Old 11-02-2012, 02:24 PM   #3166
David R
I been called a Nut Job..
David R's Avatar
Oddometer: 2,618
Laugh
Lexleroy, Everyday you own a new tig welder and do not use it is a sin.
I like your regulator. It must be made by a company that sells gas.
I use 15 cfh for mig or tig and usually its plenty. There are times I use more like with Aluminum tig. Other times I Can use less especially with a 3/8 (#6) gas cup mig or tig.
This does not make me right. My Harris Flow regulator with a ball and glass says its calibrated for a .050" orifice. No need to ever change it or even see it. As long as you get the proper amount of shielding.
My first Mig was a Lincoln SP100 in about 1985. It came with a fixed 35 cfh regulator. I burned through an 80 cf bottle in the first day. I exchanged the regulator for an adjustable one when I got the tank filled. I still have that regulator.
Enjoy your machine. I want to see pictures of your welds.
David
2012 R1200R ! 2000 R1100RT (parts for sale!), 1976 R75/6, 2014 Vulcan 900 Trike
There is a seat for everyone.
David R is offline   Reply With Quote
Old 11-02-2012, 03:18 PM   #3167
LexLeroy
Chief Mansplainer
LexLeroy's Avatar
Oddometer: 2,611
David
Tell me about it. I'm holding the new TIG, a Thermal Arc 185 Arcmaster, over my own head as an incentive to finish the bicycle that I started for my daughter. I'm down to the final braze-ons and bridges between the stays, but I got distracted this summer with my dirt bike. The poor V-Strom also suffered some serious neglect as well.
Here's the daughter's bike so far - brass fillet brazing for some of the lugs and then silver brazing the lugs to the tubes. The thing behind the bike is the frame fixture that I built to hold all of the pieces together for pinning and brazing.
And here's two of the home-made fillet brazed lugs, shown with a production investment cast lug, prior to being silver brazed into the bike.
Brazing with oxy-fuel is fun but I'm pretty stoked about learning TIG... looking forward to lots more conversations in this thread.
"They're smarter than you son... that's why they're the police."
LexLeroy screwed with this post 11-02-2012 at 03:28 PM
LexLeroy is offline   Reply With Quote
Old 11-05-2012, 07:14 AM   #3168
NitroAcres
MotoBiggots Suck
NitroAcres's Avatar
Oddometer: 530
BeerCap shown only for size relationship....
Britt Lynn
NitroAcres
Ball Ground Ga
NitroAcres is offline   Reply With Quote
Old 11-05-2012, 02:40 PM   #3169
David R
David R's Avatar
Oddometer: 2,618
LexLeroy, those are some beautiful had made parts.
Nitro Acres, nice welds. I got no rhythm......
My son and I have a job shop. We tig as much as we can.
David
Old 11-27-2012, 04:38 PM   #3170
JAFO
displaced Jeep guy.....
JAFO's Avatar
Oddometer: 3,975
So you remember those oxy-fuel cylinders I came across a couple months ago? Yeah- I also scored two sets of portables, cheap.
I hae been an oxy-acetylene cutting FOOL over the last month. Trying to figure out brazing now- I blew through an oilpan I was trying to braze a fitting onto. I think I should have used a welding tip, not the cutting head (duh!). To my credit, I didn't activate the cutting jet.
I still have to go get the big bottles filled. That's going to be a pain in the ass- local shops won't fill them if you don't have a pickup bed to put them in.
Did the gent that was trying to use a pressure reg on a Lincoln 3200HD ever get the code broken on settings and such? I would like to give gas-MIG another shot.
JAFO is online now   Reply With Quote
Old 11-28-2012, 12:10 PM   #3171
DiabloADV
Semi-Occasional
Oddometer: 2,336
I've got a Hobart 110v wire feed welder (with gas). I'm looking to weld up some exhaust pipes. I am NOT a highly skilled welder.
I'm looking for technique tips on welding mild steel pipes together. I found this YouTube vid that seems to make a lot of sense to me, at my skill level. Rather than try to lay a bead, the guy makes a series of tack welds around the tube. This strikes me as a way to really control what I'm doing.
http://www.youtube.com/watch?v=_v_6j...eature=related
Thoughts on this approach? Better suggestions...?
