Old 07-01-2012, 12:24 PM   #2911
NitroAcres
MotoBiggots Suck
NitroAcres's Avatar
Oddometer: 529
350 or 700 Miller Dynasty, combine that with a HiAmp Speedway torch setup and you are good to go...(well with lots of practice).
700 Dynasty
3" od x 3/8" wall 6061 top machined part is semi sold (has a counterbore at the interface, 1/2" walls)..so total wall is 7/8"
Straight Argon, Start temp 100 degrees F.
NitroAcres screwed with this post 07-01-2012 at 12:46 PM
NitroAcres is offline   Reply With Quote
Old 07-01-2012, 12:29 PM   #2912
David R
I been called a Nut Job..
David R's Avatar
Oddometer: 2,615
Laugh
Originally Posted by AllenL View Post
I've been following this post for a while, and I've also been teaching myself TIG for the last 6 months or so.
What is the best to weld a nut to some mild sheet steel? I'd like to be able to weld these on so that I can bolt a part on what would otherwise be difficult to access the rear of. Do you use a bolt to hold the nut in place as you weld (this didn't work real well for me)? What are some tricks?
Thanks in advance!
ANTISEEZ on the bolt and yes bolt the nut to the plate or sheet. Weld in place, remove bolt while still hot. Most regular nuts and bolts are zinc coated. It burns off when you weld. Don't Breathe The White Smoke ! Non coated nuts are better but difficult to find.
David
2012 R1200R ! 2000 R1100RT (parts for sale!), 1976 R75/6, 2014 Vulcan 900 Trike
There is a seat for everyone.
David R is offline   Reply With Quote
Old 07-01-2012, 02:32 PM   #2913
Twin-shocker
Oddometer: 1,673
Originally Posted by R-A-M-O-N View Post
Thanks. Believe me i know the consecuences of a bad head repair, ive seen it more than once. As i said this is more of a long term project im planning in the long run, maybe for next year and use this year to get info, buy the necessary equipment (which isnt cheap at all), do some courses and practice a lot. But my ultimate goal is alu head repairs.
If you have a 3phase supply you should be able to get an old transformer Miller or Lincoln set for reasonable money, which will be perfectly ok for this type of work. I would also suggest some form of crack detecting equipment is a very good idea, as is a bead blast cabinet if you dont have one already.
In terms of cost though you could probably set up to repair cast iron heads for less than alloy, but gas welding cast iron is far more of a skilled process than TIG, which most can pick up in less than 30 minutes if they can gas weld already.
Cast iron repair is likely to be much more profitable than alloy, as very few people are able to do this, and if you have a TIG for alloy, you would also be able to repair parts like exhaust manifolds using TIG brazing.
Old 07-01-2012, 03:33 PM   #2914
clintnz
Trans-Global Chook Chaser
clintnz's Avatar
Oddometer: 3,583
David
Also, make sure you don't have a high tensile nut. The more similar the steels the better the weld will be. Of course the low tensile nuts are the ones that usually come galv or plated while the HT ones are plain...
Cheers
Clint
'03 KTM 640 LC4 Enduro
The wilderness, the desert - why are they not crowded
.................................................. .....with pilgrims?
clintnz is offline   Reply With Quote
Old 07-02-2012, 06:32 AM   #2915
dmaxmike
former quadtard.
dmaxmike's Avatar
Oddometer: 824
Originally Posted by NitroAcres View Post
that is GD sexy! was that welded out on a rotator rig or is there a start/stop hidden somewhere in all that bad assness?
I don't know how to ride a bike...yet
CRF250X
dmaxmike is offline   Reply With Quote
Old 07-02-2012, 07:19 AM   #2916
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,815
700 Dynasty
I just kicked my dog
Nice work fido!!!
We're not out here to rough it. We're here to smooth it. Things are rough enough in town.
