08-09-2012, 12:16 PM
#3046 |
Rides a dirty bike
Oddometer: 1,416
I've got my own oxygen and acetylene bottles - when you take them in, you have to wait for them to be filled (was next day IIRC). If you take a swap, then it is hard to tell who owns what.
I inherited the O2 bottle from my dad, and got the acetylene as military surplus. Both had to be hydro'd when I took possession.
Two roads diverged in a wood, and / I took the one less traveled by, / And now where the hell am I? 'Being an adult is so much better when you forget that you're supposed to be boring' (D.Corsetto, 9/7/12) |
08-09-2012, 05:55 PM
#3047 | |
KLR-650
Oddometer: 260
My take... not saying it's right or anything... just me. Cylinder caps are for transporting. I don't take the regs off when not in use. When finished, I do make sure the bottle valves are closed and the torch valves OPEN such that if anything is leaking it will keep leaking and not build up pressure in something that can't take it. Also, I'd be nervous about storing any explosive gas (inc oxygen) in an airtight enclosure. Ventilation is good. There's a picture floating around of some guy's SUV... leaking propane tank in the back. After he noticed, he drove it out of the garage and decided it would vent faster if he opened the windows... electric windows. He lived, the interior was fine, but all the panels blew off both sides of the shell. Stupid thing looked like it was skinned. Enclosed space is what gets you. A ventilated shed sounds good. David... |
08-09-2012, 07:30 PM
#3048 |
displaced Jeep guy.....
Yeah I saw tha same thing- a yellow FJ with "TNKA TY" custom plates. At least it was only a modern FJ, thus not a big deal.
Just as a minor point- O2 isn't explosive. O2 is an oxidizer- it promotes combustion but does not itself burn. A pedantic point perhaps, until you see some dumbass use O2 to cool off after a hot day in the shop... and then pretty much explode into flame. Self-emolation by way of stupidity. So yeah, WON'T be doing that! Also- and not trying to start something here- but you may wish to re-think your storage protocol. The caps are there to protect the valves... both from being knocked off in event of a drop, and to prevent them being bumped and made to leak. NOT trying to be a safety-mommy sort, (but honestly that wouldn't be bad with acetylene- I understand it's one of the most dangerous gasses to work with in terms of it's explosive percentage (2.5%-80% mix with air). Just... be careful out there, huh? Building shit is all kinds of cool, but the tools and processes we use can bite you if you're not careful.. ![]() (this said, I'm the dumbass that was welding up the frame for a welding cart the other night.... looked up after I made the base and remembered I had a bike full of gas and 15 gallons of "loose" gas in cans, 5 feet from the job. This makes me a bit more cautious now... :) )
Interested in a Charleston, SC ADVdinner? |
08-09-2012, 08:05 PM
#3049 | |
aka Road Monster
The basic question of politics is "Who does what to Whom?". -Vlademir Lenin. "Politicians are always interested in people. Not that this is always a virtue. Fleas are interested in dogs." -P.J.O'Rourke |
08-09-2012, 08:13 PM
#3050 | |
Rides a dirty bike
Oddometer: 1,416
![]() Oxygen, or some other oxidizer is necessary for fire - but it doesn't "burn" - that's what the fuel does. Does air burn? Fire is rapid oxidation - rust is slow fire.
08-09-2012, 08:24 PM
#3051 |
aka Road Monster
What does oxy become after it has gone through a fire?
08-09-2012, 08:37 PM
#3052 |
Syndicated
Oddometer: 11,285
CO2 mainly, and some CO. All fuel is a hydrocarbon (CxHx) chain of some sort, well except H2 and hydrazine of course. Call it any CH compound that was built with photosynthesis say.
08-09-2012, 08:43 PM
#3053 |
aka Road Monster
Why was hydrazine banned as a fuel for dragsters way back when?
08-10-2012, 03:50 AM
#3054 |
What is this, a test? Crap.. it's like those dreams in highschool- I'm naked and there's a test today that I forgot to study for...
08-10-2012, 07:06 AM
#3055 | |
former quadtard.
Oddometer: 487
if you already have a gas rig and are looking for regulators just buy a new set as they will have all the modern safety features such as the flame arrestors already built in. as far as pressures go i run about 10-12psi for my ace and anywhere from 30-50 for my oxy. no need to take the regs off after use. just close the bottle valves and drain the psi from lines and regs by cracking the valves on the torches.
i don't know how to ride a bike...yet XT225 - short, fat, and slow; its my motorcycle twin. F650 GS Dakar -little taller, lot heavier, and much faster. |
08-10-2012, 07:08 AM
#3056 | |
Rides a dirty bike
Oddometer: 1,416
Also, for high pressure oxygen - everything is a fuel. Specifically metals that are used to contain it. Here's a picture of what happens with a little contamination: ![]() ![]() ![]() Single frames taken from high speed video of an ASTM G175 Phase 2 promoted ignition test. Each frame was taken after the first frame to exhibit flame corresponding to the following milliseconds time periods from this point: (a) 4 ms, (b) 15 ms, (c) 26 ms and (d) 65 ms. Oxygen fires like this usually only last a few milliseconds - but pretty much blast everything. They tend to self-quench, but only after going off like a bomb. Imagine your hand on the valve handle there. Info from here: http://www.astm.org/SNEWS/ND_2008/ch...wton_nd08.html
08-10-2012, 09:41 AM
#3057 |
So yeah, that's gonna be fun having it stored in my garage...
08-10-2012, 11:49 AM
#3058 |
Rides a dirty bike
Oddometer: 1,416
It's not that bad. Just be sure to keep that 3rd leg of the triangle (heat/ignition) under control. Make sure fittings are clean and dry (no oils!) when connecting. And always open valves slooooooowly to reduce the chance of particle impact ignition. It's not like the old days when you were making acetylene by dropping calcium carbide into water in a big sealed tank (an exothermic reaction that creates a gas that can detonate/explode).
08-10-2012, 05:21 PM
#3059 |
Honestly, the heat is the biggest concern. This will be in an exterior, unattached garage. In South Cackalacki. 100 degrees in the shade during the summer...
08-12-2012, 08:38 PM
#3060 | |
Motorsick
Oddometer: 1,702
Why? Did you grab the wrong TIG rod? That looks like poop.
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed. It is not the destination, it's the journey. |