1974 R90/6 motor w/1050 kit; twin plugged; installed in...1970 R60/5 frame; RM125 front end; KZ1000 Police Tank.
DiabloADV is offline   Reply With Quote
Old 11-28-2012, 03:45 PM   #3172
LexLeroy
Chief Mansplainer
LexLeroy's Avatar
Oddometer: 2,611
Flux is your friend. When it turns glassy w/ no bubbles then it's hot enough to melt the filler metal - too much heat and you roach your flux. Use a flux that wets out at the right temp for your filler. For bronze or nickel silver I use Gasflux type "B" - similar to Harris #17 (that blue paste stuff).
LexLeroy screwed with this post 11-28-2012 at 04:17 PM
Old 11-28-2012, 04:55 PM   #3173
David R
David R's Avatar
Oddometer: 2,618
Laugh
A true tack weld is made to break off if needed or hold things in position to be welded.
A series of tacks would be a series of welds made to break off.
I weld exhaust with an SP100 turned down C 3 .
I start at the top and make my way down. One pass each side.
Make a dry pass to see where the gun will fit if its on the car.
David
Old 11-28-2012, 09:02 PM   #3174
fxstbiluigi
crash test dummy
fxstbiluigi's Avatar
Oddometer: 12,186
David
David:
A 'tack' also needs to be strong enough to hold the parts in alignment and withstand the pressure of coaxing the rest of the weldment into alignment. And withstand the stresses of welding once the fit-up is complete.
The basic question of politics is "Who does what to Whom?". -Vlademir Lenin.
"Politicians are always interested in people.
Not that this is always a virtue.
Fleas are interested in dogs." -P.J.O'Rourke
fxstbiluigi is offline   Reply With Quote
Old 11-28-2012, 09:13 PM   #3175
DiabloADV
Semi-Occasional
Oddometer: 2,336
What I mean is to use a series of short welds rather than a long bead.
Old 11-29-2012, 08:59 AM   #3176
JAFO
JAFO's Avatar
Oddometer: 3,975
This will work fine, it's how I built the exhaust on my Jeep. Butt-welded tubes and short tacks. It's been bounced off of rocks and, while the tube has been squashed in areas, the welds have NOT failed.
Sent from my MB886 using Xparent Green Tapatalk 2
Old 11-29-2012, 09:00 AM   #3177
David R
David R's Avatar
Oddometer: 2,618
What I am trying to say is learn the machine. Set it so you can run a bead. It is the right welder for the job. .023 ER70S-6 wire and c/25 gas. I do a lot of exhaust.
If its too hot and you continually have to stop then turn the machine down. If you are almost blowing through then the heat is right.
Have fun and enjoy the machine.
Sent from the phone in my shoe. Maxwell Smart.
Old 12-02-2012, 04:44 PM   #3178
Schlug
JockeyfullofBourbon
Schlug's Avatar
Oddometer: 7,465
Originally Posted by fxstbiluigi View Post
David:
eh, don't confuse the two. You tack pieces together and give them a smack, maybe too. But a third or fourth time or too much movement and your pieces are going to be laying on the ground.
In other words, tacks hold together only when subjected to a small force. And when the gap isn't right, the fitter will simply break the tack and have the welder start over.
"So what makes this protest different is that you're set to die, Bobby?"
--May well come to that.
"You start a hunger strike to protest for what you believe in. You don't start already determined to die or am I missing somethin' here?"
-- It's in their hands. Our message is clear. They're seeing our determination.
Schlug is offline   Reply With Quote
Old 12-02-2012, 05:12 PM   #3179
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 15,224
It's fine for exhaust, don't weld a roll cage like that or anything your life depends on. We call that WyoWelding(Wyotech teaches that and it's technically wrong), the weakest part of a weld is the start when it's the coldest and that technique gives you a full weld of cold starts...wrong, but fine for exhaust.
Old 12-02-2012, 05:26 PM   #3180
NitroAcres
MotoBiggots Suck
NitroAcres's Avatar
Oddometer: 530
If a Tack was a Weld, it wouldn't be called a Tack....Tacks are to hold stuff together till you Weld it....a bunch of tacks stacked ontop of each other is Not a Weld.
Britt Lynn
NitroAcres
Ball Ground Ga
Times are GMT -7.   It's 01:10 AM.