Nessmuk
Old 07-02-2012, 09:47 AM   #2917
NitroAcres
MotoBiggots Suck
NitroAcres's Avatar
Oddometer: 529
Yep, turn table, and pulse...My trucks all have AM/FM/CD/Radio's, Electric Windows and A/C too....
I still go back and run my 1970's P&H Chemtron to remember the handcranks and 2/65 air, just for fun.
Old 07-02-2012, 11:08 AM   #2918
R-A-M-O-N
Oddometer: 297
700 Dynasty
Well if you could tell me were to buy the "lots of practice" part im all set Great work, some day ill have something worth sharing.
Since ill be adding to my dads business 90% of his work comes in form of aluminium heads. However i could ask around to see how much demand is there to weld cast iron heads over here, thanks for the idea.
R-A-M-O-N is offline   Reply With Quote
Old 07-02-2012, 11:19 AM   #2919
Twin-shocker
Oddometer: 1,673
TIG welding isnt really that difficult once you have the basics, and for welding heads a 300A transformer set with watercooled torch will be just fine, so you dont need to spend that much money on equipment.
Here in the UK very few people are able to repair cast iron parts, and in some cases the cost of replacement is very high, so setting up for these with gas and powder welding, and some form of furnace for pre-heat, post-cool, might be well worth looking at?
Old 07-02-2012, 03:19 PM   #2920
David R
David R's Avatar
Oddometer: 2,615
NitroAcres , that is some beautiful work.
Do you play a musical instrument?
I guess I am more of a meat and potatoes welder.
David
edited to give proper credit.
David R screwed with this post 07-03-2012 at 04:23 AM
Old 07-03-2012, 03:46 AM   #2921
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,860
Sick. And sickening that that's gonna get used for motorsports as opposed to being displayed in a museum.
"After reading through this thread I've come to the conclusion
that more people cruise the internet looking for reasons why
X bike won't work in Y scenario rather than actually riding
their motorcycles
RyanR
Mambo Dave is offline   Reply With Quote
Old 07-03-2012, 03:58 AM   #2922
NitroAcres
MotoBiggots Suck
NitroAcres's Avatar
Oddometer: 529
Worse, it is actually part of a Mobile Satcom Dish Support...not even a race part...:(
Old 07-03-2012, 06:55 AM   #2923
DaBit
Oddometer: 345
It would take me 100 years to learn welding aluminium like that, and even after 100 years I probably could not do it THAT nice!
About the nut welding: I put a little copper grease on the bolt (if I don't forget), tighten down the bolt so the nut stays where it is supposed to be, and use two tacks (on opposite sides). Since the welds only have to keep the nut in it's location a single tack would do, but two keeps things flatter/straighter and prevents the nut from bending inwards during a ham-fisted bolt install.
Advantage of two tacks only: little to no distortion, and quick.
DaBit is offline   Reply With Quote
Old 07-03-2012, 02:55 PM   #2924
Twin-shocker
Oddometer: 1,673
TIG welding really isnt that difficult, and top end inverter sets with features like pulse and AC/DC mix, make things even easier. Basically anyone able to gas weld will be able to pick up TIG very quickly, but not quite so easy without experience with gas, which other than setting your TIG machine will mean you are likely to understand the effects of heat, also how to control the weld puddle, and are pretty much good to go.
There are plenty of cheap Chinese AC/DC sets available nowadays, which make the TIG process accessible to far more people than a few years back when the only real options were either very costly, or very big and heavy and mostly required 3 phase power supply. For work on bikes an AC/DC TIG set is ideal, as it will mean you can weld pretty much anything likely to be found on a bike.
Old 07-03-2012, 03:54 PM   #2925
slidewayes
slidewayes
slidewayes's Avatar
Oddometer: 575
So what your saying is my $500 60's 300 amp 1000 lbs transformer is as good as a new $10,000 super duper solid state machine?
slidewayes is online now   Reply With Quote
Times are GMT -7.   It's 09:35 PM.
