Old 08-17-2012, 05:26 PM   #3031
David R
I been called a Nut Job..
David R's Avatar
Oddometer: 2,619
Originally Posted by ivantheterrible View Post
i hope this hasn't been asked already--i want to use some old tin roofing for a project, but don't want to get zinc poisoning. is there a (best) way of doing this? Cross wind from a fan? respirator? ( if so, a simple vapor one?)
I've read about removing the zinc plating with acid, but this seems nearly as problematic as the zinc plating its self. i heard vinegar will work, but takes a long time.
Anyone have any experience with this? Thanks
Yeah, I had a bad experience with galvanized on a cell tower site. If you breathe too much of the white smoke, it gives me the shits and the shakes in the middle of the night. Only once.
I grind the galv off but. If its on both sides, it will burn off the other side too.
If you grind it, the metal will make sparks and the coating will not. A wheel made for aluminum will not load up like a wheel made for steel. There is a color difference between the coating and the steel, but its hard to see unless in good light.
Just don't breathe the white smoke!
David
2012 R1200R ! 2000 R1100RT (parts for sale!), 1976 R75/6, 2014 Vulcan 900 Trike
There is a seat for everyone.
David R is offline   Reply With Quote
Old 08-17-2012, 05:37 PM   #3032
fxstbiluigi
crash test dummy
fxstbiluigi's Avatar
Oddometer: 12,187
And don't believe anyone that tells you to drink milk "It will take the poison out of your system" That's an old wives tale.
Zinc, the coating known as galvanizing, is a heavy metal.
The basic question of politics is "Who does what to Whom?". -Vlademir Lenin.
"Politicians are always interested in people.
Not that this is always a virtue.
Fleas are interested in dogs." -P.J.O'Rourke
fxstbiluigi is offline   Reply With Quote
Old 08-17-2012, 10:23 PM   #3033
Commanderkewl
Commanderkewl's Avatar
Oddometer: 176
One thing about oxyfuel bottles is not overpressurizing the system.. Acetelyne will combust most easily, without a flame if the pressure is above the 10 (15 in the book, just dont run the pressure on the gauge in the red zone) psi mark.
Having the guage open a 3/4 turn is all that is needed.
Ive seen the truck with hoses over pressurized and 6 bottles go up in smoke..
Ive also seen welders run it high and not get bit....your luck will run out sometime.
Zinc- no laughing matter. Shortens your life.. Heavy metal, yes.
www.aee.vt.edu/teacher-resources/lab-safety-resources/oxyfuel.pdf
1982 Yamaha 750 Virago- 80k sold
1980 Yamaha 650 Maxim- 45k RIP
1982 Suzuki GS1000-30K Sold
2001 BMW K1200LT-24K "Sally"
2004 BMW R1150RT-16K "BluByYu"
2007 BMW R1200GS-1.6K"Hawk"
I hate to advocate drugs, alcohol, violence, or insanity to anyone, but they’ve always worked for me.
— Hunter S. Thompson
Commanderkewl is offline   Reply With Quote
Old 08-18-2012, 04:19 AM   #3034
ivantheterrible
Oddometer: 610
thanks for all of the replies.
The problem with grinding is that the metal is very thin, (old roofing tin) and I'm afraid I can easily take off more metal then I can afford.
This is for a sculpture I'm working on. I'm planning on cutting out the shapes, shaping them on the english wheel, then attaching them together. I'd love to completely weld every seam, but it'll more likely be several tacks.
if it matters, I'm using oxy / acet for the work.
ivantheterrible is offline   Reply With Quote
Old 08-18-2012, 08:21 AM   #3035
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 3,519
Use a respirator with zinc cartridges and use a wire wheel to remove the zinc. Since the material is thin, try tacking them to a backing plate.
tbarstow is offline   Reply With Quote
Old 08-18-2012, 09:08 AM   #3036
victor441
victor441's Avatar
Oddometer: 1,042
pressure change with temperature....also tube notching
is proportional to the change in degrees kelvin, so the pressure increase for a gas bottle going say from 70F to 120F is not all that great... i.e. P1/T1 = P2/T2 or P2= (P1*T2)/T1 P2= P1 * (322/294) so P2 is about 10% higher
http://en.wikipedia.org/wiki/Gas_laws
on a unrelated welding topic just made a rack out of 1/2" tubing (not finished yet in the photo) and discovered a 12" round file is just the right size to notch the tubes and works quickly if the notch is started w/ an angle grinder...have a hole saw type notcher but AFAIK hole saws are only available as small as 3/4"
victor441 is offline   Reply With Quote
Old 08-18-2012, 11:04 AM   #3037
JAFO
displaced Jeep guy.....
