Old 03-16-2012, 07:12 AM   #2596
MrBob
Careening forward
MrBob's Avatar
Oddometer: 5,662
I just finished a 10 hour intro to welding at CU in Boulder and have been returning to the shop to practice laying beads.
The masks provided are self darkening. The instructor set mine at 10. I've been working on MIG welding this week and damned if I can see a thing. I can barely make out the arc and can't see the work piece at all once the lens darkens. Can I lighten the lens enough to make out more detail without hurting my eyes?
KLX 400 dual sport
Tune in, turn on, drop out.
MrBob is offline   Reply With Quote
Old 03-16-2012, 07:48 AM   #2597
David R
I been called a Nut Job..
David R's Avatar
Oddometer: 1,816
Thumb
Yes you can, the UV protection is on even if the helmet does not change.
David
2012 R1200R ! 2000 R1100RT (retired), 1976 R75/6, 11 Versys
There is a seat for everyone.
David R is offline   Reply With Quote
Old 03-16-2012, 08:34 AM   #2598
KTM640Dakar OP
Motorsick
KTM640Dakar's Avatar
Oddometer: 1,704
The amount of amperage used determines the shade you need. Welding lens shades range from 9 lowest to 14 highest. You can look at the sun with a dark 14 lens shade. Your glass lens must be a 12 or darker. It usually says on the glass lens what shade it is. Most people using home welders will not need a shade darker than 12.
If you have an older fixed shade helmet you can buy lighter and darker glass shades. Go buy yourself a #10 lens if your welder is 250 amp or smaller.
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
It is not the destination, it's the journey.
KTM640Dakar is offline   Reply With Quote
Old 03-16-2012, 10:52 AM   #2599
NitroAcres
MotoBiggots Suck
NitroAcres's Avatar
Oddometer: 372
Originally Posted by Twin-shocker View Post
I wonder if anyone has advice on welding a swinging arm made from ISO AlCu4MgTi ? Its cast and has been heat treated to T6 level.
Exact spec is: Cu 4.6 Mg 0.25 Ti 0.2 Al
Consistent with 204 cast..I have never welded any..and don't know of a compatiable filler wire.
NitroAcres screwed with this post 03-16-2012 at 11:31 AM
NitroAcres is offline   Reply With Quote
Old 03-16-2012, 11:50 AM   #2600
Twin-shocker
Oddometer: 993
I get the feeling that 4043 will work fine............I would guess that most cast swinging arms are made from similar material? Seems AlCu is essentially very close to duralamin which was invented by the Germans way back when, and used to make Zeppelin air ships................
Old 03-16-2012, 12:02 PM   #2601
NitroAcres
MotoBiggots Suck
NitroAcres's Avatar
Oddometer: 372
Most Asian swingarms are more of a 356 type material and weld really well...200 series not so much...but good luck with your project...and watch for cracking after you put it into use.
Old 03-16-2012, 12:14 PM   #2602
Twin-shocker
Oddometer: 993
We are going to test the modified bike around an MX course, and if the SA is going to break it will do there!
Old 03-18-2012, 08:43 AM   #2603
JagLite
JagLite's Avatar
Oddometer: 598
Cry Blind welding
I have the same problem.
No classes or instruction available here so I bought the book and the video the welding shop sells when I bought my Miller mig (220v).
I bought the entire setup with gas bottle, wire brush, nozzle dip, auto dark hood, jacket, gloves, etc.... Total came to over $1,500.
I can adjust the lens shade up and down from the point where I can barely see the weld arc to very bright arc & puddle.
But I can't see the metal I am trying to join.
I have improved some in laying a consistent bead size but the bead is not along the seam or angle I am trying to weld.
I start at the intended point and can continue straight but when I lift the hood I see that my nice straight bead is at a slight angle to the joint because I can't see the joint....
I talked with the guys at the welding supply and they sold me a marking pen to draw a line on the steel.
Can't see that either.
Next they suggested a better ($$$) hood, so I bought the top of the line model they raved about.
Wow! What a difference!!!
I could see the weld arc a little better.
Still can't see the metal joint at all though.
Next, the guys suggested better lighting so I set up a halogen work light to shine on my work piece.
