC Design Center
CNC Plasma and Waterjet Machines
Discuss building, operating CNC Plasma, waterjet and EDM machines here.
http://www.cnczone.com/forums/cnc_pl...rjet_machines/
This one subforum mainly deals with router tables. But it's all Open Source and much of the hardware for a CNC router table would also work on a CNC plasma table.
Open Source CNC Machine Designs
http://www.cnczone.com/forums/open_s...chine_designs/
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List
Poolside is offline   Reply With Quote
Old 01-13-2012, 07:41 PM   #2422
WIsixfitty
ceiling unlimited
Oddometer: 1,806
I just made a large logo sign for a outdoor products mfg company local to me for their corporate hq out of that material. Ariens.
Large as in aprox 10 foot diameter.
My employer had no trouble getting it and it welded and formed up just fine. iirc it was either 10 or 12ga sheet starting out.
sideways and smiling
WIsixfitty is offline   Reply With Quote
Old 01-13-2012, 10:10 PM   #2423
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 2,549
I remember that you couldn't get a lot of shapes without ordering them- sheet and plate and tube were stocked in Seattle (seaport steel), the rest of the stuff came from back east, and took a little while. I used to build trail bridges, and we mostly used self weathering steel (ASTM A-588), I'm pretty sure it's the same as what you're referring to, but we never called it Corten- just weathering steel, self-weathering steel, or A-588. Try those names if you don't get a response with Corten. I believe it's high in nickel to check the rusting process. We used separate welding wire and rod, of course.
A-588 is quite a bit stronger than A-36, too- could be that Corten or the like is something that's weathering, but no stronger than A-36 (and thus cheaper and easier to procure).
Zak
ktm
old bmw
others
slackmeyer is online now   Reply With Quote
Old 01-14-2012, 10:54 AM   #2424
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,286
I've never heard of 'weathering steel'. It has some nice properties, 119 year lifetime! Apparently Corten is the same material as A-588. In sheet form A-588 is known as A-606. And A-606 is aka Corten.
http://www.chapelsteel.com/A588.html
http://www.steeliq.com/steel-101/a606-type-4/
I wonder what the spec number is for the same material in tube or pipe shapes?
Edit: Ah. It's A-846 as tube or pipe.
http://www.centralsteelservice.com/pipe_tube.htm
http://www.centralsteelservice.com/cor-ten.htm
Poolside screwed with this post 01-14-2012 at 10:59 AM
Old 01-15-2012, 10:28 AM   #2425
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 2,565
Check out www.matweb.com to find materials by the following:
Quantitative Searches:
Physical Properties
Alloy Composition
Categorized Searches:
Material Type
Manufacturer Name
Trade Name
Metal UNS Number
tbarstow is offline   Reply With Quote
Old 01-15-2012, 11:58 AM   #2426
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,286
Oh man I forgot all about MatWeb. Thanks for the reminder!
Old 01-15-2012, 12:11 PM   #2427
KTM640Dakar OP
Motorsick
KTM640Dakar's Avatar
Oddometer: 1,707
Weathering steel is called Corten as a trade name. You should use ER80S-D2 mig wire or E8018 stick electrode on it. It is a good bridge steel and once it forms its protective oxide is takes a long time to rust away.
The mig wire that Lincoln recommends is Superarc LA-90 wire or Excalibur 8018-C1.
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
It is not the destination, it's the journey.
KTM640Dakar is offline   Reply With Quote
Old 01-15-2012, 12:16 PM   #2428
KTM640Dakar OP
Motorsick
Oddometer: 1,707
Erik
Check out this Torchmate cutting table. It will be at the Vegas show at Lincoln Electrics booth. Under $5000!
http://www.lincolnelectric.com/en-us...roduct=K3128-1
http://www.lincolnelectric.com/en-us...t_moneymatters
KTM640Dakar screwed with this post 01-15-2012 at 10:11 PM
Old 01-15-2012, 12:22 PM   #2429
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,286
Thanks for the stick recommendation.
Old 01-16-2012, 07:53 AM   #2430
NewMexico505
Oddometer: 697
Yes I am considering one of the larger TorchMates, one reason is Lincoln owns them, factory support should be good and Lincoln Electric will still be around in 10 years.
No decision yet however.
Erik
Times are GMT -7.   It's 11:25 PM.
