03-19-2012, 03:46 AM
#2611 |
Raybanned
Oddometer: 11,096
Unable to see
A trick I learned a few years ago is to highlight all my marks, etc w/ soap stone.
___________________________________ "It's called the American Dream - because you have to be asleep to believe it." -George Carlin |
03-19-2012, 04:47 AM
#2612 |
I been called a Nut Job..
Oddometer: 1,816
Proper procedure is Don't blow a hole. :) You are probably running too hot
2012 R1200R ! 2000 R1100RT (retired), 1976 R75/6, 11 Versys ![]() There is a seat for everyone. |
03-19-2012, 08:58 PM
#2613 | |
Oddometer: 598
Blind welding is a bummer
I originally bought an auto dark helmet on eBay from a seller with great feedback for around $75. I got that before I bought my welder actually. It worked great and the Miller Elite wasn't that much better. The Miller is certainly higher quality plastic, but I still can't see. I had asked the welding supply about renting a demo model but they don't do that. Thanks everyone for the suggestions. I tried the silver Sharpie. I tried the soapstone. I have tried every position and direction of welding as well as getting real close (actually I am always very close). I don't use reading glasses and I make sure both eyes have a clear view. I have NOT (yet) tried covering the back of the hood to block light coming in from behind. I will try that next, thanks! Yesterday I was at it again, welding blind with the lens set at 10. Made a few nice passes and a couple were even going where I wanted them, but not many. When I watch the instruction video the steel is clear and obvious just like the arc and puddle. It looks so easy to monitor speed of travel, tip distance, and both pieces of steel, when you can see everything. I am guessing they have an auto dark lens for the video camera and it works great. My work doesn't look like the video at all, it is just all black except for the red/orange arc and puddle. I really don't think it is the hood, I think it is my eyes, or perhaps my brain not processing anything except the brightest object visible. I do have problems with driving at night, being blinded by oncoming headlights on our unlit highways. I don't look at the oncoming lights, I just watch the shoulder on my side ahead of me. I often use my left hand as a blinder to block the oncoming headlights too. My 57 year old eyes take a lot longer to adjust to changes in distance (focus) and light intensity so night driving is more difficult than it was years ago. I had hoped the expensive hood would solve the problem and if it had it would be well worth it. Hopefully it will be the answer for others. I will just keep practicing and if covering the back of the hood helps I will let you know. I am hoping.....
Attitude ~ The difference between Ordeal and Adventure James |
03-19-2012, 09:09 PM
#2614 | |
Careening forward
Oddometer: 5,662
It's true that as we age the muscles in our eyes that help us focus do become less efficient and one way this shows up is what you described with oncoming headlights; it starts to look like everyone has their brights on but they don't. What happens when you try lower settings, like 8 or 9?
KLX 400 dual sport Tune in, turn on, drop out. |
03-20-2012, 01:45 AM
#2615 | ||
This sentance intent
Oddometer: 14,670
Had no idea they existed!
DSI #694 Quote:
03-20-2012, 02:23 AM
#2616 |
Oddometer: 993
If you have problems seeing to weld, then first thing to try is magnifying lens with helmet you have currently, and better lighting. If thats no good, then get a Speedglas helmet, which are generally better optically than the Chinese made ones (which often have big name stickers fitted!), and provide lighter shades for lower amp welding.
03-20-2012, 03:55 AM
#2617 |
Oddometer: 344
I have read this before. Why is it that some helmets can't be used with TIG? What is the difference between a TIG arc through straight argon and, for example, an (aluminium) MIG arc through straight argon?
03-20-2012, 05:38 AM
#2618 |
Oddometer: 1,816
The helmet is not sensitive enough and flickers which will drive me batty.
My other helmets have sensitivity adjustment.
03-20-2012, 08:34 AM
#2619 | |
Oddometer: 598
Brighter and brighter...
On 8, it is more bright than comfortable and there is nothing else to see... I am sure it is very confusing to those who have little or no trouble seeing while welding to understand the problem we are dealing with. It is sort of like explaining a rainbow to a blind person. No frame of reference. As in all things in life... I have found this truth: "If I don't have the problem, there is no problem." Or so we tend to believe. Until some day we DO suffer with that problem.