JAFO's Avatar
Oddometer: 3,975
Very nicely done. What process did you use, and and how did you make the bends? Also what kind of tubing?
Sent from my MB886 using Xparent Green Tapatalk 2
JAFO is online now   Reply With Quote
Old 08-18-2012, 01:10 PM   #3038
victor441
victor441's Avatar
Oddometer: 1,042
Thanks! I used MIG to weld and the tubing is 1/2" 16ga ERW, cheap and easy to find, Home Depot, Tractor Supply, etc carry short lengths that are overpriced....much cheaper to buy a 20' stick from a steel supplier. I packed the tube with sand (MUST be completely dry or a steam explosion is possible), heated sections with a MAP torch, then bent them around a big socket clamped in my vice...made a template out of coathanger wire first to get the bends right.
FWIW there is a good article on sand bending at http://www.rorty-design.com/content/sand_bending.htm
also at http://www.v-eight.com/tech_forum/viewtopic.php?t=203
victor441 screwed with this post 08-18-2012 at 01:19 PM
Old 08-18-2012, 01:16 PM   #3039
JAFO
JAFO's Avatar
Oddometer: 3,975
Damn! Great idea, will have to test this out sometime.
I remember years ago going roundabout with one of the Senior 'engineers' the about why we were not getting good bends in our network equipment conduit, they were trying to use a pipe bender and wouldn't believe we needed to pack the tube with sand. They're out of business now, for some reason ;-)
Old 08-18-2012, 08:30 PM   #3040
fxstbiluigi
crash test dummy
Oddometer: 12,187
HAHAhaaahaaha about a year or so ago someone was wondering how to bend pipe/tubing and I suggested packing it with sand, even went into some detail, about how to do that. I GOT crusified by all the self proclaimed experts that know everything about metal fabrication.
Old 08-18-2012, 08:56 PM   #3041
fxstbiluigi
crash test dummy
Oddometer: 12,187
Can I get good results by brushing the acid on the areas to be welded? I think the size of the pieces to be welded might make finding a large enough container to soak them in difficult.
thanks again!
If you are that worried about zinc poisining and using acid to clean the metal why not buy a 4' or 5' x10' sheet of 16 or 18 ga metal that hasen't been galv'ed. It can't be that expensive and you'll save money and time by not halving to mess with the acid and clean-up after.
Old 08-19-2012, 07:24 AM   #3042
ivantheterrible
Oddometer: 610
actually, the finished project will be out of 16 gauge steel, I mostly want to use the tin roofing for the model and to work out some of the kinks.
Anyway, i found a suitable container, bought some muriatic acid, and it worked great. thanks for all the replies and hopefully I'll have something to show soon.
Old 09-01-2012, 06:26 PM   #3043
KTM640Dakar OP
Motorsick
KTM640Dakar's Avatar
Oddometer: 2,123
Cross Country Pipeline adventure.
http://www.youtube.com/watch?v=J-x4U...e_gdata_player
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
It is not the destination, it's the journey.
KTM640Dakar is offline   Reply With Quote
Old 09-01-2012, 10:26 PM   #3044
Pago Cruiser
Pago Cruiser's Avatar
Oddometer: 295
I gotta welding question...
Have a late model XR1200 Sportster converted to a dual dual purpose hack. Lots of fun off-road, but I gotta start buying clutches by the 6-pack...Done all I can with countershaft and rear wheel sprockets. Need to work on crank and clutch basket sprocket sizing.
Bummer for me: While the XR primary system (using a 3 row chain) is pretty much a clone of a Buell XB, NO ONE makes crank sprockets other than stock 34T (US) or 38T (Europe) for the XR, and a 35 is available for the Buell.
I figure a 30T would be just about right. But the only way I can see to do it is to get a 30T made for an earlier Sportster, and then weld/machine a new inner spline hub from an XR donor sprocket. While I have a Miller MIG and putz with little stuff like saddlebag mounts, my skills mainly consist of being able to burn a hole in just about anything...
All I am looking to find out is: Is this project doable? Welding hardened steel used in this stressed rotational/shear environment? I assume some pre and maybe post heat treatment would be required? Or should I be looking for a machinist to make me something from scratch?
Thanks in advance.
Just because you're not paranoid doesn't mean they aren't out to get you...
Pago Cruiser is offline   Reply With Quote
Old 09-01-2012, 11:35 PM   #3045
Twin-shocker
Oddometer: 1,673
Thats certainly possible. You will need to get the donor parts accurately machined, ideally with some kind of register so they fit together perfectly, then TIG weld them together. Forget about doing the job at home with a small MIG set, as failure or sprocket not running true is very likely if you try this.
Times are GMT -7.   It's 10:07 PM.
