Old 02-20-2012, 11:54 AM   #2461
bergermeister
housin'
bergermeister's Avatar
Oddometer: 2,086
can stainless be welded with 100% argon?
I'd like to have one tank for aluminum and stainless if possible.
I know tri mix is the standard, but have been told that everything but really thick stainless could be done with 100 argon.
I've also read this from Lincoln: "Single-pass welds may also be made by using argon-CO2 gas. The CO2 in the shielding gas will affect the corrosion resistance of multipass welds made with short-circuiting transfer."
http://www.lincolnelectric.com/en-us...ss-detail.aspx
does that mean 75/25 is okay for single pass stainless, or are they referring to 98/2?
thanks
bergermeister is offline   Reply With Quote
Old 02-20-2012, 02:26 PM   #2462
WIsixfitty
ceiling unlimited
Oddometer: 2,333
I'll assume your talking MIG.
FWIW at work we are running 98/2 beacuse tri-mix/helium is in very short supply. Material is (316) .25" and smaller single pass short circuit .035" wire.
I am not a fan of 98/2 as setup is totally different plus it welds rather crappy.
I'm not sure about 100% argon.
sideways and smiling
WIsixfitty is online now   Reply With Quote
Old 02-20-2012, 05:51 PM   #2463
xymotic
xymotic's Avatar
Oddometer: 8,367
Without a torch or plasma, what's the next best way to cleanly cut a relatively large 2-3" or more hole into 1/8" mild steel plate? Looking for cheap entry cost, reasonable labor to get'r'done and hopefully a tool that won't have to be replaced every other job. but cheap :)
Originally Posted by Just_Sean
Oh for ***k's sake Aaron. Please link us to my fascist, racist or homophobic posts.
"Anyone who doesn't take truth seriously in small matters cannot be trusted in large ones either."
Albert Einstein
Baja trip to the tip
6:10 to Yuma
trials and tribulations in the Mojave
Baja Blitz Yard sale
View Current Location via Spot Tracker
xymotic is offline   Reply With Quote
Old 02-20-2012, 06:28 PM   #2464
xymotic
xymotic's Avatar
Oddometer: 8,367
Originally Posted by Benesesso View Post
Pretty cheap used, will cut a huge hole very cleanly. 12" hole in 1" plate, no problem.
Yeah, I prolly shoulda mentioned it's for working on my boat. Plate that's already on the boat.
Albert Einstein
6:10 to Yuma
Old 02-20-2012, 06:46 PM   #2465
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 3,154
jigsaw or holesaw. A mag drillpress with an annular cutter bit would be the cat's azz, but I'm guessing it's more than you need/want to pay.
Zak
ktm
old bmw
others
slackmeyer is offline   Reply With Quote
Old 02-20-2012, 06:53 PM   #2466
xymotic
xymotic's Avatar
Oddometer: 8,367
Yes, thank you :P
Is a decent bimetal holesaw gonna last for a few cuts?
Would a air saw be better then a regular jigsaw?
Anybody make a nibbler or anything that will work that thick?
Albert Einstein
6:10 to Yuma
Old 02-20-2012, 07:05 PM   #2467
slackmeyer
slackmeyer's Avatar
Oddometer: 3,154
Yes, thank you :P
A few cuts yes, but I've never gotten great life out of them- but I'm usually rushing/bungling some job, drilling at too high a speed with no cutting oil. I think with proper conditions, they could last pretty well.
Don't know about an air saw, but I think a jigsaw with a good blade would handle this easily- not as nice a hole though, and 3" is on the small end for most metal jigsaw blades that I see.
Zak
ktm
old bmw
others
Old 02-20-2012, 07:06 PM   #2468
P B G
Oddometer: 10,001
I'd go bimetal hole saw, slow with lube.
Old 02-20-2012, 07:43 PM   #2469
xymotic
xymotic's Avatar
Oddometer: 8,367
thx, that brings up another welding 'related' question: When you are drilling or cutting something in the process of a weld job/repair How do you get the oil off so you can get good primer/paint adhesion especially in nooks and crannies that might be inaccessible now that you welded the piece in there?
(nuther advantage of plasma I guess )
Albert Einstein
6:10 to Yuma
Old 02-20-2012, 07:49 PM   #2470
KTM640Dakar OP
Motorsick
KTM640Dakar's Avatar
Oddometer: 2,118
thanks
98% argon 2% CO2
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
It is not the destination, it's the journey.
KTM640Dakar is offline   Reply With Quote
Old 02-20-2012, 07:52 PM   #2471
KTM640Dakar OP
Motorsick
Oddometer: 2,118
Nice mill.
I wish that I had one.
Old 02-21-2012, 09:11 AM   #2472
bergermeister
housin'
Oddometer: 2,086
Originally Posted by KTM640Dakar View Post
98% argon 2% CO2
any thoughts on 100% argon for mig stainless?
Old 02-21-2012, 10:01 AM   #2473
bobivey
Oddometer: 39
Please do not take this as gospel as I am sure someone has welded stainless with straight argon. We used to use 90% helium 8% argon 2% CO2 to dip transfer MIG weld stainless. We now use 55% helium 43% argon 2% CO2, based on the high cost of helium. Both mixes work fine, we also have used 98% argon 2% oxygen on heavy 3/8" and thicker weldments with good success.
Good luck
bobivey is offline   Reply With Quote
Old 02-21-2012, 06:36 PM   #2474
fxstbiluigi
crash test dummy
fxstbiluigi's Avatar
Oddometer: 12,155
To begin with 1/8" is not considered plate it is sheet metal.
1/2" drillmotor with a bi-metal hole saw of the proper demention for the hole desired. Low speed with lots of liquid coolent.
The basic question of politics is "Who does what to Whom?". -Vlademir Lenin.
"Politicians are always interested in people.
Not that this is always a virtue.
Fleas are interested in dogs." -P.J.O'Rourke
fxstbiluigi is offline   Reply With Quote
Old 02-22-2012, 05:07 PM   #2475
David R
I been called a Nut Job..
David R's Avatar
Oddometer: 2,589
I would rather cut a 2" hole with a saw than a plasma or torch. No clean up and I would actually get the size I want.
Those cutters are the balls but cheapest was the question. I would only use one in a drill press.
Edit. I got 22 good 7/8" holes with an annular cutter in 1/4" stainless. l flooded it with PB blaster. The last 2 holes were nearly impossible. RPM was about 400.
David
2012 R1200R ! 2000 R1100RT (parts for sale!), 1976 R75/6, 2014 Vulcan 900 Trike
There is a seat for everyone.
David R is online now   Reply With Quote
Times are GMT -7.   It's 11:01 AM.