03-20-2012, 11:23 AM
#2620 |
Old Enough To Know Better
Oddometer: 5,517
JagLite, even though I use a fixed shade (11) in a Jackson helmet with a nice big faceplate, I had some issues seeing while I was self-teaching.
One tip I picked up either here or over in a welding newsgroup was to never never watch the arc. Only look at the joint and the edge of the puddle that is freezing. Trust me, that is hard to practice but works. The eye is naturally drawn to the arc as its the brightest thing in view. Once you train the eyes to start on the joint and never look past the freezing edge of the puddle it gets way easier to put the bead in accurately and by watching the freeze zone you tend to work travel speed better too.
Mark J Merritt Island, FL When a person asks you for advice, they don't want advice. They want corroboration. |
03-20-2012, 12:56 PM
#2621 | |
Oddometer: 598
Self discovery
I thought about what you are saying, and I do believe that when I do the best, I am NOT looking at the arc, but as you say, the edge. Oh, boy! I am looking forward (har-har-har!) to practicing that the next time (Thursday) I can get in the garage for some quality time. ![]() After I posted this morning I have been thinking about my vision and how it has changed over time. I realized that it is a problem for ME, my eyes, not the hood or my (lack of) technique that is the underlying problem. I remembered the last time I went to see a movie in a theater. That for several years now I have had to find a seat before the lights go down. Once the lights are down, even if the screen is bright with something playing, I can't see the seats, the people, the floor, nada. I didn't have any problem when I was younger, I could walk right in the dark, see where people were sitting and find my friends. But now, my wife knows that when we go in, if it is dark, she either has to wait for several MINUTES (!) while my eyes adjust so I can see or she has to lead me by the hand like a blind man. She has to tell me if there are steps or any obstructions. Over several minutes my eyed do adjust and I can see OK, not great, but I can usually recognize friends faces unless the movie is showing night scenes.... ![]() If I have to run to the restroom during the movie, when I return I have to stand at the back and watch for several minutes while my eyes readjust. So, I do believe it is my problem to work with as best I can. I am pretty sure that looking at the arc is making it worse so I will work on not looking directly at it. I don't see that welding a bead for several minutes to adjust my eyes before I weld the area I want to do will be very practical. ![]() "Ummm, why does this weld bead run all the way down this tube and then around the joint?"
03-20-2012, 01:56 PM
#2622 | |||
Oddometer: 2,556
![]() Quote:
03-20-2012, 02:19 PM
#2623 | |
Careening forward
Oddometer: 5,662
I would discourage you from thinking your eyesight will prevent you from enjoying welding. What you're describing it pretty normal eyesight changes with aging. There are lots of ways to compensate. I was laying down beads in a line today when I noticed that the light reflected from the previous bead helped me stay on track. You might want to try laying something mildly reflective next to your bead to add a little more light. I showed these to my instructor and he said "decent" which is one step short of gushing for him. The previous batch were so ugly that I deleted the photo.
03-20-2012, 07:20 PM
#2624 | |
Oddometer: 598
Denial? Ha!
I don't need them for reading any normal text but instructions on some things are so small I need a microscope! I haven't tried my readers while welding yet because I can see clearly before all goes dark and I can see the weld puddle clearly while welding. But I will try it and see if it might help. I just did the exercise you suggested and I can read clearly at 8". I am sure I don't get that close to the bead! I was also in mid 40's when I went to the eye doctor to see (another punny!) what was wrong with my eyes. I had never needed glasses before and I was concerned there was a serious problem. She told me that it is a serious problem, fatal even! Yep, I was getting older... No cure for it either. My glasses correct my distance vision so I only wear them while riding & driving so I can read signs at a distance.
03-20-2012, 08:05 PM
#2625 | |||||
Oddometer: 2,556
![]() Quote:
![]() Quote:
2004 DR650: 46,358 miles of ![]() ER70S-2 screwed with this post 03-21-2012 at 12:43 PM |
