Old 08-10-2012, 12:49 PM   #3016
Wadester
Rides a dirty bike
Wadester's Avatar
Oddometer: 1,971
Originally Posted by JAFO View Post
So yeah, that's gonna be fun having it stored in my garage...
It's not that bad. Just be sure to keep that 3rd leg of the triangle (heat/ignition) under control. Make sure fittings are clean and dry (no oils!) when connecting. And always open valves slooooooowly to reduce the chance of particle impact ignition. It's not like the old days when you were making acetylene by dropping calcium carbide into water in a big sealed tank (an exothermic reaction that creates a gas that can detonate/explode).
Two roads diverged in a wood, and / I took the one less traveled by, and / now where the hell am I?
This isn't a "you're doing it wrong" topic. (Originally Posted by Human Ills, 7/1/14)
Wadester is online now   Reply With Quote
Old 08-10-2012, 06:21 PM   #3017
JAFO
displaced Jeep guy.....
JAFO's Avatar
Oddometer: 3,974
Honestly, the heat is the biggest concern. This will be in an exterior, unattached garage. In South Cackalacki. 100 degrees in the shade during the summer...
JAFO is online now   Reply With Quote
Old 08-12-2012, 09:38 PM   #3018
KTM640Dakar OP
Motorsick
KTM640Dakar's Avatar
Oddometer: 2,063
Originally Posted by ChrisE View Post
What happened here
Welding Class....Welded an aluminum box using stainless steel rod...
Why? Did you grab the wrong TIG rod? That looks like poop.
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
It is not the destination, it's the journey.
KTM640Dakar is offline   Reply With Quote
Old 08-13-2012, 12:58 PM   #3019
dmaxmike
former quadtard.
dmaxmike's Avatar
Oddometer: 784
i have cut outside all day for weeks on end in direct sunlight and never had a problem. People use torch sets in much hotter places then your backyard shed like the ship yards in NC/SC/VA. Don’t worry about it people on the internet told you it was safe.
I don't know how to ride a bike...yet
CRF250X
dmaxmike is offline   Reply With Quote
Old 08-14-2012, 09:25 AM   #3020
JAFO
JAFO's Avatar
Oddometer: 3,974
Well hello, then I know it is true...
Hey ya'll watch this... I saw it on the Internet..... :-)
Sent from my MB886 using Xparent Green Tapatalk 2
Old 08-14-2012, 03:31 PM   #3021
clintnz
Trans-Global Chook Chaser
clintnz's Avatar
Oddometer: 3,423
From my dim memory of engineering class gas storage pressure vessels usually have a design temperature of 50C/120F, then on top of that there are all sorts of other safety factors. Ask your gas supplier.
Cheers
Clint
'03 KTM 640 LC4 Enduro
The wilderness, the desert - why are they not crowded
.................................................. .....with pilgrims?
clintnz is offline   Reply With Quote
Old 08-14-2012, 03:48 PM   #3022
P B G
Oddometer: 10,001
Or drive by your local gas supply in the middle of the day. Bet they don't have their tanks in air conditioned storage, no matter where you live.
Old 08-14-2012, 05:51 PM   #3023
KTM640Dakar OP
Motorsick
Oddometer: 2,063
Your Oxy fuel bottles are fine in the hot sun. Just dont let them leak in a closed room or car and light them. Also dont let more than 14 psi out of an acetalylene bottle or it tends to self ignite. Keep an acetelyne bottle upright to keep the acetone inside from coming out of the bottle. If you do knock it over you should give the bottle time to settle the acetone to move back to the bottom of the bottle. The bottle has a menbrane that keeps the acetone and acetelene stable and safe. Sorry no spell check.
Old 08-17-2012, 11:54 AM   #3024
ivantheterrible
Oddometer: 564
i hope this hasn't been asked already--i want to use some old tin roofing for a project, but don't want to get zinc poisoning. is there a (best) way of doing this? Cross wind from a fan? respirator? ( if so, a simple vapor one?)
I've read about removing the zinc plating with acid, but this seems nearly as problematic as the zinc plating its self. i heard vinegar will work, but takes a long time.
Anyone have any experience with this? Thanks
ivantheterrible is offline   Reply With Quote
Old 08-17-2012, 12:37 PM   #3025
Wadester
Rides a dirty bike
Wadester's Avatar
Oddometer: 1,971
Outdoors with a breeze works well with oxy/acetylene. Respirator with zinc fume cartridges would be safest.
The one time I wanted to clean the zinc off and away, I used muriatic acid. Takes off zinc like washing off mud. Didn't attack the steel underneath, but I did wash/neutralize it after.
Old 08-17-2012, 12:57 PM   #3026
ivantheterrible
Oddometer: 564
thanks wadester.
How will I know when the zinc is gone, if I use the acid method? I know what the zinc plating looks like, will it just look like regular metal when the zinc is gone?
if I wire brush it off, how far from the weld area do i need to take off to be safe? Also, again, if i use this method, how will i know when it's gone?
Thanks again!
Old 08-17-2012, 02:22 PM   #3027
ER70S-2
ER70S-2's Avatar
Oddometer: 6,106
I think muriatic acid fumes are as dangerous as the zinc, be careful with that crap. Outdoors during a tornado would be good.
2004 DR650: 62,400 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is online now   Reply With Quote
Old 08-17-2012, 03:00 PM   #3028
Wadester
Rides a dirty bike
Wadester's Avatar
Oddometer: 1,971
Muriatic fumes are irritating, nasty. Zinc fumes are poisonous and can cause permanent damage. Well ventilated spaces are always a good idea.
You can easily tell when the acid has taken away the zinc. Obvious color difference, plus no more bubbly mess. Wire wheel will not remove all the zinc. Grinder, maybe.
How far to clean? How big is the heat discolored area gonna be? A bit more than that. Clean a generous area. You'll need to paint/coat the area if you want rust protection anyways.
Old 08-17-2012, 03:14 PM   #3029
ivantheterrible
Oddometer: 564
Can I get good results by brushing the acid on the areas to be welded? I think the size of the pieces to be welded might make finding a large enough container to soak them in difficult.
thanks again!
Old 08-17-2012, 03:47 PM   #3030
WormShanks
b00b
WormShanks's Avatar
Oddometer: 348
thanks again!
How much welding are you going to be doing on those things? If it's not going to be hours worth I would think doing the work in a well ventilated area and keeping your face out of the fumes would be sufficient.
http://www.sperkoengineering.com/htm...Galvanized.pdf
Ridden: AF AM AW AU AT AZ BS BH BD BB BY BW BV BR IO BN BG BF BI KH CM CA CZ DK SV GQ ER EE ET FK GI GR GP VA HN HK HU IS IN ID IR IQ KI KP KG LA LV LB LU NR NP NL AN NC NZ NI NE NO OM PK PR QA RE RO RU RW LC VC WS SM ST TM TC TV UG UA AE GB US UY UZ VU YE
WormShanks is offline   Reply With Quote
Times are GMT -7.   It's 02:51 PM.