It usually just made my lens go dark before I could see my start point....
I had my eyes checked and they are fine, no reason they should be the problem.
I keep practicing and sometimes I can stay on the joint and think I am finally "seeing" the steel.
Then my next weld will be slightly off track even though I had thought it was right where I wanted it to be.
Very frustrating.
Fun, but frustrating.
I experiment with the lens setting and can find which one is the best for the amps I am using, but I can't see the seam of the steel.
Are some people just unable to see the work piece?"
Attitude ~
The difference between
Ordeal and Adventure
James
JagLite is offline   Reply With Quote
Old 03-18-2012, 09:14 AM   #2604
MrBob
Careening forward
MrBob's Avatar
Oddometer: 5,662
What did you need to spend for a decent hood? I've been perusing Amazon and looking at models for around a hundred bucks.
Tomorrow I start the week-long machine shop course which is next to the welding shop so I can continue to practice.
I'll ask my instructor if he has any ideas on the visibility thing.
KLX 400 dual sport
Old 03-18-2012, 12:37 PM   #2605
David R
David R's Avatar
Oddometer: 1,816
Harbor freight makes an ad helmet for about40.00 that works fine except for tig. I use a Miller elite. 300.00, worth every cent. I have a Lincoln Vista I do not like. It cost the same as the Miller.
Old 03-18-2012, 05:02 PM   #2606
Whitebread117
Oddometer: 371
Very frustrating.
Don't know what to suggest other than get your face in there. Move your head to one side so you can get your hood 10-12" from the arc.
One other thing that helps me especially with tig on small parts is cover your head/hood so no light comes in behind your hood. A piece of leather works best but a large shop rag or bandanna works fine for testing purposes. Cover the back of your head so you get zero light in from overhead/behind. It drastically improves the brightness/contrast of the light coming through the lens. It's a lot hotter/less comfortable than going without so I only do it when I can't get a good view otherwise. Try it and see if it helps. On any project where you're running a decent amperage/arc you shouldn't need to do this but if you're having trouble seeing the workpiece it might help.
Whitebread117 is offline   Reply With Quote
Old 03-18-2012, 05:26 PM   #2607
OHScot
Oddometer: 8
Really helps me to run the weld towards me instead of away or across. Weld in towards your face, (at your own risk of course) usually have to trigger with my thumb. Found the worse the position I was in the better my welds were, finally realized it was that I could see at the unnatural angle I had my arm and head. Otherwise I have to put my head closer than comfortable to the arc.
OHScot is offline   Reply With Quote
Old 03-18-2012, 05:29 PM   #2608
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,285
Use a silver metallic Sharpie. Steel is closer to black in color, and a black marker has relatively little contrast. The silver color shows up really well through the shade glass. Like it says on the side, store the markers tip down.
http://www.sharpie.com/enUS/Publishi...int_Silver.jpg
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List
Poolside is offline   Reply With Quote
Old 03-18-2012, 06:10 PM   #2609
ER70S-2
ER70S-2's Avatar
Oddometer: 2,556
Make sure you can see with both eyes. If your glove, helmet or any other obstruction blocks one eye, you've lost your depth perception.
If you have to use reading glasses, get a cheater lens for inside your helmet. They come in the same diopters as reading glasses.
http://www.welders-direct.com/mm5/me...Code=LNS-MXXXX
2004 DR650: 46,358 miles of
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 screwed with this post 07-08-2012 at 08:35 PM
ER70S-2 is online now   Reply With Quote
Old 03-18-2012, 10:41 PM   #2610
xymotic
xymotic's Avatar
Oddometer: 7,755
When MIG welding vertical, what's the proper procedure if you blow through the steel? Move faster and 'paint' in some metal? Simply stop and let it cool or ????
Originally Posted by Just_Sean
Oh for ***k's sake Aaron. Please link us to my fascist, racist or homophobic posts.
"Anyone who doesn't take truth seriously in small matters cannot be trusted in large ones either."
Albert Einstein
Baja trip to the tip
6:10 to Yuma
trials and tribulations in the Mojave
Baja Blitz Yard sale
View Current Location via Spot Tracker
xymotic is offline   Reply With Quote
Times are GMT -7.   It's 08:32 PM.
